Old 12-31-2003, 11:49 PM   #1
TexasRacer's Avatar
Send a message via AIM to TexasRacer
Default NTC3 centax
Is a Centax needed? I have a 2 shoe clutch drilled shoes and a set of coppers springs on it already and it seems to work greak but is the Centax alot better? I hear it is really hard to tweak it in like tighting the spring to make the clutch engage later or sooner.
TexasRacer is offline   Reply With Quote
Old 01-01-2004, 10:14 AM   #2
The Sleeper's Avatar
To answer your question, is a centax needed,,, no it isn't needed.
But if you're the type that travels and races at several different tracks then a centax would be helpful. Or if you're the type that likes to make changes on your car just the heck of it, a centax is fun to have.
As for the NTC3, adjusting a centax isn't that hard. Maybe it is easier on a belt driven car where the clutch is more exposed but still,,, you won't have to take the engine and clutch off to do any adjusting.
The Sleeper is offline   Reply With Quote
Old 01-01-2004, 11:30 AM   #3
New_Toasted's Avatar
Location: The Milkyway/Planet Earth/Europe/Sweden/Skåne/Malmö
If you have a badass engine (high performance as NovaRossi, RB etc) a Centax will help you a lot, not only because it's adjustable but also because it will last so much longer than your two shoe you got now.
New_Toasted is offline   Reply With Quote
Old 01-01-2004, 11:40 AM   #4
TexasRacer's Avatar
Well It looks like I am gonna need one then because I am the guy traveling aroung and I run a MR12. So what I really ment to ask does it help out alot.
Old 01-01-2004, 02:13 PM   #5
It helps the way that you can adjust the clutch for diffrent engines and you'll get a little more "punch" out of your engine.
Old 01-01-2004, 03:58 PM   #6
EVOLUTION's Avatar
http://www.rctech.net/forum/showthre...&goto=lastpost
EVOLUTION is offline   Reply With Quote
Old 01-01-2004, 04:30 PM   #7
TOEBSTER2's Avatar
Where can a guy get a Centax clutch?
Crookid Creations
TOEBSTER2 is offline   Reply With Quote
Old 01-01-2004, 04:44 PM   #8
At any shop that carries Serpent parts. www.rccarinternational.com seems to be a good choice..
If you like to, you can check the order number at www.mytsn.com/products and then search for 'Centax' or something..
Old 01-01-2004, 08:53 PM   #9
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
www.speedtechrc.com
Racing4Evo is offline   Reply With Quote
Old 01-01-2004, 09:46 PM   #10
Nrctc3's Avatar
Send a message via AIM to Nrctc3 Send a message via Yahoo to Nrctc3
To be honest I didn't like the centax on mine, just didn't go outta the hole like I preferred I'd stick with the 2 shoe. I have the Kawahara clutch & mounts if you wanna buy them.
Nrctc3 is offline   Reply With Quote
Old 01-01-2004, 10:57 PM   #11
sup
sup's Avatar
so, how do you guys tune the shoe type clutch? to make it engage quicker?
sup is offline   Reply With Quote
Old 01-01-2004, 11:13 PM   #12
Racing4Evo's Avatar
That is the beauty of the centax is that you can control the punch of the clutch. Just tighten down the nut and if that isn't enough for you, just switch out the spring for a harder one. Once you get the hang of it, the adjustment is a breeze. When traction conditions change you can adjust the punch of the clutch to compensate.
Old 01-02-2004, 11:41 AM   #13
Nrctc3's Avatar
Yeah it's definately a must have, I just didn't like it on my TC3 I love it on the R40 though.
Old 01-04-2004, 11:59 AM   #14
Motorman's Avatar
Problem is the centax for the NTC3 is very small, almost to small. the kawahara ones slip real bad unless you work on them alot.
Just here to give the world grief.
Motorman is offline   Reply With Quote
NIP centax for NTC3 jiml R/C Items: For Sale/Trade 0 12-23-2004 10:48 AM
WTB NTC3 BMI gen 2 chassis and centax FFR3582 R/C Items: Wanted to Buy 2 10-31-2004 03:54 PM
WTB: Centax for NTC3 and FT-NTC3 Roller FFR3582 R/C Items: Wanted to Buy 5 08-09-2004 05:39 PM
FS: KFactory Centax clutch for G4/NTC3 rodneybarrett R/C Items: For Sale/Trade 0 02-27-2004 09:02 PM
Kawahara NTC3 centax clutch ME-student R/C Items: For Sale/Trade 0 08-07-2002 06:58 PM
