Old 08-10-2009, 12:03 PM   #841
Clocking's Avatar
Originally Posted by fatboy View Post
I've complete the front of the 733 and found that my front belt is rubbing against the part where hold the steering post. excuse mi cuz i dont know what should it be called. ( Enclosed Pic )
Is there any other way which i can get rid the front belt from rubbing.
I have the same problem and i use a puck, can someone help me ?
Serpent 733 - Nova 353 Tuned 2009
Servos Sanwa ERG WRX - Sanwa M11X
Clocking is offline   Reply With Quote
Old 08-10-2009, 12:42 PM   #842
trickd122's Avatar
Mine rubs but this is not a problem, If you want you can just grind off a little material.
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 08-10-2009, 01:53 PM   #843
cobrajet's Avatar
Originally Posted by Paolo M View Post
Mine race ready is 1735, all stock parts, Lipo batt and regulator
I got mine just a tad lighter then that. Using a li/fe battery. No fuel. And min foam Exceed lites with less then 50% of the top with ti screws to balance the weight out as close as I can get
cobrajet is offline   Reply With Quote
Old 08-10-2009, 02:11 PM   #844
RC MARKET's Avatar
1mm washer
RC MARKET is offline   Reply With Quote
Old 08-10-2009, 04:21 PM   #845
MrSlow's Avatar
Originally Posted by trickd122 View Post
Tweaking the swaybars have NEVER been easier!!!
i notices my front sway bar was a bit bent and not quite symetrical (did not sit flat on a setup board). i bent it a bit with pliers. is that the thing to do?
also, im using new JR servos with grommets. this makes the mounts a bit thick and changes the alignment of fr and rr linkages. do i need to use the servo grommets?
thanks
MrSlow is offline   Reply With Quote
Old 08-10-2009, 04:42 PM   #846
+1 my front sway bar came bent as well.
i0kr1sol is offline   Reply With Quote
Old 08-10-2009, 04:44 PM   #847
trickd122's Avatar
thanks
Well if after bending it, it was straight then no problem my rear on was that way and I resolved it in a similar manner. I generally use grommets however I only have them on the throttle not the steering. No issues so far.
However am not by ANY means the end all Be all guy to go to. When it comes to setup and chassis tunning Mr Morganti and Mr Apolaro should be your go to guys.
Old 08-10-2009, 05:26 PM   #848
Suspended
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
Default First Run Impressions
Well guys I got to run the car for the first time this weekend...
at Ft Myers, and I must say I was Blown Away by the
performance of the car. The car was very receptive to
small changes and you noticed them almost immediately.
I have heard you guys say the sweet spot was very large
and I agree. My overall first impression of the car was
happiness - no more traction roll!!! This is the set up I ran
at Ft Myers and I am SURE it is going to change again - just
wanted to share with you guys
Front
100000 diff oil
-1 droop
middle roll center position
car long
4mm caster in front of arm
5.5mm ride height
stock springs (blue) 1st hole
2 hole piston
40wt oil (1000 cst)
1.0 toe out
2.0 camber
stock sway bar, flush in the collar
ackermann in front position and wide
198mm width
Rear
40000 diff oil
3 droop
low bottom pins
car long
camber link inner and 2nd position from bottom
2mm under link on inner position
6mm of ride height
springs (red long) 2nd hole
3 hole piston
40wt oil (1000 cst)
2.5 toe in on each side
3.0 camber
stock sway bar, inside hole in the arm and flush in the collar
200mm width
Tires tried them both
38F& 38R
40F& 40R
60mm fr
62mm r
2mm split
TEAM ARC USA --- TEAM POWERS USA ---- TEAM VALKARIA RC ----
rcpaintinpete is offline   Reply With Quote
Old 08-10-2009, 06:16 PM   #849
trickd122's Avatar
Front
100000 diff oil
-1 droop
car long
5.5mm ride height
2 hole piston
40wt oil (1000 cst)
1.0 toe out
2.0 camber
198mm width
Rear
40000 diff oil
3 droop
low bottom pins
car long
6mm of ride height
3 hole piston
40wt oil (1000 cst)
3.0 camber
200mm width
38F& 38R
40F& 40R
60mm fr
62mm r
2mm split
yep It's ON baby...... Wayne's ready, I'm ready.....Bobby's ready...oops his car came READY
Old 08-10-2009, 06:29 PM   #850
DayDAY's Avatar
You can tighten the servo saver a bit to raise the metal up a bit, if the belt scratches the plastic parts, just use sand paper or a cutter to file it out a tiny bit. Mine is not touching after the modification.
DayDAY is offline   Reply With Quote
Old 08-10-2009, 09:17 PM   #851
clmbia45's Avatar
Originally Posted by clmbia45 View Post
1863 grams, with nimh battery
Changed from JR servos to Futaba 9450 and 9550, and lipo battery and regulator. Wt. dropped from 1863 Gm to 1775 Gm. I have the Spektrum telemetry module and temp sensor installed; also I have the old bigger receiver, which probably accounts for most of the 40 Gm difference with Paolo.
clmbia45 is offline   Reply With Quote
Old 08-11-2009, 12:34 AM   #852
shawn01's Avatar
I have been looking for engines as well. Being out of the states right now, I cannot see what most guys are running for the on road curcuit. I am tossed up between the novarossi 353, the RB Concept touring 9 onroad competition, or the RB Concept touring 9 RC on road competition engines.
shawn01 is offline   Reply With Quote
Old 08-11-2009, 03:55 AM   #853
so what is everyones verdict on the car after a few runs?
any broken parts, any wear in the drivetrain (belts, pulleys etc)?
how is the slop in the arms, linkages, etc? i noticed after a few runs of my rrr, everything was very sloppy.
also, those that are speaking highly of the car after running it, are you comparing it to the 720? anyone switch from NT1, RRR, MTX4 and run the car yet? Would like to see some input.
finally, what shock and diff oils come closest to the serpent ones? i can't find serpent shock or diff oils
thanks.
justin.
implusepro is offline   Reply With Quote
Old 08-11-2009, 04:34 AM   #854
quietstorm76's Avatar
thanks.
justin.
I switched from the 720 and this car is a lot better all around. That sweet spot is as big as everyone is saying. Tried lots of changes on the car and so far nothing I've done has upset the car. It really is a great car.
Shock oils are different Serpent 40wt is 1000cst, 35wt is 600cst, diff oil may be the same across the board but double check below.
http://www.twf8.ws/php/index.php?opt...per&Itemid=175
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 08-11-2009, 08:28 AM   #855
Gonzo RR's Avatar
X2 I also have a 720 and this new 733 is kind of making the 720 obsolete. I have tons of spares for my 720 TONS!!!. I agree on the sweet spot, it's just great!!! Last race @ local track I finished 3rd, 2 NT1's finished before me but that was only my second time at the track with the 733 and my set up wasn't 100% I'm sure that will change as I get more familiar with the car.
I also have a NT1 but i'm waiting on parts for it (rear diffs) once I get it running again I will compare them and post.
Xray NT1 '08 /'09 EC LRP12R / Serpent 720 '08 RB Concept V12, R3 RB mods, V12 Rody, Matrix RW / Serpent 733, 733TE RB T9 / EA RC8T OS .21 Vspec speed tuned / Kyosho Inferno GT, GT2 / EA SC10 / Serpent Cobra GT coming soon!
Gonzo RR is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
