Old 02-01-2012, 12:01 PM   #4051
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
The car looks great!
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 02-01-2012, 02:42 PM   #4052
lil-bump's Avatar
Trader Rating: 83 (100%+)
The sedan looks great. Serpent has address alot of key points with the 747. I'm digging it
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 02-01-2012, 06:02 PM   #4053
Bundy_Bear's Avatar
Originally Posted by Turbo D View Post
Do you use DLS that often???
Since driving 733 i just tried but never used DLS....
In my opinion, DLS just makes the car feel a bit different but doesnt make it faster..
For me the car is perfect, even without DLS.
So here my question:
Do you use DLS just because its a nice and unique option or do you think it really makes the car faster???
Best regards
Daniel (Germany)
Nope leaky diffs
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 02-01-2012, 06:28 PM   #4054
nitrodude's Avatar
Originally Posted by Bundy_Bear View Post
Nope leaky diffs
It seems you only post on here just to diss the car, maybe you should stick to the G4s thread...
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 02-01-2012, 06:55 PM   #4055
Team Chump's Avatar
Default WHAT THE
[QUOTE=Bundy_Bear;10263626]Nope leaky diffs[/QUOte
between me & my mate we have 5 733s . and never 1 leaking diff . maybe yours is an assembly problem
Walter R/C
Serpent
Reds Racing
Podified Race Fuel
Team Chump is offline   Reply With Quote
Old 02-01-2012, 06:57 PM   #4056
Old 02-01-2012, 11:05 PM   #4057
EEL Monster's Avatar
Best regards
Daniel (Germany)
I am happy with the balance of the chassis without DLS at the places I race
I found it made the rear sit flatter but made the car slower to change direction. Less rotation under acceleration and less rear roll mid corner. It's just a tuning option as far as I see it
That was at Lilydale but I wanna give DLS a go at a local parking lot track and see what it's like with lower grip
Nope leaky diffs
That's what happens when you overfill them
Serpent 733TE / Reds M3T
LRP S8BX Team / Go MP5 7pt
Tamiya F104 Pro
EEL Monster is offline   Reply With Quote
Old 02-02-2012, 03:43 AM   #4058
Bundy_Bear's Avatar
[QUOTE=Team Chump;10263932]
Clayton:
You sound like Patto with the user error bizzo:P
I have built two cars and issues with both diffs on both cars... Maybe i am too heavy handed.
Might see you at Wynnum on Saturday if the weather is kind!
Andrew
MissMooRC Racing
Old 02-02-2012, 04:39 AM   #4059
Team Chump's Avatar
[QUOTE=Bundy_Bear;10265722]
Originally Posted by Team Chump View Post
Clayton:
Andrew
Hey Andrew, if you come down Saturday bring those diffs and i'll take a look at them with you and we'll try to sort what's happening.
Walter R/C
Serpent
Reds Racing
Podified Race Fuel
Old 02-02-2012, 04:46 AM   #4060
Bundy_Bear's Avatar
[QUOTE=Team Chump;10265839]
TE is stilling sitting in box somewherem have original 733 i can bring. Plan on dropping in to hand in membership.
Andrew
MissMooRC Racing
Old 02-02-2012, 05:07 AM   #4061
Where does it leak exactly???
Turbo D is offline   Reply With Quote
Old 02-02-2012, 03:42 PM   #4062
Bundy_Bear's Avatar
[QUOTE=Turbo D;10265901]
At the seam where the two halves join together and out of the screw holes.
Andrew
MissMooRC Racing
Old 02-02-2012, 11:36 PM   #4063
rc-goods's Avatar
Default Zero Force Serpent 733 Bearing Set (16 pcs)
Serpent 733 1/10 200mm touring-733_wm.jpg
www.rcgoods.com
rc-goods is offline   Reply With Quote
Old 02-03-2012, 01:43 PM   #4064
[QUOTE=Bundy_Bear;10268551]
Andrew
Same here. Of the 6 diffs I have they were all leaking the same way. Tried new cases, and even doubling up the o-rings. Same issue. My solution was to cut the screws down by about two threads on both sides. Now they don't leak but still sweat slightly. I could live with that. Ironically if you order new cases now they seem to be coming with slightly shorter screws.
ETC: Serpent 411 Eryx 3.0 |Serpent 411 Eryx 2.0 | Serpent 411 TE | Xray T2 | Tamiya F104 V2
NTC: Serpent Cobra GT | Serpent 811 | Serpent 748 TQ | Mugen MTX-4
Heli's: Align TRex 500 EX | HK 500 x2
modelfan is offline   Reply With Quote
Old 02-03-2012, 03:44 PM   #4065
Team Chump's Avatar
[QUOTE=modelfan;10273437]
There are 2 different length screws for the diff pulleys, the longer 10mm ones are for the front pulley only and if used on the rear will bottom out and not allow the diff halves to pull up tight.
Walter R/C
Serpent
Reds Racing
Podified Race Fuel
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
