Old 09-15-2009, 07:40 AM   #1156
NitroWD's Avatar
Default heavy car?
hi guys,
just wondering what's the weight of yr 733?
mine weighs a whopping 1815g! race ready (shell, 58mm tires, no fuel, bls451 servos, 1450mah LiFe battery). body shell weighs 105g, (normal or heavy?)
how do you guys get yr car to weight about 1750g or less?
using low profile servos shld reduce significantly and maybe a smaller battery?
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 09-15-2009, 09:07 AM   #1157
rcpanama's Avatar
Originally Posted by NitroWD View Post
hi guys,
Low Profile Servos (two), Lipo Battery 1770
RCPANAMA
Serpent 720 Novarossi Murnam 12 + 3CT Full Ceramic & 2630 pipe. 733 Novarossi Murnam 12 + 3SCT full ceramic & 2660 pipe , Nomadio Sensor, Xceed Lipo, Xceed Tires Japan Foam
rcpanama is offline   Reply With Quote
Old 09-15-2009, 09:10 AM   #1158
quietstorm76's Avatar
hi guys,
I'm at 1793g race ready with 56/58 tires(jaco). custom body weighing 101g
Futaba 9452 servos, Nimh batt.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 09-15-2009, 09:19 AM   #1159
DayDAY's Avatar
Well, it seems like most of you didn't have this problem on this one-way bearing.. then I must admit that I am not having very good luck.... So I will take your advises and tube the bearing and test run again.
Thanks to all of you on recommanding different type of lube, will check in HK (where I'm from) and see which is popular here.
DayDAY is offline   Reply With Quote
Old 09-15-2009, 09:26 AM   #1160
M7H
M7H's Avatar
I know they did change the inside of these bearings, because now (as you can also see in your pictures) the inside is red coloured. This used to be black.
I to have a new red coloured one way as spare in my box, but haven't used it yet.
at least thanks for the warning, I will check it regularly when I will start using it...
Serpent
M7H is offline   Reply With Quote
Old 09-15-2009, 12:09 PM   #1161
spurgear's Avatar
Send a message via MSN to spurgear
hi guys,
Im at 1750g with no body. Just matrix tires. Xceed lipo and brushless futaba servos.
Serpent 733 trinirc.com
Novarossi Plus 12-3CT Murnan Modified Full Ceramic Edition
Novarossi EFRA 2630 exhaust with medium header
Futaba 3PK HRS with Digital Servos/ JLR Starter Box
East Civic 200mm
spurgear is offline   Reply With Quote
Old 09-15-2009, 12:11 PM   #1162
howardns's Avatar
hi guys,
race ready xceed lite rims 62/60 xceed lipo with regulator, stratus 96g, futaba 9451, total 1740g, big change is lipo 55g less weight
Serpent Cobra GT
Homestead RC Raceway
howardns is offline   Reply With Quote
Old 09-15-2009, 12:57 PM   #1163
dj apolaro's Avatar
At the Nats I was 1740 with race ready car. Twister tires and Airtronics radio gear. I do not use the receiver box cover though.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 09-15-2009, 02:01 PM   #1164
CIMRI's Avatar
Hi,
- low profile servos.(w. short cabels)
- upper deck titanium screws
- futaba recevier
- lipo
- body 102 gr.
- light weight exeed tires 58/60
Total 1710 gr.
Serpent 733 1/10 200mm touring-733weight.jpg
CIMRI is offline   Reply With Quote
Old 09-15-2009, 02:10 PM   #1165
Send a message via Yahoo to sheeley
I just got a oneway from serpent and it has the red inside and it is dry. First oneway I got with no grease in it.
sheeley is offline   Reply With Quote
Old 09-15-2009, 02:14 PM   #1166
dj apolaro's Avatar
With the new one-ways I use the associated diff ball grease. The clear stuff. We have found this to work pretty well. Lube it about ever hour of use. For the first time give it a good layer. I will say that Serpent America has an optional one-way that the aluminium part is orange. I think these last longer, however they are not needed. Just keep the stock one lubed. Also not sure how much the optional one cost, since I know that is the next question.
DJ Apolaro
Old 09-15-2009, 02:40 PM   #1167
Team Kamikaze's Avatar
DJ Apolaro
The Adaptor 2-speed / oneway pro / orange..is US$28.70 if in stock.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 09-15-2009, 03:31 PM   #1168
M7H
M7H's Avatar
So don't forget to lube it before first usage...
Isn't any form of grease actually to "sticky" for the needles?
Or is the grease you are talking about more a sort of an oil?
And doesn't the one way lube work good enough?, or do you need to relube it to often then.
I know the one way lube works perfect one the "older" type of one ways....
Serpent
Old 09-15-2009, 04:14 PM   #1169
dj apolaro's Avatar
On the new ones the fit is tigher and the oil just breaks down from the heat. It also depends on the air temps. In Florida the temps are very high and humid. The grease has been working well, but just for the tight fit one-ways. The older ones work great with the normal oil and same for the option ones.
DJ Apolaro
Old 09-15-2009, 04:19 PM   #1170
I have been using the serpent oneway lube with no problems in the past but since the serpent drivers are using the associated grease I'm ordering some and will use it with this new oneway. All the oneways I have got in the past came with a dab of grease in them and I just keep lubing them with the oneway lube before the next race.
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
