Old 09-03-2009, 11:56 AM   #1051
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Originally Posted by RevMaxx View Post
i believe he means if you use softer rear tire, it will wear out faster resulting in eventually smaller rear tires than front later in your run...
bigger front tire diameter than rear results in front wheel drive.
If the front tire is bigger, then the front tire is turning slower than the rear tire for every rpm. If that happens, wouldn't the rear tire be pushing on the front tire? Hence, rear wheel drive? Please explain.
YR4Dude is offline   Reply With Quote
Old 09-03-2009, 01:51 PM   #1052
QuiXoTic_NL's Avatar
There is no center differential, so the speed at which the front and rear axle rotate relative to another is fixed. Hence, when the front tires are larger than the rear tires, the front tires will try to travel a larger distance than the rear tires. The front tires are pulling, so front wheel drive.
QuiXoTic_NL is offline   Reply With Quote
Old 09-03-2009, 02:19 PM   #1053
rcpanama's Avatar
Thumbs up
This is what I love about this forum, with Dj, and this explanation, now I really can understand the reason about tires split, tire softeners, etc., sometimes is very difficult to do chances, if one canít understand the principal behind it.
RCPANAMA
Serpent 720 Novarossi Murnam 12 + 3CT Full Ceramic & 2630 pipe. 733 Novarossi Murnam 12 + 3SCT full ceramic & 2660 pipe , Nomadio Sensor, Xceed Lipo, Xceed Tires Japan Foam
rcpanama is offline   Reply With Quote
Old 09-03-2009, 02:50 PM   #1054
YR4Dude's Avatar
Okay, I see it now. Both front and rear tire turn at the same rpm regardless of its diameters. Since the front is bigger, the front travels more for every revolution than the rear does. So thats where you get the FWD.
Thanks.
My current setup is with a stiffer sway up front and 38shore front and rear at 60mm with no split in diam. I'm getting good turn in at the start of the turn and good traction exiting the turn. Shock and shock settings are still stock.
All credit goes to Sam at Kamikaze for helping me dial in this set-up. Nigel deserves credit too. He set-up my clutch.
Old 09-04-2009, 06:19 AM   #1055
shawn01's Avatar
Thanks to Serpent America I wrote them an email about the tank and flyweights, giving them my mailing address and where I purchased the car. 3 days later they sent me the replacement parts. Awesome customer service and support. Great job Serpent America!
shawn01 is offline   Reply With Quote
Old 09-04-2009, 10:10 AM   #1056
and23's Avatar
Talking Great 733!!!
Finally is arrived my Serpent 733...
and23 is offline   Reply With Quote
Old 09-04-2009, 01:48 PM   #1057
Gonzo RR's Avatar
+1
Xray NT1 '08 /'09 EC LRP12R / Serpent 720 '08 RB Concept V12, R3 RB mods, V12 Rody, Matrix RW / Serpent 733, 733TE RB T9 / EA RC8T OS .21 Vspec speed tuned / Kyosho Inferno GT, GT2 / EA SC10 / Serpent Cobra GT coming soon!
Gonzo RR is offline   Reply With Quote
Old 09-04-2009, 04:07 PM   #1058
Smile Serpent 733 Ceramic Bearings
Hey guys
We JUST released our Ceramic Ball Bearing kit for the Serpent 733. Check them out!
ACER Racing: the Fastest, Smoothest, Lightest & HARDEST BALLS in the INDUSTRY.
acerracing is offline   Reply With Quote
Old 09-05-2009, 08:08 AM   #1059
howardns's Avatar
i just got the exceed lipo and regulator and where do you mount the regulator ? , i saw it above the battery below the radio tray and on the tray also.
Serpent Cobra GT
Homestead RC Raceway
howardns is offline   Reply With Quote
Old 09-05-2009, 08:17 AM   #1060
rcpanama's Avatar
I have it, in top of the radio Tray, in the Pipe side, where the side belt is, I install it with double tape, clean the area and the bottom of the regulator very good with alcohol, and it is working ok.
RCPANAMA
Old 09-05-2009, 08:19 AM   #1061
rcpanama's Avatar
RCPANAMA
I don t use a switch, only direct cable connection
Old 09-05-2009, 09:15 AM   #1062
NitroWD's Avatar
Default new diff housing v2?
hi guys, how do i tell the new diff housing from the old one? since they've got the same part number?
804174
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 09-05-2009, 06:55 PM   #1063
804174
usually it will say revised
p1pioneer is offline   Reply With Quote
Old 09-06-2009, 01:46 AM   #1064
and23's Avatar
Default Some problem to build Serpent 733
Hi, I have different problem to assemble the new kit Serpent 733, for example:
- the front belt crawls with the ackerman;
- and the front geardiff don't move good...
Moreover the manual shows that there are 5mm of spacer-set caster to right up and 3mm of spacer-set caster to left up, this is correct???...
Old 09-06-2009, 02:37 AM   #1065
Pattojnr's Avatar
Trader Rating: 19 (100%+)
firstly caster should be the same left and right. so set it evenly. what you end up with will be determinded by the track conditions.
the front belt does run on the steering , but it isnt a huge problem, relieve some plastic from where it is touching, this is what i did.
and lastly, the diffs will loosen up after running them for 10 or 15 mins.
hope this helps
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
