Old 06-14-2009, 11:07 PM   #1
_Hier_'s Avatar
Trader Rating: 19 (100%+)
Default Reciever pack... Do you trust AA's...
Just checking in to see how many of you trust AA's in your receiver pack.
How long do you trust them for? Continous?
1hr main on a fresh set?
www.hobbyplexraceway.com
-www.windcrestwinery.com-
_Hier_ is offline   Reply With Quote
Old 06-14-2009, 11:32 PM   #2
i use good AA's in my receiver pack, and havent had a problem.
i run a fail-safe, which is a must with any nitro i guess.
i use a multimeter to check the voltage of my receiver pack before each time i run my car.
total3d is offline   Reply With Quote
Old 06-14-2009, 11:44 PM   #3
_Hier_'s Avatar
I suppose I should clarify my question a little.
Will a fresh set of AA's last in a 1 hour main... Approximately 70 minutes total??
Old 06-15-2009, 12:52 AM   #4
Send a message via ICQ to _cyclops_
2/3A cells do fine in most model cars.. if not then use AAA (tripe-A) cells.
They are available in 1000mah, which would be largely enough for a 1hour main...
_cyclops_ is offline   Reply With Quote
Old 06-15-2009, 12:57 AM   #5
freestyles's Avatar
Trader Rating: 14 (100%+)
It's a bit hard to say cause everyone uses different servo's which will all draw a different amount of amps but in general i would think it would last however i reckon you will notice your servos slowing down considerably towards the end. I personally wouldn't trust them for that period of time.
If you are going to use AA's i recommend using the 2500mah rechargeable ones from energizer. I use them for transmitters and i've never had a problem and they last a fair while
Hope that helps
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 06-15-2009, 01:18 AM   #6
M7H
M7H's Avatar
I am able to run between 1 1/2 and 2 hours on a 1400mAh pack in my 8th scale....
Serpent
M7H is offline   Reply With Quote
Old 06-15-2009, 10:01 AM   #7
_Hier_'s Avatar
thanks for your input.
Old 06-16-2009, 03:45 PM   #8
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
if you are using a FUTABA failsafe, be wary.....does not work with alkalines due to the drop off curve.....failsafe or not, battery voltage goes low..that car is Gone....
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
