Old 10-09-2009, 10:30 AM   #1321
G87z's Avatar
Originally Posted by Pattojnr View Post
yep i used the long springs for rear also on my 720
This may be a dumb question, but what do the long springs offer over the short springs on the rear of the 733?
Thanks!
Team Shepherd USA / Picco Engines / Sanwa / Matrix Tires / Byrons Fuel / SRC
G87z is offline   Reply With Quote
Old 10-09-2009, 11:39 AM   #1322
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
the longer springs make the rear more stable and it doesnt bottom out as much.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 10-09-2009, 11:40 AM   #1323
trickd122's Avatar
Thanks!
Better Ride height adjustment and a more progressive feel.
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 10-09-2009, 01:24 PM   #1324
Originally Posted by dj apolaro View Post
Hi guys,
I
Front-
-2 droop, this helped with the bump in front of the drivers stand trying to make the right hand turn.
5 ride height
short car
2mm of actual caster, 4mm of clips
camber left 3 ( I know this seems weird, but it was needed to keep the tire from coning the wrong way, due to the hard right turns)
camber right 1.5
35 shore - twister tires
-1 toe
198 width
blue springs
layed down
900 wt
1 hole piston
spool (for now use the heaviest oil you can get)
Standard hex
2.2mm front sway bar. This is the one step softer than the stock
Roll center pins all the way up
Rear-
2.5 droop
6 ride height
short car
4 left camber
3.25 right camber
camber link is inside on tower all the way down and 2mm and inner on hub
40 shore - twister tires
2 toe
199 width
pink springs (I use long rear springs)
layed down
900wt
2 hole piston
150 diff oil ( I think anything from 100 to 150 will work good. 120 would be best I think)
Standard hex
softest sway bar setting
Roll center pins all the way down
DJ Apolaro
Hi guys / DJ - quick question re shims on the rear camber link. When you say 2mm of shims does this mean the standard orange cone washer that comes with the kit or are you adding 2mm of shims in addition to this?
Many Thanks
Gap Man is offline   Reply With Quote
Old 10-09-2009, 02:19 PM   #1325
dj apolaro's Avatar
Yes, they are the stock shims.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 10-09-2009, 04:06 PM   #1326
jca2000au's Avatar
Trader Rating: 9 (91%+)
Default 733 manual
anyone know where can i download manual for 733? I went to sepent's site but i couldn't open it but all other are ok.
http://www.serpentchina.com/product/804000/downloads/
jca2000au is offline   Reply With Quote
Old 10-09-2009, 05:27 PM   #1327
dj apolaro's Avatar
I was able to open it. It is in PDF format. I tried to post here, but it is too big.
Sorry, maybe you could try again....
If you email me I could reply and send it in an email attachment.
[email protected]
DJ Apolaro
Old 10-09-2009, 07:03 PM   #1328
Alex Siddique's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Alex Siddique
its a zip file .
No Fucker's Taking my money O/s OR local :) :)
Alex Siddique is offline   Reply With Quote
Old 10-09-2009, 11:04 PM   #1329
jca2000au's Avatar
Originally Posted by ccrcraceway View Post
its a zip file .
Thank you.
Old 10-10-2009, 10:55 AM   #1330
musti72's Avatar
Hi DJ, I remember that you use MRT transponders and wanted to ask if they fit to 733 without any problems. Thanks.
Mustafa Alp
http://www.aytemizhobi.com
Turkish shop for: Serpent, Xceed, Sweep Racing, MyLaps
musti72 is offline   Reply With Quote
Old 10-10-2009, 11:13 AM   #1331
dj apolaro's Avatar
Not on the bottum, But I modified the 966 graphite transponder holder and use in the top by the servo. There are 2 screws and I put it there.
DJ Apolaro
Old 10-10-2009, 11:17 AM   #1332
Team Kamikaze's Avatar
MRT transponder are thicker than the AMB transponder, it will not fit under the fuel tank like the AMB does, you have to shim the fuel tank at least 2mm higher in order for the MRT to fit or just mount it to the side of the receiver cover or you can fabricate a transponder mount and mount it on top of the steering servo mount which have 2 holes ready for a transponder mount.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 10-10-2009, 11:23 AM   #1333
i made one out of lexan i will post a pic later if you like
Old 10-10-2009, 11:30 AM   #1334
musti72's Avatar
Thanks for the fast replies.
Mustafa Alp
Old 10-10-2009, 12:11 PM   #1335
Default lexan mount
from spare body lexan
Serpent 733 1/10 200mm touring-img00033.jpg
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
