Old 09-10-2009, 08:50 PM   #1111
Originally Posted by dj apolaro View Post
Just for you Mr Wayne; The traction was super high. I would not use this set-up normally. Too stiff in the front, but I was tring to make the car transition really fast for the chicanes.
Front
droop 0
stock sway bar
green springs layed down
2 hole piston 1,000 wt oil
car short and 2mm of actual caster or 4mm of clips (same thing)
-1 toe on each side
1.75 left and 1.5 right camber
4 ride height
37 shore 56mm - Twister (non light weight)
198 width
Rear
droop 3
2.3mm sway bar inner position
pink springs 2nd hole from bottom
3 hole piston 900wt oil
car short
+2 toe on each side
3.25 left camber and 2.75 right camber
5 ride height
camber link inner bottom on tower and inner on hub with 1mm shim
2 back screw out for more flex on the bottum of chassis. The ones that hold the motor mount thingy.
40 shore 58mm Twister (non light weight)
199 width
For normal traction I would use blue front spings, red rear springs and 2.5 rear toe. Also maybe flip the shock pistons front to rear. Just switch the spings, the shocks themselves are the same size.
If I missed anything, just ask. I leave out of town in the morning. Will be back Monday night. Will reply then.
Later,
DJ Apolaro
That's why we love you so much
p1pioneer is offline   Reply With Quote
Old 09-10-2009, 08:56 PM   #1112
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
Default hey
hey Wayne I guess this is considered cyber stalking you better get back to work on that 733 race day is 10 days away no time to waste it takes alot of work to get that new car around the track in one piece Peter
Speedypeterb is offline   Reply With Quote
Old 09-10-2009, 08:56 PM   #1113
GMartinez's Avatar
Trader Rating: 85 (100%+)
P1 RU you going to the state race @ Homestead would be nice to see you wheeling again
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 09-10-2009, 09:00 PM   #1114
George i'm not missing that for nothing.And for you peter you'll see it make it around the track,as a matter of fact there will be a few just for you.
Old 09-10-2009, 09:03 PM   #1115
And stop stalking me Peter
Old 09-10-2009, 09:09 PM   #1116
Default hey
alright you just had to ask goodnight hey George
Old 09-11-2009, 05:01 AM   #1117
impalabob64's Avatar
Send a message via AIM to impalabob64
Default Sup Wayne
I will be there i will be following close behind to make sure you get around the track nice smooth, oh yah better be damit fast, G4RS 09 maybe can help you out with that joke guys see you guys on Sat.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 09-11-2009, 06:18 AM   #1118
trickd122's Avatar
Bobby, looks like you already know you have no choice but to be bringing up the rear Seriously this wil be a great race.
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 09-11-2009, 06:56 AM   #1119
trickd122's Avatar
Default Weight transfer
Why is it that I never see anyone tweak their cars with fuel in the tank. Is there a technical reason for this practice? With less fuel less I know less weight gets transfered because the weight of the car is reduced but the car's center of gravity never changes neither does the roll axis, so why not tweak the car with the fuel (maybe 1/2 tank) as a compromise. Wouldn't that gave a more neutral handling car throughtout it's entire run?
Just a thought
Old 09-11-2009, 06:58 AM   #1120
Default Lurking,& Waiting
You know i just sit back an wait you know one bobble then im all over yah. It will good to see you guys again its been awhile.
RoninRc.com
Basher BT-4
Old 09-11-2009, 07:08 AM   #1121
Trader Rating: 4 (83%+)
Just a thought
Tino stick to painting please ......
Roniel_R is offline   Reply With Quote
Old 09-11-2009, 07:22 AM   #1122
trickd122's Avatar
Waddup... BTW congrats!!!!
man can't a guy get a break..lol
Old 09-11-2009, 09:51 AM   #1123
Serpent-Dan's Avatar
R.I.P to all the World Trade Center victims as well as the other two flights gone but never forgotten.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 09-11-2009, 10:14 AM   #1124
Default Plus 1
Plus 1
RoninRc.com
Basher BT-4
Old 09-11-2009, 02:43 PM   #1125
Send a message via Yahoo to noelcleofe17
Just wanted to ask if this new 733 will be better than the MTX4R?
noelcleofe17 is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
