Old 06-19-2009, 06:32 PM   #1
Monteman's Avatar
Trader Rating: 16 (100%+)
Default Asphalt tires
Is there such a thing? i dont mind replacing tires as a result of racing on asphalt but at $40 a pop i wouldn't mind finding something that lasts a little longer. I tried the stock tires on my NTC3+ and they melted, tried a set of Jaco Rubbers (blue) and they are as good as done. Im headed to the LHS tomorrow hoping to find something that doesnt completely melt away. Hell i think i have only run about 10-12 tanks through this thing and im down 2 sets already... or is that to be expected?
What tires is "best suited" for asphalt?
Cameron - Edmonton Canada
** Every time see someone use their first post to necro-bump a 4 year old thread all I can think is "at least they used the search function" **
Monteman is offline   Reply With Quote
Old 06-19-2009, 06:55 PM   #2
wingracer's Avatar
Trader Rating: 24 (100%+)
Put foams on it. Asphalt foam is rated by hardness. You will see numbers like 37 or 45 with higher numbers being a harder tire. Try 37's all the way around. Just be sure to get 37 fronts and 37 rears. While they have the same number, front and rear foam is different. If you want even more life, try 42 or 45.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 06-19-2009, 07:08 PM   #3
Monteman's Avatar
awesome, thanks for the quick reply.
1/12 forum ovalnator Electric On-Road 46189 Yesterday 08:13 AM
TC3 Forum Lowrider Electric On-Road 12196 10-13-2017 09:47 PM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 08:38 PM
Losi XXX-S TSR6 Electric On-Road 14329 01-26-2015 08:59 PM
What rubber tire's to run on asphalt track? BIG DADDY8 Electric On-Road 53 07-16-2010 03:39 PM
Rubber vs Foam Tires - let the battle begin! black-knight Australian Racing 385 09-01-2004 12:59 AM
Tires Foam vs. Rubber you decide! FoamDonuts Electric On-Road 81 03-10-2002 07:59 PM
