Old 04-16-2011, 05:13 PM   #1591
flynia's Avatar
Hi Team,
Have done a bit of a rebuild of my G4RS 09 over the last week or two. I'm going to try the old K Factory G4 Shocks for a bit of bling and difference. We will see how it goes
Also! My New EX-10 EURUS Radio as well!
Team Magic G4RS 2009 / K Factory K1007-3 Body Shell
RB T10-RC Engine and EFRA 2659 Pipe Set
Hitec Servos - HS-7775MG (Throttle) and HS-7965MG (Steering)
LRP LiPo RX PACK AAA HUMP 1700 RX 7.4v with MuchMore MRG-5A Regulator
KO PROPO EX-10 EURUS Transmitter with KR-407S Receiver
flynia is offline   Reply With Quote
Old 04-16-2011, 11:12 PM   #1592
Bundy_Bear's Avatar
Originally Posted by abi View Post
Hi Andrew,
I run 2mm spacers under the front inner upper pivots so as to lower my front roll centre, I'm trying to gain some front grip. I will be trying a higher rear roll centre this Tuesday night so as to take away some rear grip. These 09's have so much roll centre adjustment its not funny, fine tune with the upper arms and major changes with the lower arms (K Factory mounts).
For wheelbase I run maximum short due to our small low grip track, again heaps of adjustment here.
I think the latest trends from other manufacturers is for spots on the chassis to mount weights at the front, middle and rear and I feel one reason they can do this is because the completed cars are so underweight these days and weight redistribution has drastic effects on chassis balance, a match made in heaven. The 09's are light but no places to quickly add screw-in brass plates like others.
Hi Adrian
Good to hear from you. I guess it is similar setup to the the G4+ Evo in the front it just lacks information in the manual as to how to change it. Also suprised you can't change the location of the pin like previously with the plastic insert.
Take car and have a safe Easter
Andrew
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 04-19-2011, 07:46 PM   #1593
abi
Dont even get me started on the manual! What a POS that document is...
I like the front, with the K factory arm mounts we can run short or long arms as well as infinite roll centre adjustment.
I'd like to see TM or KF release a revised front bumper similar to the G4+evo with the CF upper and separate plastic nose cone, they worked really well. I tend to stay clear of impacts generally but how many front bar plastics have I used in the past 2 years
At the same time TM/KF could redo the body posts so they actually fit current bodies, so over the front posts going through headlights and the rear posts too high. The fifth post is perfectly located,... go figure.
I have had two weeks of flukie unrelated engine woes in the club championship with one round to go so i have lost my 1st and 2nd positions in outlaw and protourer. The 09 is going like a rocket though, much better car than they are credited for IMO.
Originally Posted by Bundy_Bear View Post
Hi Adrian
Andrew
Team Magic tragic. G4S RTR, G4S, G4S+Evo, 3 x RS09's.
OS Speed, Spektrum.
abi is offline   Reply With Quote
Old 04-19-2011, 09:25 PM   #1594
Trader Rating: 53 (100%+)
wondering if you Nitro guys can help a nitro offroader ...ran nitro onroad back in the day ,,,anyhow i ran a E4 JS in vta as a relax locally class and it was dialed ...but i ran AE springs blues and greens ....
can someone please PM or post here on what number's for K factory springs match or at least come close...VTA i could get away with the high ride hieght but im gonna run it as a USGT car and wanna lower that bad boy
TIA!
Rick Hess
Yokomo-Amain-Protek RC
R&C Hobby shop Clarksville TN
RCP Customs-RC Juice
rkhess is offline   Reply With Quote
Old 04-20-2011, 09:49 AM   #1595
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Guys,
Anyone have info on the new nitro sedan from TM ?,
thanks,
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 04-20-2011, 07:20 PM   #1596
Tabushi's Avatar
Hi guys,
Just wanted to share couple pics with you, this weekend i will be doing break inn of my XXXV Sirio engine + VP PRO TS-1 pipe, first time racing sirio im very excited ...
I installed the LIFE PACK made by td-civ from this forum so i will test them too :
I've been using ALIGN DS-620 servos on my 1/10 nitro sedan, very nice results so far very pleased lots of torque and speed for this scale ...
cya !!
Old 04-21-2011, 06:13 PM   #1597
Quietroit's Avatar
Questions?? k factory part
Can anybody help to explain what the k factory 14212, k14201, k14200 parts do for the 09 ex adustment roll-center , suspension arm length.What a good start point low, high,small and large tracks. THank u
G4rs 09|3pk| KO KO PROPO
Quietroit is offline   Reply With Quote
Old 04-22-2011, 03:57 AM   #1598
abi
Happy to be corrected but longer arms are for bumpy tracks and shorter arms for smooth. Roll centre relates to track grip and open/tight. Low grip tracks tend to like lower roll centres to generate side grip and higher traction tracks tend to like higer roll centres. Front to rear grip can be influenced by roll centre too, lower the roll cenre at the end needing more grip.
Adrian
OS Speed, Spektrum.
Old 04-23-2011, 09:54 AM   #1599
peter.'s Avatar
Can I use Sanwa SDX-801 low profiel for gas / brake for the g4rs
peter. is offline   Reply With Quote
Old 05-09-2011, 02:33 PM   #1600
peter.'s Avatar
g4rs
Old 05-09-2011, 02:39 PM   #1601
peter.'s Avatar
g4rs
Old 05-09-2011, 02:52 PM   #1602
td-civ's Avatar
Trader Rating: 18 (95%+)
looks good im going to run mine for the first time this year on sat im running a new shock setup this year and i think its going work even better
td-civ is offline   Reply With Quote
Old 05-13-2011, 02:37 PM   #1603
peter.'s Avatar
does anyone know when the new 200mm Team Magic car is for SALE
Old 05-13-2011, 03:49 PM   #1604
Chickentrader's Avatar
Originally Posted by flynia View Post
Hi Team,
Good luck with the radio. I'm disappointed with ours. The old loved KoPropo Helios radios were starting to fail, and we recently upgraded.
The new KoPropo's have an extra menu to select from. It was quicker before to just scroll up or down, and has made the menu functions a little slower to get to. This I can handle without any worries; but they have also remodelled the "Autostart" function, which was a really useful function before. It has now become something that requires different throttle trigger movements to work at all, and will stop functioning if you move the throttle the wrong way (easy done). A totally uncalled for change, and it's turned it into a close to useless function.
Also; who needs 40 models??????? It doesn't affect the operation, but surely 10 models is enough for anyone to remember which is which!
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media – The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 05-15-2011, 11:48 PM   #1605
Tabushi's Avatar
I remember that someone that posted here before was working at design area or TM Factory ...
There is any chance to know updates on the 2011 Nitro Sedan project ?
thanks
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
Team Magic G4 + EVO afm Nitro On-Road 421 08-05-2011 01:31 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Just Hobby 1/10 Onroad GP Sedan Challenge Race 2( 08 March 2009 ) justhobby Singapore R/C Racers 28 04-08-2009 10:59 AM
