Old 08-29-2009, 05:07 PM   #1021
howardns's Avatar
i ran the 733 for the first time today and i am impressed ! traction was low/ medium and i used DJ 's setup to start. only change i made was to use some older yellow long springs and as DJ said on bumpy / smooth track the car liked this change. the car is the easiest rolling car i have ever had. i used the new ( reverse flyweights) .4 gap 1.2 clutch tension .2 end gap with a plus12 and the opperation was flawless allowing the engine to rev-up better than ever. i ran better lap times than before at equal traction. i cannot wait to go run again
Serpent Cobra GT
Homestead RC Raceway
howardns is offline   Reply With Quote
Old 08-29-2009, 05:50 PM   #1022
rcpanama's Avatar
Originally Posted by dj apolaro View Post
when you run a softer front the tire wear is more even through your run. It also gives more steering. Therefore when you run a harder tire in the front the steering is less and the rear tires wear faster. This creates more rear tire wear and gives the car front whell drive.
Hope this helps.
DJ Apolaro
Thanks Dj, it makes sense, but now that say it
Serpent 720 Novarossi Murnam 12 + 3CT Full Ceramic & 2630 pipe. 733 Novarossi Murnam 12 + 3SCT full ceramic & 2660 pipe , Nomadio Sensor, Xceed Lipo, Xceed Tires Japan Foam
rcpanama is offline   Reply With Quote
Old 08-30-2009, 12:35 PM   #1023
Default Serpent fuel tank
Hi Chaps,
Hinge point on my 733 fuel tank has broken, does anyone no of any dealers that have the version 2, tank in stock who will ship to the UK.
Thanks.
fezz is offline   Reply With Quote
Old 08-30-2009, 06:13 PM   #1024
Joey4875's Avatar
Well today I was testing out the new tank and I had a problem again LEAKING AGAIN THE HINGE IS FINE NOW IT LEAKS OUT THE CAP And now I got to find one before Nats
Xray,Hudy,RC America
Joey4875 is offline   Reply With Quote
Old 08-30-2009, 08:15 PM   #1025
Pattojnr's Avatar
Trader Rating: 19 (100%+)
tank lids are the same as 720/966, so try a new lid. also give it time to settle in and seal.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 08-30-2009, 10:49 PM   #1026
Joey, leaving tomorrow for the Nats. We have plenty of tanks don't worry. Anyway, the new ones work fine, the rubber just need to settle in. Put a rubber band to hold the cap down for a few hours. This will accelerate the settle in process. Is the same cap as the 966, so there is no reason why it should not work
RCtarget, Capricorn, Novarossi, Maxima MX Fuel, Matrix, Xtreme Aero, Avid, Ko Propo, Veytrex Lab, Blast RC, PMR
Paolo M is offline   Reply With Quote
Old 08-31-2009, 12:01 AM   #1027
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I was just about to switch over to the 733..... Oh well.
Paolo: See you in Ohio
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 08-31-2009, 05:08 AM   #1028
Joey4875's Avatar
I was told to do that did it last night. When I get home later I will let you know if it worked. Thanks Paolo see you in a couple of days
Old 08-31-2009, 09:20 PM   #1029
Trader Rating: 40 (100%+)
Default chassis #2
Serpent 733 1/10 200mm touring-pictures-522.jpg   Serpent 733 1/10 200mm touring-pictures-544.jpg   Serpent 733 1/10 200mm touring-pictures-539.jpg   Serpent 733 1/10 200mm touring-pictures-531.jpg   Serpent 733 1/10 200mm touring-pictures-533.jpg
Got the grip is offline   Reply With Quote
Old 08-31-2009, 10:00 PM   #1030
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
yeah right
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 09-01-2009, 01:36 AM   #1031
spurgear's Avatar
Send a message via MSN to spurgear
Originally Posted by Got the grip View Post
That is some crazy custom mods!
Serpent 733 trinirc.com
Novarossi Plus 12-3CT Murnan Modified Full Ceramic Edition
Novarossi EFRA 2630 exhaust with medium header
Futaba 3PK HRS with Digital Servos/ JLR Starter Box
East Civic 200mm
spurgear is offline   Reply With Quote
Old 09-01-2009, 01:55 AM   #1032
Send a message via ICQ to _cyclops_
Holie smokes! That's amazing!
_cyclops_ is offline   Reply With Quote
Old 09-01-2009, 02:15 AM   #1033
RevMaxx's Avatar
Send a message via MSN to RevMaxx
he'll definitely need weights to make the complete kit legal...
RevMaxx is offline   Reply With Quote
Old 09-01-2009, 03:06 AM   #1034
M7H
M7H's Avatar
Always nice to see the mods you make on cars, but do they give a performance advantage?, and in this particular case, how about the heat generated by the engine, because fibre carbon or aluminium... that's quite a difference.....
Serpent
M7H is offline   Reply With Quote
Old 09-01-2009, 10:18 AM   #1035
yogii's Avatar
Default Looking for Centax Clutch parts
I'm looking for Serpent Vector Clutch parts to match up to another car.
yogii is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
