Old 07-12-2009, 03:47 PM   #271
Nitro-Racer*'s Avatar
looks like that the one way is shot, will need replacement... as for how to get it out, get all the shaft out and just hammer it i guese
Xray Nt1-Novarossi 3sct-KoPropo-GRP-Altis 2.3-RB Fuels
Xray 808 09-RB Killer 9-Hitec-KoPropo-RB Fuels
Nitro-Racer* is offline   Reply With Quote
Old 07-12-2009, 05:35 PM   #272
Omarko's Avatar
Originally Posted by Omarko View Post
is it worth upgrading my G4S w/ WC kit and other hop ups to the new G4RS or should I just get an XRAY NT1 ? what do you guys think ?
Originally Posted by NitroWD View Post
the new RS09 is a new platform, you cant convert G4S to it.
I did not mean upgrade the current car I have ... I meant as in getting the G4RS 09 over the NT1 ...
Omarko is offline   Reply With Quote
Old 07-12-2009, 06:06 PM   #273
you have pm
Old 07-12-2009, 07:32 PM   #274
aizenbelle's Avatar
Originally Posted by mettuchi View Post
Hi
I have a problem with my G4RS2009 and i wonder if someone can help me please. While i was driving the car, the first gear stripped and the car stopped. After investigation i saw the first gear stripped really bad. Anyway i came home and tried the to take off the first 62t gear which one way bearing installed. But i couldnt take it off, it looks like it is stuck on the shaft. Did it happen to anyone else? I tried really hard to take it off but it doesnt come off!!!! Can someone tell me what to do please?
wow!! what happened?? did you crash prior to this problem? let us know if you can find out.that is pretty interesting.
by the way I have just tested my front differentials and they seem to do the job just fine for such a tiny box.
Hey Impalabob did you race your car yet. tell us how you did
Don't Blame it on the car when you know you cant drive
X_ray Nt_1 08
RRR WC (For sale!!)
G4+EVO
G4RS 09' (IT'S FINALLY HERE!!!!!) Serpent 733 put on hold!!
aizenbelle is offline   Reply With Quote
Old 07-12-2009, 07:35 PM   #275
Company Representative
OLD 69's Avatar
Trader Rating: 44 (100%+)
If you want a G4RS 09 shoot me a PM, we have them in stock
...Ari
www.hobbyexpress.com.au
www.nbhc.com.au
OLD 69 is offline   Reply With Quote
Old 07-12-2009, 07:37 PM   #276
aizenbelle's Avatar
Smile
well if it was between the G4+EVO and the NT1 I would say both are just as good. RS09 is on a different level I think. But I would suggest you test both of the cars because everyone can give you their point of view and tell you one is better than the other, but you will never find out till you try it first hand Good luck.
X_ray Nt_1 08
RRR WC (For sale!!)
G4+EVO
Old 07-12-2009, 07:54 PM   #277
LAKIA's Avatar
Hi
well,well,we face the same problem yesterday during our club race A main final..one car can only run 6 minutes and the other was in the 10 lap leading position at about 25 min,the problem come.
what we think is the too much free play of the 2 speed shaft force the one way bearing on the first gear housing bearing to jam.
till now, we still cann't remove the first gear..
TM should had done something to this..
we had been driving the first G4 till now..the RS strip 2 nd gear all the time n now the RS 09 strip first gear.
LAKIA is offline   Reply With Quote
Old 07-12-2009, 08:11 PM   #278
aizenbelle's Avatar
man that is interesting, so do you recommend to shim up the two speed?? I dont want this to happen to me and if it is preventable I may as well do it now
X_ray Nt_1 08
RRR WC (For sale!!)
G4+EVO
Old 07-12-2009, 08:53 PM   #279
PrimeAKF11's Avatar
Hi
I just came back from a race and this was exactly what happened to me. Car was running fine and the 1st gear just stripped when it was about to shift into second. (Had to happen when I was in third place, on a trophy race to boot! ) Took it apart at home and the oneway bearing/housing is stuck on the shaft HARD .
I'm both glad and concerned to know that I'm not the only one with this problem. Glad because it probably means I wasn't doing anything horribly out of place, concerned because it points to a design flaw of sort and in that case I wouldn't be able to run the car until the problem is solved. Right now I need to order a few things but can't because I'm not even sure if I'll ever be able to press the oneway housing apart from the shaft .
Best rubber tires>> www.SweepRacingUSA.com
For your Team Magic G4 parts needs>> www.bluesunhobbies.com
HD Videos of Blue Diamond Onroad Raceway!!! 200ft+ straight of fury!! >> http://www.rctech.net/forum/racing-forum/406318-2nd-annual-pete-johnson-have-nice-day-memorial-race-5.html
PrimeAKF11 is offline   Reply With Quote
Old 07-12-2009, 10:00 PM   #280
Want to know what kind and size of the receiver battery works in the new G4RSII?
ioxqq is offline   Reply With Quote
Old 07-13-2009, 04:07 AM   #281
kickass's Avatar
kickass is offline   Reply With Quote
Old 07-13-2009, 06:25 AM   #282
i have seen the new G4RS with stripped first gears at my track.... the pay on the 2 speed is really too much... hope shimming will help...
katze is offline   Reply With Quote
Old 07-13-2009, 06:54 AM   #283
impalabob64's Avatar
Send a message via AIM to impalabob64
Default Stripped Gears
I had my first race with the car no gear strip. 3 QFr,s 1 10min main,finished third .I always drop a couple drops of one lube after every round ,especially with a new car. The only thing was the car had a on power push.But i have more testing but overall the car is fast.I ran used a motor that wasnt the greatest but got the job done. Also has anyone experience an on power push,may go to 100,000 in the rear diff.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 07-13-2009, 06:59 AM   #284
freestyles's Avatar
Trader Rating: 14 (100%+)
Wow 100k in the rear diff, now that's heavy Wouldn't that contribute to the pushing you already have?
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 07-13-2009, 07:11 AM   #285
aizenbelle's Avatar
Questions?? Oneway
Kool man!!! PrimeAKF11 was going to get top 3 too but his oneway got stuck, he said he emailed TM so hopefully we will find out what the deal is with the oneway. He said he had shim his two speed shaft but I dont think this would contribute to the oneway failing do you? have you shimmed yours?. I have not yet shimmed mine and I am hesitant to do it now since I have been doing fine without it. hopefully will find out soon enough.
X_ray Nt_1 08
RRR WC (For sale!!)
G4+EVO
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
Team Magic G4 + EVO afm Nitro On-Road 421 08-05-2011 01:31 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Just Hobby 1/10 Onroad GP Sedan Challenge Race 2( 08 March 2009 ) justhobby Singapore R/C Racers 28 04-08-2009 10:59 AM
