Old 08-25-2009, 12:14 PM   #976
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Originally Posted by trickd122 View Post
Link
http://www.rcmaxpower.com/en/product...e.asp?idsub=22
Has anyone used this pipe on the 733 with the matched manifold, mine touches the linkage
I had the same issue so I went back to my 2602 pipe
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 08-25-2009, 01:06 PM   #977
trickd122's Avatar
The pipe is really very NICE!!
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 08-25-2009, 01:45 PM   #978
serpentamerica's Avatar
Hi Guys, good news. Replacement tanks are in. Please call us to arrange the shipment
Facebook: http://www.facebook.com/pages/Miami-FL/Serpent-America/120322987992068
www.serpentamerica.com
e-mail: [email protected]
telf: 1-305-677-3253
serpentamerica is offline   Reply With Quote
Old 08-25-2009, 06:51 PM   #979
I just wanted to discuss the clutch issue in more detail if anyone had a minute or two...
I appear to have the clutch shoes that were drilled on the wrong side as well. I have run the clutch with the concave side towards the flywheel but I do not like the amount of delay in the clutch engage time. If I understand a previous poster correctly, I can put the concave side out so that the trailing end of the shoe is towards the back when the flywheel spins counter clockwise. I know that is a mouth-full. I dont know how to explain it any better so you have my apologies.
Serpent America, was this a production issue? Kind of strange due to the fact that the clutch was unchanged betweent he 720 and 733.
kellhound2007 is offline   Reply With Quote
Old 08-25-2009, 07:00 PM   #980
You could always try a short novarossi header
Old 08-25-2009, 07:06 PM   #981
Default fly weights
You can contact serpent america for replacements or if you have a local dealer you can purchase a set.
Old 08-25-2009, 07:10 PM   #982
Gael L's Avatar
Ok so I finally got the chance to run my 733 at the track today with a basic set up. I did notice that my tank is busted on the right side but it also was spitting fuel out through the cap? Other than that the car was on rails I couldn't believe the way it was running. Better than my 720 ran. Great car just can't wait for the replacement tank need it yesterday.
Dan.
Did you run at Floyd? I got a chance to run at Chaplin on Sunday and the car is pretty close to where I want it. I am 2 tenths faster then I was with the 720. I got a good high traction setup but I am still looking for the right balance on low traction.
Gael
Gael L is offline   Reply With Quote
Old 08-25-2009, 07:25 PM   #983
Originally Posted by the_geeky View Post
Of course you will have to contact RC MUSHROOM, that is what you get for not supporting your LHS, hope you learn a valuable lesson.
well i live in canada in toronto, and no local dealers wanna carry serpent here, so i am stuck ordering else where, wish there were dealers here, i always had serpent since the days of impulse,
skidoos is offline   Reply With Quote
Old 08-26-2009, 06:22 AM   #984
spurgear's Avatar
Send a message via MSN to spurgear
ever since i assembled the diffs its continously leaking diff oil. Is it possible that i over filled it? I filled to the mark shown in the diagram. Im thinking to refill with the gears inside just above the shafts?
Serpent 733 trinirc.com
Novarossi Plus 12-3CT Murnan Modified Full Ceramic Edition
Novarossi EFRA 2630 exhaust with medium header
Futaba 3PK HRS with Digital Servos/ JLR Starter Box
East Civic 200mm
spurgear is offline   Reply With Quote
Old 08-26-2009, 06:26 AM   #985
~McSmooth~'s Avatar
Mine do the same thing the first couple of runs after I build them.
Here's a nice item that help with it, though. You can get it through Grainger.
http://www.permatex.com/products/Aut...et_Maker_b.htm
After building the diffs, put a bead of this around the seal and let dry.
DeSoto Racing * Franchise * Pro-One * Team Scream * Power Push * Team Ass
Badly influencing a new generation of racers!
~McSmooth~ is offline   Reply With Quote
Old 08-26-2009, 06:30 AM   #986
With my 720 diffs i used high temp rtv silicone around the screws and the out drives and it worked well. You can get that from any autorparts store.
Jean L.
sponsored by my paycheck.
Maxx is offline   Reply With Quote
Old 08-26-2009, 09:00 AM   #987
shawn01's Avatar
Mine were leaking when I first put the kit together. I took the front and rear end apart, gave it a few more REALLY HARD turns, and no more leaking.
shawn01 is offline   Reply With Quote
Old 08-26-2009, 09:53 AM   #988
Gael
Hey Gael, yes I ran at Floyd late monday I ran 40's all around. The car was planted and I was using a Blitz body. Spur the o-rings could have moved as the two halves were coming together just use some silicone sealer.
Old 08-26-2009, 10:23 AM   #989
YR4Dude's Avatar
Trader Rating: 44 (100%+)
You can also go to www.kamikazetoysandhobbies.com
Even by mail order, they can take care of all your Serpent needs. Their shipping is very reasonable. Plus Sam is very knowledgeable about the product and all the products and accessories he sells that would compliment your Serpent. His son Nigel is a driver for Serpent and can help you with your setups.
YR4Dude is offline   Reply With Quote
Old 08-26-2009, 10:39 AM   #990
Bambusratte's Avatar
Originally Posted by RC MARKET View Post
Diff Housing V2 arrive !
& New Fuel Tank is Clear .
What's the difference between the old and the new Diff-Housing? Any pics?
Bambusratte is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
