Old 04-09-2012, 12:19 PM   #4111
Gonzo RR's Avatar
Originally Posted by Rodrigo360 View Post
Hi, I found this!
The Serpent 733 TE Team Edition is the latest evolution
of the Serpent 733 platform.
The EVO version already included the famous Direct Link System (DLS)
and the updated rear end to enable mounting the rubber or
alu connectors to influence flex, and also the mono-type engine mount
was included.
In the 733 Team Edition the following news is included in addition
to above:
- new SL6 gearbox, all new design with very low inertia
- improved fueltank with new cap and seal
- rubber and alu rear connectors included
- the DLS camber bracket can be used with DLS
and with standard rear set-up.
Anything else???
My TE came with hard-anodised chassis plates, mono disk brake..... Second speed shaft is also different, and the aluminum shaft for the brake is also different from the 1st version.... i think that's it
Xray NT1 '08 /'09 EC LRP12R / Serpent 720 '08 RB Concept V12, R3 RB mods, V12 Rody, Matrix RW / Serpent 733, 733TE RB T9 / EA RC8T OS .21 Vspec speed tuned / Kyosho Inferno GT, GT2 / EA SC10 / Serpent Cobra GT coming soon!
Gonzo RR is offline   Reply With Quote
Old 04-10-2012, 02:03 PM   #4112
Rodrigo360's Avatar
Wink
Hi,
Another question about mi 2nd hand 733. I'm confused about gearing. What is the original pinion/spur setup? According to manual pinions are 17/22, but nothing about spurs.
Team Associated TC6.1 - Xcelorin 10.5T - Reedy - XP
Rodrigo360 is offline   Reply With Quote
Old 04-11-2012, 07:06 AM   #4113
lil-bump's Avatar
Trader Rating: 83 (100%+)
Hi,
Stock spurs are 54t 60t
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is online now   Reply With Quote
Old 04-12-2012, 06:47 AM   #4114
Les
Les's Avatar
Default SL6
Pass you soon...
Can anyone tell me whether they have tried the new SL6 Serpent Transmission, is it much more reliable than the original 733 transmission.
Cheers
Serpent S411 4.0 13.5T D4
Kyosho V-ONE S3, RB Rota-Start
Sanwa MT4S
Les is offline   Reply With Quote
Old 04-12-2012, 12:46 PM   #4115
lil-bump's Avatar
I ran 4hrs of practice last week with no issues. The new tranny spools up better and has a much better shift.
Elliott Hart
Serpent America
Desoto Racing Team
Old 04-17-2012, 11:25 PM   #4116
tha Beast's Avatar
Trader Rating: 100 (99%+)
does anyone know if the 2speed shoes(pads) from the evo fit the SL6 im having serious issues with the 2 speed shoes that come with the 733te
REFLEXRACING
MIKES HOBBY SHOP PORTER TX
tha Beast is offline   Reply With Quote
Old 04-18-2012, 02:22 AM   #4117
Thybaut's Avatar
They don't fit, the evo ones are larger.
Serpent 733 TE | RB Touring 9, Novarossi N12T1 | Sav÷x SC-1257TG | Ko Propo EX-10 EURUS
Thybaut is offline   Reply With Quote
Old 04-18-2012, 07:39 PM   #4118
tha Beast's Avatar
REFLEXRACING
Old 04-24-2012, 02:29 AM   #4119
Do not cry
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 04-24-2012, 04:40 AM   #4120
EEL Monster's Avatar
The SL6 uses different 2-speed shoes
What's wrong with the shoes supplied with the SL6?
Serpent 733TE / Reds M3T
LRP S8BX Team / Go MP5 7pt
Tamiya F104 Pro
EEL Monster is offline   Reply With Quote
Old 04-24-2012, 06:59 AM   #4121
Aza088's Avatar
Cheers
there is a problem with the 2 speed shoes in the TE the material was too soft.
I have been told will be fixed with the 747. if you can't wait for the 747 shoes. Try drilling out the shoes where the grub screw goes in to adjust the gap.
insert bigger grub screw and try to find one with course thread.
you will also have to scrap the top with a hobby knife where you inserted the new grub screw as it will swell alittle.
This will make the gear box much better.
But you will need new shoes after about 4 ltrs of racing.
The shift point is very sensitive as well some tracks i found its best to be happy where it is and not try and chase the shift point.
Good luck let us know if this fix's your problem.
Shepherd | Brilliant RC | Matrix | Maxima | Xceed | KoPropo
www.bluerc.net
www.hobbyexpress.com.au
www.hootrc.com.au
Aza088 is offline   Reply With Quote
Old 04-25-2012, 04:54 PM   #4122
Default SL6
Hi!
Hm, maybe stupid question.
I'm before 1st drive of 733TE.
It has this new SL6 gear box, but on 2nd gear there is no hole to easy access
for adjust screws ...
I should made hole or not?
Taking off gear is little flustrating
Michal Abramowicz
Old 04-25-2012, 06:52 PM   #4123
Aza088's Avatar
Originally Posted by M.Abramowicz View Post
Hi!
I have never drilled a hole or needed to just remove the c clip i normally have my pit crew do this during the warm up of a race if need be just make sure you have a spare c clip just in case but there should be no need to make holes just for adjustment.
www.bluerc.net
www.hootrc.com.au
Old 04-25-2012, 10:21 PM   #4124
lil-bump's Avatar
I've ran about 8 hours on my TE and I've had very little trouble with 2 speed,
I did put loctite on all the screws. I changed the buttons head screws to 10mm screws vice the 8 mm. Here are my initials settings
4 3/4 - 5 turns out from fully compressed on both button head screws. The setcrews are about .75mm resessed into the shoe halves. The shoes should have very little rock around the center hub maybe about .1mm
These setting will get you close. My first gear ratio is 17/60.
I hope this helps anyone struggling to get the tranny too shift at all.
Also I had to shave a little of the shoe to get it fit into the Hub without dragging. And yes I did drill a hole in my 2speed hub for easier adjustment of the screws
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 04-25-2012, 11:13 PM   #4125
tha Beast's Avatar
well i have drilled out the holes to fit bigger crub screws i have 3 sets of shoes im gonna try one with CA one with loctite and one without anything just to see what happens. I have a series race this weekend hopefully everything works out. wish me luck
REFLEXRACING
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
