Old 08-14-2009, 12:31 PM   #886
Gonzo RR's Avatar
Originally Posted by Pattojnr View Post
i see pics of everyones cars, and i all see them with the side belt tensioner on the top of the plate. now i havent run mine yet, but i cannot get the belt tight enough. i have put it below the plate, and now i can set the tension much better, and a gram or 2 is also lowered, hahaha.
and for everyone saying these kits are tight, i do not believe that, mine is loose. rear top arm links, and steering links, and shock ends all are loose on the balls. top front arms have a slight bit of play also. should be fast straight away
X2 Mine was also loose out of the box! not tight parts anywhere... It felt really good firts time at the track... and getting better!!!
Xray NT1 '08 /'09 EC LRP12R / Serpent 720 '08 RB Concept V12, R3 RB mods, V12 Rody, Matrix RW / Serpent 733, 733TE RB T9 / EA RC8T OS .21 Vspec speed tuned / Kyosho Inferno GT, GT2 / EA SC10 / Serpent Cobra GT coming soon!
Gonzo RR is offline   Reply With Quote
Old 08-14-2009, 01:58 PM   #887
cobrajet's Avatar
Plus 1.
I had (or think I "needed") mount the side belt tensioner in the lower postion. Even after replacing belts to the more durable orange belts. And my parts were so lose out off the box that parts fell every where (j/k). Didn't need To trim or ream a part, perfect fitment!
Still can't find any thing on the optional chassis that's showen on a few sites...
cobrajet is offline   Reply With Quote
Old 08-14-2009, 03:45 PM   #888
Gonzo RR's Avatar
Originally Posted by cobrajet View Post
Plus 1.
Yeah is not even on the serpent website either... nor is the front spool but I ordered one anyway... I'm curious to see what that optional chassis plate looks like!
Old 08-14-2009, 04:41 PM   #889
liteweight's Avatar
When we going to get the new fuel tank replacement? what is the procedure?
John's Mobile R/C Raceway outdoor racing
"The New Coliseum Carpet Track"
"MRH" Carpet racing
"Xray T3 2012"
liteweight is offline   Reply With Quote
Old 08-14-2009, 07:52 PM   #890
Hello all:
Right now most of the people on Serpent America are in the worlds. Early this week I contacted serpent headquarters and they told me that they were in the process of packing. So my best guess is that tanks should be on local distributors around mid next week.
Based on previous experience as Serpent Distributor. The best process is to contact the hobby shop that sold you the kit and ask for the tank. They are the ones that will receive the replacement. This is the only way that Serpent can replace without doubt this defective tanks.
Im sure that once they are available, the will be supplied to dealers.
Edgar Millenium is offline   Reply With Quote
Old 08-14-2009, 10:13 PM   #891
shawn01's Avatar
Thanks for the info about the batteries. Good to know. I have been checking out the new line-up from max amps. I think I'll give them a try.
shawn01 is offline   Reply With Quote
Old 08-15-2009, 10:58 AM   #892
Erchur's Avatar
Eduardo Romero
Serpent America-Desoto Racing, Novarossi, KO Propo, Byron's Fuel, Alpha Tires, Alpha Body
Erchur is offline   Reply With Quote
Old 08-15-2009, 12:38 PM   #893
RC MARKET's Avatar
manufacturer said next weekend !
RC MARKET is offline   Reply With Quote
Old 08-15-2009, 07:44 PM   #894
auggy79's Avatar
Guys would need some help here.....my LRP starter box could not reach the flywheel as it seems to be smaller than the other brands.
What starter box do you guys use/recommend?
auggy79 is offline   Reply With Quote
Old 08-15-2009, 08:52 PM   #895
shawn01's Avatar
I went with the MUGEN Pro Starter RII on road starter box. Starts it up every time, runs with dual 550 motors. A main hobbies has them for $110.
Old 08-16-2009, 02:00 AM   #896
RC MARKET's Avatar
Yes MUGEN Pro Starter RII is best & smaller !
price is around $90
Old 08-16-2009, 12:52 PM   #897
I used the jl starter box and that has work the best for me and it was really easy to set for the car
p1pioneer is offline   Reply With Quote
Old 08-16-2009, 09:15 PM   #898
cobrajet's Avatar
Well, find a problem with mine other then a cracked tank with didint cause any problem, in fact my car was spot on today.
The tank transponder mount was to low for our system to pick it up today. and lost a heat run do to it. Were are you guys who mount them on top place the transponder? Seems the side is to close to the linkage and other places its a belt or waving hello for a impact.
Old 08-17-2009, 01:58 PM   #899
Am i wrong in assuming the old serpent starter box i had for my 710 and 720 will work for the 733? Does the kit come with an adapter like the others did?
Jean L.
sponsored by my paycheck.
Maxx is offline   Reply With Quote
Old 08-17-2009, 02:04 PM   #900
cobrajet's Avatar
My kit did not. And the old ones will not fit
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
