Old 06-16-2009, 07:59 PM   #1
Trader Rating: 21 (100%+)
Default STS D3R (ONLY) discusson
I know we have a thread for STS engine already. But they all are mixed with all sizes. My thread is specifically for "D3R" only.
I am thinking to buy a used JLR EVO 3 vs a new STS D3R...dont know what to do....
If you have one, can you please tell me what you think? I have recently blew my Sirion Evo 3 crank in 2 big pieces and i have less than 2 gallons...so i think expensive or name brand is not always the best...
By the way, is the JLR Evo 3 better or worse than the Sirio Evo 3???
Thanks...
xxx123 is offline   Reply With Quote
Old 06-16-2009, 08:08 PM   #2
aizenbelle's Avatar
Thanks...
Good engine! look around for pricing .
2 gallons for a Nitro engine way toooooooo much
Don't Blame it on the car when you know you cant drive
X_ray Nt_1 08
RRR WC (For sale!!)
G4+EVO
G4RS 09' (IT'S FINALLY HERE!!!!!) Serpent 733 put on hold!!
aizenbelle is offline   Reply With Quote
Old 06-16-2009, 08:08 PM   #3
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
the JL evo 3 or the 4. i've had the d3r good all around engine simple to tune but is better with a nova carb but for all out power go with the JL
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 06-16-2009, 08:37 PM   #4
Hi, why you say 2 gallons is a lot...??
My friend has a V12 over 4 gallons, still strong....
My P5X in my losi 8ight has way more than 4 gallons still idle and hold tune fine....
Old 06-16-2009, 08:42 PM   #5
wingracer's Avatar
Trader Rating: 24 (100%+)
The Piccos are the best bang for the buck motors on the planet, go with them.
Although, why buy used when new ones are so cheap?
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 06-16-2009, 08:50 PM   #6
CurveTracer's Avatar
I have both engines, the JL Evo 3 is an order of magnitude of power output across the rev range over the STS D3R. I had an RD Logics Turbo II pipe mated to my D3R and it performed well, especially with a good clutch setup. The JL Evo engine has smooth high torque through the technical sections of the race course and down the back straight. It performs best when mated to the Picco 2607 pipe.
This thread should be moved to the nitro engine zone.
"Yellow Jacket" Mugen MTX-6, Picco Torque
TeamNITRO RC Club, Lynwood, Illinois
CurveTracer is offline   Reply With Quote
Old 06-16-2009, 09:02 PM   #7
The D3R is good engine for the money. It will work better with the Novarossi cab, for the stock cab makes sure the fuel inlet (at the HSN) is tight as it will leak if it is loose.
http://www.gpm-parts.com
gpm-parts.com is offline   Reply With Quote
Old 06-16-2009, 09:32 PM   #8
i have many Novarossi Carbs, but they are for my .21 P5X, would they fit? Thanks
Old 06-16-2009, 10:28 PM   #9
no, only the .12 carb fits. The .21 Novarossi carb will only fit the .21 STS engines
Old 06-17-2009, 04:05 PM   #10
aizenbelle's Avatar
I have never seen an engine performing the same after the first gallon. I dont know if your friend runs his engine hard, just around or whatever. but after 2 gallons an engine should be rebuild or pinched and if you are a racer you should rebuild every one gallon.
X_ray Nt_1 08
RRR WC (For sale!!)
G4+EVO
Old 06-17-2009, 06:27 PM   #11
Do you know how much fuel you need to break in a RB engine?
Old 06-17-2009, 06:37 PM   #12
aizenbelle's Avatar
10 thanks did mine just fine. Please don't tell me you go through a gallon to break in an engine
X_ray Nt_1 08
RRR WC (For sale!!)
G4+EVO
Old 06-17-2009, 07:32 PM   #13
max_chen's Avatar
Send a message via MSN to max_chen Send a message via Skype™ to max_chen
Ha....Ha....
High Performance Exhaust System by SSTECH.
www.sstech-racing.com
My facebook http://www.facebook.com/#!/profile.php?id=100000783788369
APlus adjustable clutch system(ACS Clutch)
max_chen is offline   Reply With Quote
Old 06-17-2009, 07:54 PM   #14
wingracer's Avatar
Man I wish 10 thanks was all it took. Would save a lot of time and money
Team Shepherd USA
Old 06-17-2009, 08:11 PM   #15
Sometimes, 10 tanks can get your engine "broken" too.....
