Old 07-19-2009, 12:30 AM   #451
stefan's Avatar
Send a message via AIM to stefan
Originally Posted by M7H View Post
That what opinions are for...
But, as a long time Serpent driver I can assure you 1 thing compared to other brands.
Yes, the plastic parts now seem to have a (to) tight fit, but after you have driven the car everything will settle, and then you will see that the amount of play on the parts will be very little compared to other brands.... and this little amount of play will stay that way for a very long time!....
And I have seen hugh amount of play on other branded cars... "this supose to be like this" is the comment from the owner then.... sure...
I don't know about the plastic parts loosening up.
As a long time Mugen driver, this spring I built my first Serpent kit, a 966 for my son who's partially supported by Serpent now.
I have to say, the built didn't go as smooth as I am used to from my Mugens.
Among missing parts I was actually shocked how tight some of the plastic parts fitted, and I went back to a very old routine, to "bake" the car at 80°C for a few hours.
The suspension became a bit more free after that, but all the ball ends didn't.
I ended up using a long time Serpent driver's ball reamer to make them move freely. Strange thing was that they started to tighten back up.
Sorry to say, but I replaced them with Mugen parts
I think serpent is working on a new plastic compóund to solve this problem
@ Katze: As with full size cars, the first production runs are prone to have small problems. It's callled field testing. That's why I usually wait a few month before I purchase a new kit
stefan is offline   Reply With Quote
Old 07-19-2009, 12:52 AM   #452
M7H
M7H's Avatar
Maybe the new chinees plastic is a bit different....
I know a mugen fits together perfectly, and with a snake you sometimes have to do some work, although my 950R, 960'08 which I upgraded to 966, went together without the use of a reamer at all....
I also believe people should just put the car together and drive with it, because it will loosen up...
Serpent
M7H is offline   Reply With Quote
Old 07-19-2009, 04:56 AM   #453
and23's Avatar
[/QUOTE]
What type of receiver is this??? Is it Ok for the radio Esprit II type R??? thank you very much...
and23 is offline   Reply With Quote
Old 07-19-2009, 05:10 AM   #454
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
+1....Also, I remember reading about a process HUDY uses to remould parts so after they cool he can see where the shrinking areas are, remold them, and this is what allows for a first time fit.....although I am sure the plastic has something to do with it
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 07-19-2009, 09:02 AM   #455
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Originally Posted by and23 View Post
What type of receiver is this??? Is it Ok for the radio Esprit II type R??? thank you very much...[/QUOTE]
That is a Airtronics/Sanwa 2.4ghz FHSS-2
Inf1nity CM Beat1 Racing
Serpent-Dan is online now   Reply With Quote
Old 07-19-2009, 10:18 AM   #456
ok... now i intend to do some unbiased field test reporting as i got back from a few runs at the track...
<< First impressions >>
Build process was rough for me but the finished product looked really handsome indeed. Car started up fine and nothing was seriously binding. Suspension was still too stiff for my liking and that caused handling problems for the first couple of tanks. Car was totally all over the place. The plastics bits loosen up and the car tweaked massively towards the right. Some sub trimming allowed the car to track straight again.
<< Set-Up >>
Started out with the stock setup and the car was handling sweet at my local track(after the car loosened up of course). Was impressed since the only other car that handled sweet right from the box was a Kyosho. Tweaked the shock positions and changed my rear diff oil to a harder one and the car was suddenly great! Certainly did not expect the setting-up to be so easy. As i slowly got used to the car(and maybe the car loosened up further), i felt that i was putting out faster and faster laps.
<< Handling Impressions >>
The car can handle weight changes really fast. I suspect its due to the low CG and centralised weight placement. Noticeable less roll for sweepers and chicanes/S turns/180 turns were suddenly much more fun. I suspect the car will be very fast in a tight technical track. The "sweet spot" for the car was very wide. The car responds to setup tweaks but is not overly sensitive which is a good thing i guess. Ran my tires down to the rim and the car was consistent in handling throughout the day.
<< Verdict >>
The 733 is impressive both aesthetically and performance wise. These two point will definitely allow Serpent to sell a lot of 733s. They can sell even more 733s if they buck up on the manual and plastic part mouldings.
I am wowed by the car because of how it can corner so damn fast and its easy drivabillity. I think Serpent has a potential front runner now. My NT1 is excellent but I think the 733 is better. Will test out more extensively to ensure that it is not perceived superioriority due to the new "car syndrome".
Mr Hudy, look out!!! A little competition will be good. * hint hint - new car *
katze is offline   Reply With Quote
Old 07-19-2009, 10:53 AM   #457
auggy79's Avatar
Just got the kit, have not started building it but will like to make a few comments:
1) Kit is confirmed manufactured in China (Says on the box)
2) Beautiful matt aluminum parts (However, some minor scratches on the front aluminum bulkhead (Seems to be a manufacturing issue or it could be an initial batch issue)
3) Full colour manual but like what Katze has mentioned, manual was pixelated and poor resolution. Manual also not very detailed like those from xray and kyosho. Not a kit for beginners....
4) No setup sheets included, Serpent did not even bother to include some decals considering the price!
5) Very thick and sturdy 4mm carbon fibre parts
auggy79 is offline   Reply With Quote
Old 07-19-2009, 03:44 PM   #458
RC MARKET's Avatar
some parts arrive !
RC MARKET is offline   Reply With Quote
Old 07-19-2009, 04:13 PM   #459
cobrajet's Avatar
<< Set-Up >>
<< Verdict >>
good review, i know with some high end off roading kits you need to "breakin" the car to losin it up, maybe the same case here. i'll have mine in the morning
so next track day i can run both cars and get my thoughts about it.
cobrajet is offline   Reply With Quote
Old 07-19-2009, 09:08 PM   #460
GMartinez's Avatar
Trader Rating: 85 (100%+)
1st I don't have a 733 but wished I did got to see a couple of local drivers & Dj run his 733 today
Very smooth but Dj is always smooth a couple of things that I saw compared to his 720 the 733 has more corner speed & very smooth that it almost looks like an electric car on the track that is dialed instantly.
as for the other local drivers there 733's looked really good as well
really got a chance to look it over & im very impressed if I spent more time on it the next thing I would be doing is buying 1 the 733 is very free rolls really good.
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 07-19-2009, 11:43 PM   #461
Originally Posted by RC MARKET View Post
some parts arrive !
when are the spurs gonna be in?
arms and belts too?
Old 07-20-2009, 12:27 AM   #462
cobrajet's Avatar
arms and belts too?
the spurs and pinions are the same as the 720s "WC" gears, has of all of the clucth system
Old 07-20-2009, 01:37 AM   #463
M7H
M7H's Avatar
As the manual is not online yet, I wonder if it is the same idea as the manual for the 966?
Here you have a link, to compare:
http://www.serpent.com/file.php?FileID=4945
If not, I reckon they did everything they could to get the 733 on the market, and not mis the train and let the V10 steel customers...
Serpent
Old 07-20-2009, 03:46 AM   #464
Pattojnr's Avatar
Trader Rating: 19 (100%+)
i dont believe they got the car in the market correctly. for reasons i will not get into at the moment. but all i ican say is that many distributors do not have kits yet and do not know when they will get theirs for their own preorders, but a certain HK shop has 100 kits. well they did yesterday.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 07-20-2009, 04:32 AM   #465
M7H
M7H's Avatar
101 kits he has, but he already had this 4 days ago, so does he really have them?, or is this just a fake number he put in his system...
Serpent
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
