Old 07-22-2009, 07:58 AM   #496
dj apolaro's Avatar
Serpent 40wt is 1000cst
They are the same. I just did not get oils in my kit and used what I had.
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 07-22-2009, 07:58 AM   #497
quietstorm76's Avatar
Originally Posted by katze View Post
Hi DJ,
I am just a bit confused. The Kit come with 1000cst oil but the latest setup sheet states 40(1000) for stock shock oil... are you using the stock shock oil included 1000cst or you changed to 40WT(approx 500cst)?
40WT serpent oil is 1000cst. Don't use any other brand of 40 w,wt because it is not the same.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 07-22-2009, 08:01 AM   #498
RC MARKET's Avatar
other parts arrive !
RC MARKET is offline   Reply With Quote
Old 07-22-2009, 08:07 AM   #499
Ok I'm half way thru the build and so far the only thing I've found is the car is a little tight as some has stated. I think it will loosen up after 1 or 2 tanks. Drive line is very free and I did not touch the bearings. The instructions could use some tweaking but I'm sure they will do updates. It's nothing that will stop a build though, after 3 hours of working on it I have all the suspension and drive line done. Just have to do the radio tray and shocks and I'm finished.
Primary Weapon: ?
Secondary Weapon: ?
Old 07-22-2009, 08:59 AM   #500
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
btw, polishing the black oxide coating off of the shock pivot ball and similar helps make a slop and bind free assembly. i used hippatch (sp?) semichrome car polish. can be found at most bike (motorcycle shops)
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 07-22-2009, 09:24 AM   #501
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 07-22-2009, 10:03 AM   #502
no 61T and 56T spurs?
katze is offline   Reply With Quote
Old 07-22-2009, 11:56 AM   #503
RC MARKET's Avatar
i'm waitting arrive !
Old 07-22-2009, 12:16 PM   #504
cobrajet's Avatar
i got mine done last night and i dont have any issues with any thing being tight, smooth as silk.
did have to move the side belt guide lower and the brake pully around. the alum looks great too, cool finish and no marks, some flash but nothing blowing it out didnt fix. i like how the diffs and roll centers are super easy to get too. going to start out trying out DJs set up.
cobrajet is offline   Reply With Quote
Old 07-22-2009, 12:36 PM   #505
Default serpent 733
Hi
where can I find 120,000-150,000 oil for the diff?
jjrctech is offline   Reply With Quote
Old 07-22-2009, 12:47 PM   #506
Send a message via ICQ to _cyclops_
Originally Posted by jjrctech View Post
Hi
get 100K
get 200K
MIX!
_cyclops_ is offline   Reply With Quote
Old 07-22-2009, 12:49 PM   #507
Originally Posted by _cyclops_ View Post
get 100K
get 200K
MIX!
where can i buy that oil for all I see is up to 100k
Old 07-22-2009, 07:11 PM   #508
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Serpent makes up to 100K if you want thicker wt oil you can use mugen or ofna oils.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 07-22-2009, 07:19 PM   #509
beta bob's Avatar
Trader Rating: 2 (75%+)
If you want diff oil that thick why don't you just use a spool
Team Terribles---------2009 post of the year
"Cant you read Mopar???He said that he drives a T-max 2.5!!!!"
Spec classes are for communist
beta bob is offline   Reply With Quote
Old 07-22-2009, 07:27 PM   #510
dj apolaro's Avatar
They do not make the spool yet. It is coming.
Also running a diff even at 300 is not the same as running a spool. There are pleanty of companies that make over 100. Xray makes all of them, Mugen, Kyosho, Ofna, etc. It should not be hard to get. I know on the internet it is easy.
Good Luck,
DJ Apolaro
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
