Old 09-09-2009, 08:45 AM   #1096
dj apolaro's Avatar
I think a 53 and a 62 on first would be a great option for gears. Just to have more fine tuning. Not that it is needed, but would be great.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 09-09-2009, 10:02 AM   #1097
Originally Posted by NitroWD View Post
anyone had their front and rear diffs leaking?
when i had mine assembled; they were fine, no leaks. however after i run the car 2 days later, it started leaking. i'm sure that they were not over filled.
other than using rtv, any other fixes?
btw, anyone that has yet to assemble their kits, could do a favour to measure the size of the diff oring?
just make sure you do not strip or break the bit of plastic your screws go into on the diff... once that happens, it will leak...
the solution is to change to the v2 diff housing.....
katze is offline   Reply With Quote
Old 09-09-2009, 10:05 AM   #1098
trickd122's Avatar
Originally Posted by quietstorm76 View Post
We didn't let him go. From what I understand he only signed a two race deal. Bumod and the Worlds.
It's really sad to see him go, on the brighter side we still have drivers here in the US that are very highly competitive. Serpent seems to be recruiting new talent and IMO a great addition would be Chris Tosolini. I personally would rather see toso joining our team as opposed to having Jiles for the worlds. (Hint Hint SerpentUSA)
However in this day, age and economy it's ALL about money. Had it been me I'd have done the same thing. However I honestly believe though that there are still drivers who have loyalty regardless of financial gain eg. DJ, Paolo, Swagger, Collari etc. No love lost but I feel kinda betrayed!!!!!
Just my $0.00 cents, recession guys can't afford the usual $0.02 cents sorry
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 09-09-2009, 10:06 AM   #1099
Originally Posted by howardns View Post
I had the same problem and solved it by changing to a shorter collet between engine and flywheel.
I did the same.
GHN
ghn-sp is offline   Reply With Quote
Old 09-09-2009, 10:55 AM   #1100
quietstorm76's Avatar
Originally Posted by Pattojnr View Post
how do you find the newer internal gear ratio ? improved accel, and is top end still good as 720 ? cheers.
With stock gears and my 353 tuned the 733 felt a little slower on top than my 720 but not by much. Out of the corners the 733 wins all day long.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 09-09-2009, 11:03 AM   #1101
dj apolaro's Avatar
I run the same motor. I use 17/61 and 23/55. With this combo you will get good bottom, mid and top. I typically use a 2630 with short header and 16%. Run time is good and power is great. Adjust the clutch based on traction. For low bite also use a 60 instead of 61 spur. Clutch for low bite use .4 to .5 gap. For high bite use .7 to .8 gap.
Hope this helps. Try it the next time at the track.
DJ Apolaro
Old 09-09-2009, 11:08 AM   #1102
Hey Dj, can you post your setup from the Nats when you get a chance? I'd like to see how far off my setup is from yours.
Primary Weapon: ?
Secondary Weapon: ?
Old 09-09-2009, 11:16 AM   #1103
DJ Apolaro
I will try that thanks. Next stop will be The Fort in October.
Primary Weapon: ?
Secondary Weapon: ?
Old 09-09-2009, 11:26 AM   #1104
dj apolaro's Avatar
I tried to upload here the setup from the serpent editable one, but it did not work. Check the serpent.com site in a few days. If it is not up then let me know and I will type it out here.
DJ Apolaro
Old 09-09-2009, 11:51 AM   #1105
DJ Apolaro
aight cool
Primary Weapon: ?
Secondary Weapon: ?
Old 09-09-2009, 02:21 PM   #1106
spurgear's Avatar
Send a message via MSN to spurgear
i see the editable sheet listed today on serpent.com
Anyone ever try the stock setup as listed on the site?
Serpent 733 trinirc.com
Novarossi Plus 12-3CT Murnan Modified Full Ceramic Edition
Novarossi EFRA 2630 exhaust with medium header
Futaba 3PK HRS with Digital Servos/ JLR Starter Box
East Civic 200mm
spurgear is offline   Reply With Quote
Old 09-09-2009, 03:00 PM   #1107
DJ Apolaro
I say type it out.what's wrong DJ fingers tired from the weekend?
p1pioneer is offline   Reply With Quote
Old 09-09-2009, 08:34 PM   #1108
dj apolaro's Avatar
Just for you Mr Wayne; The traction was super high. I would not use this set-up normally. Too stiff in the front, but I was tring to make the car transition really fast for the chicanes.
Front
droop 0
stock sway bar
green springs layed down
2 hole piston 1,000 wt oil
car short and 2mm of actual caster or 4mm of clips (same thing)
-1 toe on each side
1.75 left and 1.5 right camber
4 ride height
37 shore 56mm - Twister (non light weight)
198 width
Rear
droop 3
2.3mm sway bar inner position
pink springs 2nd hole from bottom
3 hole piston 900wt oil
car short
+2 toe on each side
3.25 left camber and 2.75 right camber
5 ride height
camber link inner bottom on tower and inner on hub with 1mm shim
2 back screw out for more flex on the bottum of chassis. The ones that hold the motor mount thingy.
40 shore 58mm Twister (non light weight)
199 width
For normal traction I would use blue front spings, red rear springs and 2.5 rear toe. Also maybe flip the shock pistons front to rear. Just switch the spings, the shocks themselves are the same size.
If I missed anything, just ask. I leave out of town in the morning. Will be back Monday night. Will reply then.
Later,
DJ Apolaro
Old 09-10-2009, 06:13 AM   #1109
trickd122's Avatar
Front
droop 0
stock sway bar
-1 toe on each side
4 ride height
198 width
Rear
droop 3
car short
+2 toe on each side
5 ride height
199 width
Later,
DJ Apolaro
What Body did you end up using?
thanks
Old 09-10-2009, 08:43 AM   #1110
Front
droop 0
stock sway bar
-1 toe on each side
4 ride height
198 width
Rear
droop 3
car short
+2 toe on each side
5 ride height
199 width
Later,
DJ Apolaro
Hi DJ
what diff oil u using on such high grip track, and what do u recomend for med to low grip track, thanks
ck
ck960 is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
