Old 08-13-2009, 06:27 AM   #871
s10dude's Avatar
there is " alway's " a few things to sort out on a new model . that is why i didn't get one yet and will not till next year when most everything will be worked out....tank problem is a biggie though....lol
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 08-13-2009, 06:31 AM   #872
~McSmooth~'s Avatar
With a new engine and exhaust, and a yet-unbroken fuel tank.
DeSoto Racing * Franchise * Pro-One * Team Scream * Power Push * Team Ass
Badly influencing a new generation of racers!
~McSmooth~ is offline   Reply With Quote
Old 08-13-2009, 07:14 AM   #873
shawn01's Avatar
Car looks good, what RB engine did you end up going with?
shawn01 is offline   Reply With Quote
Old 08-13-2009, 07:42 AM   #874
Suspended
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
hey McSmooth your missing you rear side pully lol car looks great
you know you can solder the crack on the tank it holds up very well
I couldnt wait for the new tank to run the car .put about 15 tanks of fuel through it last sunday and the solder trick is still holding and thats with a
tie strap goint to the rear tower
TEAM ARC USA --- TEAM POWERS USA ---- TEAM VALKARIA RC ----
rcpaintinpete is offline   Reply With Quote
Old 08-13-2009, 08:18 AM   #875
~McSmooth~'s Avatar
Yeah, the side pulley can be seen in the upper left corner. I'll be taking the engine out again shortly, so didn't need to have that in the way.
I ran the kit tank for the entire GLC. Tons of practice, 5 quals, and 2 mains. No cracks in the tank. Yet.
Old 08-13-2009, 08:19 AM   #876
~McSmooth~'s Avatar
The Murnan one.
Old 08-13-2009, 01:09 PM   #877
spurgear's Avatar
Send a message via MSN to spurgear
The Murnan one.
That is supposed to be super fast! How does it run?
Serpent 733 trinirc.com
Novarossi Plus 12-3CT Murnan Modified Full Ceramic Edition
Novarossi EFRA 2630 exhaust with medium header
Futaba 3PK HRS with Digital Servos/ JLR Starter Box
East Civic 200mm
spurgear is offline   Reply With Quote
Old 08-13-2009, 01:18 PM   #878
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
With fuel....
(Sorry couldn't help myself ).
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 08-13-2009, 02:59 PM   #879
quietstorm76's Avatar
It is supa fast. Get one or chase one.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 08-14-2009, 06:04 AM   #880
~McSmooth~'s Avatar
Haven't run it yet. Notice how shiny the exhaust is. LOL.
The car was run at the GLC with a different engine/exhaust.
It's been broken in, and will finish the process at the Byron's race.
Old 08-14-2009, 07:38 AM   #881
DayDAY's Avatar
gentlemen, finally I bought a Novarossi N12 with silver heatsink, Max pipe, looks good, gonna start beaking in the engine this weekend. Though the engine is not a super one, but one day I might upgrade it to a 353..
DayDAY is offline   Reply With Quote
Old 08-14-2009, 08:59 AM   #882
shawn01's Avatar
Alright fellas I have been looking at batteries all day long..... I am going to be running an Airtronics set-up, the 92744 reciever, and the 94358M ERG-VB high torque servos. What are some suggetions for batteries, of course trying to go with a light weight. Also I want to be operating at 6.0 v and most of the batteries I was looking at rate at 7.4 so will I be needing a voltage regulater as well. Thanks for your input!
Old 08-14-2009, 09:06 AM   #883
~McSmooth~'s Avatar
I use the Exceed LiPo Rx pack, and I don't use a regulator.
I was told by a pro driver (that's at the worlds now), that most radio mfrs test their gear to 9V. He, and many other racers I know, don't bother with the reg.
Basically, you can do it, but at your own risk.
( I don't mention said pro driver's name, only because I'm not sure of any radio "sponsor" issues with him telling people publicly not to use a reg.)
Old 08-14-2009, 09:34 AM   #884
Pattojnr's Avatar
Trader Rating: 19 (100%+)
i see pics of everyones cars, and i all see them with the side belt tensioner on the top of the plate. now i havent run mine yet, but i cannot get the belt tight enough. i have put it below the plate, and now i can set the tension much better, and a gram or 2 is also lowered, hahaha.
and for everyone saying these kits are tight, i do not believe that, mine is loose. rear top arm links, and steering links, and shock ends all are loose on the balls. top front arms have a slight bit of play also. should be fast straight away
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 08-14-2009, 10:46 AM   #885
i do agree with you... running at 7.4v is not gonna do too much harm to your radio gear since most manufacturers would build in a fair degree of safety factor... of course if you want zero worries, use the regulator....
btw i did an experiment with a used 9451 servo and spektrum receiver some time back just for the fun of it... i ran approximately 7.5~8volts into it using a variable dc power supply... nothing blew after 30 mins....
or alternatively, go LiFe (6.6v)...
katze is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
