Old 08-09-2009, 09:38 PM   #826
Originally Posted by fastharry™ View Post
I'm a little surprised by how heavy it is...
Mine race ready is 1735, all stock parts, Lipo batt and regulator
RCtarget, Capricorn, Novarossi, Maxima MX Fuel, Matrix, Xtreme Aero, Avid, Ko Propo, Veytrex Lab, Blast RC, PMR
Paolo M is offline   Reply With Quote
Old 08-09-2009, 10:25 PM   #827
clmbia45's Avatar
Originally Posted by clmbia45 View Post
That's with the Spektrum temp telemetry, Protoform Stratus 3.1 body, JR dig servos. The battery pack is heavy. Maybe I should have used less paint?
My lipo and regulator will be here tomorrow. Somewhere I have some titanium pivot balls, if I can find them. I'll weigh it after the battery change, but I think the JR servos are heavy, too.
clmbia45 is offline   Reply With Quote
Old 08-10-2009, 01:04 AM   #828
Clocking's Avatar
Mine 1845 with servos Sanwa ERG-WRX and aluminum screws:/
Do you think that the battery nimh is my problem?
Serpent 733 - Nova 353 Tuned 2009
Servos Sanwa ERG WRX - Sanwa M11X
Clocking is offline   Reply With Quote
Old 08-10-2009, 02:15 AM   #829
DayDAY's Avatar
Default Need advise on Servos and engines
My 733 is almost finish and now waiting for servos and engines, any recommandations???... I have 2 9402 but quite old...wish to use a digital one,
Serpent 733 1/10 200mm touring-serpent-733-1.jpg
DayDAY is offline   Reply With Quote
Old 08-10-2009, 04:16 AM   #830
quietstorm76's Avatar
If you're on a tight budget just run the 9402's and get a Red Dot.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 08-10-2009, 04:35 AM   #831
what are the standard spurs and pinions that come with the 733?
implusepro is offline   Reply With Quote
Old 08-10-2009, 04:39 AM   #832
Originally Posted by Gonzo RR View Post
I think he said he was using the stock gearing which is 17 - 22 / 60 - 54
Primary Weapon: ?
Secondary Weapon: ?
Old 08-10-2009, 04:41 AM   #833
DayDAY's Avatar
Sorry, don't quite understand "Red Dot"... is it an engine?? Been out of the R/C car world for quite a time....thanks.
Old 08-10-2009, 04:44 AM   #834
Oh my bad. Here ya go
http://www.kamikazetoysandhobbies.co...p?prod=51124-3
Primary Weapon: ?
Secondary Weapon: ?
Old 08-10-2009, 04:49 AM   #835
DayDAY's Avatar
[QUOTE=quietstorm76;6184206]Oh my bad. Here ya go
Oh..., know la, thinking of getting a Novarosee, in compare to the tow, which one is better....
Old 08-10-2009, 04:56 AM   #836
Hello from Spain,my fueltank is broken too.
I have taken some photos when i have build my car,with pictures of the weigth of some parts like pivotballs,clucth etc.
you can download it here.
w w w .megaupload.com/?d=3M4J6CW8
I wish you like.
Sorry about my english.
Jon
MaNoN is offline   Reply With Quote
Old 08-10-2009, 05:44 AM   #837
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Hi Paolo...Good to see.....I was kind of figuring that's where the weight should be. I really like the looks of this car, and if Serpent comes out with a new electric, I will buy both for next year. Need to have both cars from the same stable.
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 08-10-2009, 06:40 AM   #838
trickd122's Avatar
Default 733 Loving this car
This car is Bad-ASS. It is fast and so far has handled BETTER than my previous car. It is very reactive meaning for me it seem to transfer weight more rapidly. The sweet spot really is larger than the 720, in that I was able to run different settings and still achieve good handling. The car is easy to setup. I am not the worlds greatest mechanic so for me this is very important.
Tweaking the swaybars have NEVER been easier!!!
Hits:
*You truly get MORE than what you pay for...Seriously
Sexy, sleek look
Excellent handling
Large sweet spot
NO hop ups needed
Very OPEN look
Support - EXCELLENT
Brakes are well ventilated (The keep cooler) less brake fade
Misses
-Wider bumper needed for the US (The narrow bumper allows for the wheels to absorb all the impact)
Changing the rear inner camber link is a bit difficult.
Final rating 9.5!!!
Great car.
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 08-10-2009, 06:52 AM   #839
I just repaired my fuel tank and I took the advice given already about the soldering iron but I added a step.
I took a pair of large channel lock pliers or you can use a C-clamp and I held the hinge in place. I put the pin in place to keep the hole from deforming. I used a small flat tip iron and melted the plastic around the break. Then I used some flexible plastic (tackle box inserts) and melted it with a cigarette lighter so it could drip around the broken area. Last I took a dremel and filed away any excess plastic so the tank will close fully.
Trick to get the spring back in.............zip tie the lid in place, push the spring in with a 5mm driver, slide the pin thru and that's it. It was really easy for me.
My .02 cents
Primary Weapon: ?
Secondary Weapon: ?
Old 08-10-2009, 09:02 AM   #840
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
[QUOTE=DayDAY;6184217]
If your looking for a Nova rossi based engine for a good price you can look at the Max Power RR3 engine for about $280
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
