Old 06-09-2009, 06:55 AM   #1
beers4evo's Avatar
Default clutch issue?
hey guys, when i accelerate off the mark, my car progresses high rpm and car doesn't move much, and if it does its very little..then I back off the throttle, and accelerate again and it picks up momentum...
Other guys cars seems to off the mark just get the car moving quick...
Now I'm wondering what could be the problem?
Is it clutch issue?
LSN needle too rich?
2-speed?
tuning?
what should I check for?
thanks!
Kyosho RRR Evo2 WC / O.S Engines / Twister Tyres / Futaba / Sanwa / Tornado
- im taking you down, im taking you to funky town!
beers4evo is offline   Reply With Quote
Old 06-09-2009, 07:13 AM   #2
mcsquish's Avatar
It may be the clutch spring nut is too tight, which won't let the clutch shoe get to the endbell. What are your clutch settings, clutch spring, and what kind of clutch?
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Never argue with an idiot, they'll just drag you down to their level and beat you with experience.
Dirt Burners Racing - R.I.P. BB / Kolors by Kropy / CEFX / One Eighth Racers
mcsquish is offline   Reply With Quote
Old 06-09-2009, 07:24 AM   #3
beers4evo's Avatar
I'm running 0.3 clutch gap, endplay i can't remember, but its enough to have the clutchbell free spin without binding, 2d flyweights, clutch spring tension is set to 0.8, stock clutch shoe (grey) and i am using kyosho rrr evo 2 car with stock clutch. thnx
Old 06-09-2009, 04:18 PM   #4
aizenbelle's Avatar
Is it clutch issue?
2-speed?
tuning?
thanks!
I would start with the clutch and 2 speed, if your clutch is engaging when you give gas than you should check your 2 speed.
Don't Blame it on the car when you know you cant drive
X_ray Nt_1 08
RRR WC (For sale!!)
G4+EVO
G4RS 09' (IT'S FINALLY HERE!!!!!) Serpent 733 put on hold!!
aizenbelle is offline   Reply With Quote
Old 06-09-2009, 05:15 PM   #5
batto's Avatar
I agree with Mcsquish, It does sound like clutch slip due to spring tension being slightly too heavy. Try backing it off and remember as much as every thing else the actual spring needs to warm up and in turn will then allow the clutch to work with some consistency. also the -3 gap may be to little as it may bind when every thing is at operating temp. I did read an article by Josh Cyrul where he suggested to run not smaller than a -45 gap so as not to have the possible binding of the shoe on the clutch bell, This gap being a sedate clutch and not more than a max of -75 for an animal clutch. I personally run -60 on my Sirio power clutches. Hope this helps you.
R , Noel
Shepherd Velox V 10 (Very Very Soon) - Novarossi powered
Futaba 4pk
Matrix tyres
Liquid Speed Fuels
www.tracksiderc.com.au
batto is offline   Reply With Quote
Xray NT1 aantonis Nitro On-Road 7523 12-12-2017 03:48 PM
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
IDM Products? rcrevolution Onroad Nitro Engine Zone 717 03-03-2013 03:52 PM
JL Racing .12 nitrodude Onroad Nitro Engine Zone 2083 05-16-2012 02:21 PM
Losi Clutch NIGHTMARE!!! motoclay Nitro Off-Road 14 10-06-2008 06:34 PM
Clutch Bell Bearing Issue 843rcguy Nitro Off-Road 18 08-22-2008 11:09 AM
