Old 08-20-2009, 07:15 AM   #916
quietstorm76's Avatar
Originally Posted by Clocking View Post
What are the best tires for the 733?
That really depends on your traction but you should be safe with 38f/38r with box setup.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 08-20-2009, 07:51 AM   #917
Originally Posted by rcpaintinpete View Post
my old serpent box worked fine with a little mod to it
had to shave a little off the right rear side and took of one of the front nubs that were hitting the diff and moved it over 1/4 inch car actualy fits better then my 720 did and I can still use it for my 966 will post some pic when I get home from work
rcpaintinpete,
I d like to see the pics of the box ? Thanks
GHN
ghn-sp is offline   Reply With Quote
Old 08-20-2009, 08:19 AM   #918
Sow&Steady's Avatar
Originally Posted by shawn01 View Post
Let us know what you think about that motor too!
Will do ... I love Murnan engines but starting this one to run it in was a pest. I thought only the Plus-12s were difficult. With the 2604 I think it'll fly once ready tho!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 08-20-2009, 08:22 AM   #919
RC MARKET's Avatar
HardCoated main chassis
Serpent 733 1/10 200mm touring-cso-ser-733h.jpg
RC MARKET is offline   Reply With Quote
Old 08-20-2009, 08:31 AM   #920
Pattojnr's Avatar
Trader Rating: 19 (100%+)
if only an after market tank came out before the chassis
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 08-20-2009, 11:52 AM   #921
RC MARKET's Avatar
maybe tomorrow !
Old 08-20-2009, 01:31 PM   #922
Default Persistent tank leak
I have had problems with fuel leaking out of the filler cap of my 733 I have even removed the tank from the car and left upturned with fuel in for 24hrs hoping the O-ring would soften, no luck.
So I removed the cap spring and replaced with a slightly larger spring from a NTC3 low profile tank. Result leak cured tank can now hold pressure with not a hint of air leaking around the filler cap.
fezz is offline   Reply With Quote
Old 08-20-2009, 03:29 PM   #923
send it back to the hobby shop. Serpent agreed to replace it with a new and improved fuel tank.
silverM3 is offline   Reply With Quote
Old 08-20-2009, 11:41 PM   #924
MrSlow's Avatar
hey y'all
how do i build the shocks so there is equal rebound on all? if someone can give a quick shock assembly procedure that would be great
thanks!
MrSlow is offline   Reply With Quote
Old 08-21-2009, 12:12 AM   #925
nitrodude's Avatar
Originally Posted by MrSlow View Post
hey y'all
thanks!
You have to get the serpent shock building tool, it makes or easier to build all 4 shocks with the same rebound.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 08-21-2009, 02:25 AM   #926
shawn01's Avatar
Nice, I talked to the guys at Murnan yesterday, gonna pick one up, cant wait to rip it up with it. Almost done putting the kit together. Everthing on this kit fits so well together. Its all compact and everthing seems to flow. Well its backto building, have fun getting that motor singing
shawn01 is offline   Reply With Quote
Old 08-21-2009, 04:56 AM   #927
Pattojnr's Avatar
hey y'all
thanks!
shock shaft all way out, then do the retainer up half way, then when oil is coming out, push the shock shaft halfway down. then slowly tighten the retainer up. it works for me.
Serpent - Walter RC
Old 08-21-2009, 07:04 AM   #928
Joey4875's Avatar
hey y'all
thanks!
Use a 3mm and a 1mm castor clip put them at the bottom of the shock and fill the shock with oil put shock together then slowly push in shock till the castor clips hit the shock body and then tighten the cap Paolo showed me this trick works everytime
Xray,Hudy,RC America
Joey4875 is offline   Reply With Quote
Old 08-21-2009, 01:00 PM   #929
MrSlow's Avatar
Default Shock Build
thanks for the shock build tips.
could i see a picture of these 2 techniques? i am still learning all the vocabulary and having a tough time visualizing the procedure...
thanks
Old 08-21-2009, 01:38 PM   #930
Clocking's Avatar
thanks
Yes i need too, thank you
Serpent 733 - Nova 353 Tuned 2009
Servos Sanwa ERG WRX - Sanwa M11X
Clocking is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
