Old 11-11-2009, 06:46 PM   #1471
Suspended
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
Originally Posted by trickd122 View Post
Hey DJ what color springs did you use in the rear?
DID NOT see you this weekend whats goin on
TEAM ARC USA --- TEAM POWERS USA ---- TEAM VALKARIA RC ----
rcpaintinpete is offline   Reply With Quote
Old 11-11-2009, 08:17 PM   #1472
shamu's Avatar
When assembling the diff one of my outdrives binds in the diff housing when you rotate it.I cant find what is causing this the part looks fine and I dont see any flashing in the housing.will this wear in or am I missing something?
CHARLIE SCHAUMBURG
XRAY NT1 2013 / FORDHAM HOBBIES / HOT RACE TYRES/ Port Jervis NY Onroad Raceway/ FLOYD BENNET RACEWAY / McPappy Racing /
shamu is offline   Reply With Quote
Old 11-11-2009, 08:58 PM   #1473
quietstorm76's Avatar
Make sure the center screw that holds the bevel gear is not backed out and also thread lock this screw. it will vibrate loose and bind like hell if you don't.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 11-11-2009, 09:26 PM   #1474
shamu's Avatar
the diff is not together yet ,the bevel gear has not been attached.I insert the outdrive into the housing and when you rotate it, it starts to spin freely then binds.this is only on one half the other half is fine.
CHARLIE SCHAUMBURG
Old 11-12-2009, 12:30 AM   #1475
trickd122's Avatar
Yeah, I had some stuff that I had to take care of and also my homie Wayne wasn't going to make it either. I figured that you guys would represent us well and you did so. My presence was not neede after all.
On a second note I heard the track was alot of fun. The recent changes made the track more High speed and flowing.....funny though the laptimes are basically the same
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 11-12-2009, 12:34 AM   #1476
trickd122's Avatar
During the manufacturing process sometimes there is excess material left over inside the diff case. This is NOT a problem however, you can use an xacto knife of something of sorts to remove or just run it in.
Old 11-12-2009, 12:05 PM   #1477
and23's Avatar
Default News 733!!!
http://www.unoadieci.com/prodotto.cf...0-b3f820b2601a
Andrea
Serpent 733
Max RR3
and23 is offline   Reply With Quote
Old 11-12-2009, 01:30 PM   #1478
Suspended
Originally Posted by and23 View Post
what are the stubs for?
Old 11-12-2009, 02:42 PM   #1479
Team Kamikaze's Avatar
The picture shown are 903257 Uprights for the 966, not for the 733.
Here: http://serpent.com/product/903257
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 11-12-2009, 03:12 PM   #1480
It won't just spin freely because of the x-ring that goes onto the outdrive once it's inserted. You checked for flashing in the diff housing? Tried switching the outdrive to the other side?
Primary Weapon: ?
Secondary Weapon: ?
Old 11-12-2009, 05:32 PM   #1481
Suspended
Default great deal on bodies
HEY GUYS have 2 733 bodies for sale
one is cut and fitted the other is not
and one 966 body fitted
60$ each or 150$ for all 3 bodies
yes these were DJ's bodies
we have changed up his paint schem
and will not be using them
Old 11-12-2009, 06:26 PM   #1482
shamu's Avatar
There is no flashing in the housing, it must be defective because the outdrive spins freely in the other housings,i'll have to order a new housing bummer!this is holding up my build.Thanks for your help anyway.
CHARLIE SCHAUMBURG
Old 11-14-2009, 07:10 AM   #1483
are you saying that you can't turn the outdrive at all? Is it stuck? It can be a little tight and be ok.
Primary Weapon: ?
Secondary Weapon: ?
Old 11-14-2009, 08:32 AM   #1484
rcpanama's Avatar
Default Blitz
Hi, does anyone knows what is the position in front of the center post from body position in the Blitz Altis
RCPANAMA
Serpent 720 Novarossi Murnam 12 + 3CT Full Ceramic & 2630 pipe. 733 Novarossi Murnam 12 + 3SCT full ceramic & 2660 pipe , Nomadio Sensor, Xceed Lipo, Xceed Tires Japan Foam
rcpanama is offline   Reply With Quote
Old 11-14-2009, 11:56 AM   #1485
Serpent-Dan's Avatar
RCPANAMA
27.5mm sits right at the center of the wheel wells. I run mine at 27mm
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
