Old 08-04-2009, 08:28 AM   #736
~McSmooth~'s Avatar
Originally Posted by Killa G View Post
Did you run the wing standard with this setup or did you move it back a few mm? This setup looks like it has tons of steering.
Gael
Standard position.
There was no oversteer with this setup on the Toledo track.
Originally Posted by quietstorm76
Your tire choice, did you run that shore gap because of understeer? I'm wondering if you noticed a lose of on power steering with the Civic compared to the Stratus?
I didn't try the Stratus body. I plan to do that soon, as well as the Altis.
As for tires, I know Paolo was running 38F/40R early in practice, but I don't know what he finished with.
I ran 35F/40R in qualifying, but ran the harder compound for the longer mains and discovered I liked those tires better.
DeSoto Racing * Franchise * Pro-One * Team Scream * Power Push * Team Ass
Badly influencing a new generation of racers!
~McSmooth~ is offline   Reply With Quote
Old 08-04-2009, 09:14 AM   #737
Gael L's Avatar
Originally Posted by quietstorm76 View Post
Wassup Gael? How you likin' the car?
Haven't built it yet but looking forward to getting some work done this week. Been busy with work and the fam. Seems like you and everyone else are loving it though
Gael L is offline   Reply With Quote
Old 08-04-2009, 11:01 AM   #738
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Originally Posted by ~McSmooth~ View Post
Standard position.
I love the Herrminator avatar. Tell Jimmy, that Scott says Hi.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 08-04-2009, 11:14 AM   #739
~McSmooth~'s Avatar
James says, "Hey".
See you in a month.
Old 08-04-2009, 01:27 PM   #740
clmbia45's Avatar
Questions??
There are 3 thick white plastic donut shaped "washers" in the kit; any one know what they're for?
clmbia45 is offline   Reply With Quote
Old 08-04-2009, 01:41 PM   #741
~McSmooth~'s Avatar
I believe they're for putting in your fuel tank if it expands and gets oversized.
Old 08-04-2009, 02:28 PM   #742
clmbia45's Avatar
OK & tnx. I had forgotten about that, and there is a hole in the bottom of the tank to install it.
Old 08-04-2009, 07:00 PM   #743
Erchur's Avatar
How/where are you guys mounting the voltage regulator (for use with an Xceed lipo battery)?
Thanks!
Eduardo Romero
Serpent America-Desoto Racing, Novarossi, KO Propo, Byron's Fuel, Alpha Tires, Alpha Body
Erchur is offline   Reply With Quote
Old 08-05-2009, 02:02 AM   #744
shawn01's Avatar
thanks for the info on the springs guys, be ordering some today
shawn01 is offline   Reply With Quote
Old 08-05-2009, 03:11 AM   #745
RC MARKET's Avatar
Originally Posted by Erchur View Post
How/where are you guys mounting the voltage regulator (for use with an Exceed lipo battery)?
Thanks!
if used Xceed New regulator can stay in battery plate top side between upperdeck
RC MARKET is offline   Reply With Quote
Old 08-05-2009, 04:35 AM   #746
when are the 733 front lower suspension arms gonna be in stock? fuel tank when come in?
katze is offline   Reply With Quote
Old 08-05-2009, 08:12 AM   #747
Team Kamikaze's Avatar
All the arms for the 733 are available now!
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 08-05-2009, 10:39 AM   #748
MrSlow's Avatar
beginner question:
what do you guys mean when you say "sping layed down"? also, which serpent front springs are most useful to have? thanks
jason
Here's my GLC Setup:
Front
100K diff oil
0 droop
middle roll center position
car long
3mm caster in front of arm
5.5mm ride height
blue spring layed down
2 hole piston
40wt oil (1000 cst)
Zero toe out
1.5 camber
stock sway bar
ackermann in back position and wide
Rear
40k diff oil
2 droop
lowest roll center position on bottom pins
car long
camber link inner and 2nd position from bottom
2mm under link on outer position
6mm of ride height
long pink spring, 2nd hole up from bottom
3 hole piston
45wt oil (1400 cst)
2.5 toe in on each side
3 camber
stock sway bar
Other:
stock pinions and spurs
civic body
38 shore front, 42 rear
MrSlow is offline   Reply With Quote
Old 08-05-2009, 10:41 AM   #749
MrSlow's Avatar
also...what do you do specifically to make car "long"? please describe how to set up...
thanks
Old 08-05-2009, 10:41 AM   #750
nitrodude's Avatar
He means he used the blue spring with the shock mounted on the lowest hole on the shock tower.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
