NTC3 engine question
Hello, I have a ntc3 and the current engine is in need of replacement. What would be a good .12 engine for bashing? Also, would it be worth putting a .18tz or would it just destroy the drivetrain? I have the bump starter so a pull start is not necessary. Thanks
I would say, a fast, reasonably priced engine would be novarossi NS12TS1, or JLR Red Dot. Both should be just under 200.
NTC 3 engine
Way too much torque, and the torque steer made it difficult to drive.
There are many many good fast 12 engines that will have more than enough power for the car. Shaft driven cars do suffer from torque steer if they are over powered.
You will strip out the diff gears also if the car is over powered
The engines list in the other reply will be good choices for you, and not break the bank
Thanks for the feedback guys. I also have a NTC3 and am looking at future engine replacement. I've tried a couple different engines and am currently running a SH Pro Turbo .12 (the hand made one, 41,000 rpm version) and it's "OK" but lacks some bottom end punch. For most of the tracks I run on I think I want more bottom and mid-range over a screaming top end.
A friend is running an older TOP Racing .12 which really impresses me but it's hard to find. The only one I've found is ~$250 or so from Brooklyn Hobbies.
http://brooklynhobbies.com/index.asp...OD&ProdID=1444
