Old 01-27-2012, 12:05 PM   #4021
and23's Avatar
Ok Thanks...
Andrea
Serpent 733
Max RR3
and23 is offline   Reply With Quote
Old 01-27-2012, 07:16 PM   #4022
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by lil-bump View Post
No one knows We all have to wait until the Toy fair to see what Serpent unvails. Unless you are Michael Salven this is all speculation.
Pass you soon...
its not speculation, there IS a prototype Touring car . how different it is to the 733, we will have to wait.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 01-27-2012, 08:13 PM   #4023
lil-bump's Avatar
Trader Rating: 83 (100%+)
I trust you are correct. But to be a forward minded company. You always have a prototype in your closet. The question is... When will it become a concept for production. I'm just as anxious as the next guy to see what and when Serpent will unveil a new 1/10 scale sedan. Only time will tell
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 01-27-2012, 08:49 PM   #4024
Isn't all speculation and hype another level in this hobby? At the hint of anything new it gets the dialogue going as we start contemplating shelf space for the possibility of new toys. It's always worked for me
ETC: Serpent 411 Eryx 3.0 |Serpent 411 Eryx 2.0 | Serpent 411 TE | Xray T2 | Tamiya F104 V2
NTC: Serpent Cobra GT | Serpent 811 | Serpent 748 TQ | Mugen MTX-4
Heli's: Align TRex 500 EX | HK 500 x2
modelfan is offline   Reply With Quote
Old 01-28-2012, 02:23 PM   #4025
lil-bump's Avatar
ShhhhhhSh... Don't let the secret out
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 01-29-2012, 06:03 PM   #4026
EEL Monster's Avatar
Just ran at the Victorian Onroad Champs over the weekend with the TE
Car was handling great but a couple of trans probs reared their head
Problem 1: Has anyone else had trouble with the SL6 2speed bouncing between gears under hard acceleration after it's shifted when there's a lot of load on the trans?
Problem 2: Stripped 1st gear spur about 15mins into my Semi but have never stripped an SL6 spur ever before then? It was about 40 degrees C and I'm wondering if the heat and the longer race caused the spur to overheat. The teeth look kinda melted. Not your normal sheer marks
Serpent 733TE / Reds M3T
LRP S8BX Team / Go MP5 7pt
Tamiya F104 Pro
EEL Monster is offline   Reply With Quote
Old 01-29-2012, 06:27 PM   #4027
Aza088's Avatar
Hi Mate,
I have had the sl6 trans issue and i have finnaly resolved it you need to look at how the gears are wearing.
After looking at mine the gears were wearing on the non drive side so put it simple it was stripping when 2nd gear kicked in and slapped 1st.
Problem was the one way heats up and starts to grab so when 2nd gear kicked it is was stressing the plastic on first gear.
Resolve new one way and new lay shaft ( or just clean the layshaft with the wire brush on the bench grinder i did this worked )
i now don't oil the one way but i do clean the one way after every run i mean every 5min qual i clean the one way just with a clean rag and a tool to run on the one way internals.
Every 30min final new gears and new pinions every 2 or 3 race meetings to make sure i finish.
This has resolved my problems completely on the stripping gears.
The other problem you are saying with the gearbox jumping between the gears-
The 2 speed clutch material is not the best if you go for a run even 5min qual and then pull apart the gearbox grab the metal centre that the shoes sit on and turn the shoes there is alot of play there.
OH i hear you say tighten the grub screws and yes the play is gone no prob you are correct go for a run first 5-10 laps gear box is fantastic then back to jumping gears again.
Check the slop in the gearbox clutch shoes again the play is back the grub screws come loose because of the material is so soft.
Resolve super glue the grub screws and find a slightly bigger grub screw but you will need to clean up the top of the clutch shoe after you insert the bigger grub screw ( just with a hobby knife works fine)
I hope this helps any thing else just ask ill help the best i can these 2 issues i have been through already so i feel im very intimate with my 733 SL6 gearbox now lol
Shepherd | Brilliant RC | Matrix | Maxima | Xceed | KoPropo
www.bluerc.net
www.hobbyexpress.com.au
www.hootrc.com.au
Aza088 is offline   Reply With Quote
Old 01-29-2012, 06:35 PM   #4028
Aza088's Avatar
Also one to look out for because of my massive horsepower IDM
I was testing yesterday and stripped a gear bang like that no extra noise or any sign it was about to happen hmmmmmm!!!
Ok found problem the mono engine mount actually stripped the 1x engine screw out if it and i said oh well its only one screw ha
Don't go driving with 3x engine screws in 1 and a half laps striped 1st again
My fault replaced the engine mount no problem.
Just thought id share that with you.
Other than that the 733 is a weapon for 2012 i just need to save weight somewhere thinking thinking.
Any sugestions
Already running LIFE bat , titanium screws ,
www.bluerc.net
www.hootrc.com.au
Old 01-29-2012, 09:00 PM   #4029
Thanks for the tips with the SL6 Aza!!!!
I'll give it all a try at the next clubby. Hopefully I can upset some of these Capricorn guys at MRCCR
The chassis was AWESOME though
Any sugestions
Without ballast my TE weighs in at 1690 with an OS Speed 12XZ, Savox 1251MG servos, Xceed Ti screws except chassis screws, 3racing Ti turnbuckle links, Capricorn 1650mah LiFe, Futaba FASST reciever
1690g and that's with the alloy servo saver and alloy front arm carriers.
I had 50g ballast on the car for the Vics
Tamiya F104 Pro
Old 01-30-2012, 05:35 AM   #4030
djiewie's Avatar
Any sugestions
What did help with my NT1 was plastic diffgears and alu pins. But i use only the small plastic gears. The 2 big one`s on the axle i use the metal ones.
Used it without wear for 6 weekends racing and still good for more. I use a 700mah life wich is only 40grams
Lightweight axle on the tranny and front will help too. Look at the alu parts wich are new om the serpent site, they are already working on it.
And remember, lighter cars don`t always win though.
djiewie is offline   Reply With Quote
Old 01-31-2012, 08:44 AM   #4031
and23's Avatar
http://www.rcalert.com/news/?p=11
Andrea
Serpent 733
Max RR3
Old 01-31-2012, 05:40 PM   #4032
Aza088's Avatar
Originally Posted by and23 View Post
top photo is not a 733 keep an eye on the toy fair starting today in Germany.
Who can guess what it is call looks so nice though
www.bluerc.net
www.hootrc.com.au
Old 01-31-2012, 07:46 PM   #4033
lil-bump's Avatar
Looks like they took a lot of designs the 966te. My guess the name will be 733 LE (light edition) or like everyone else says the Serpent 740. Can't wait to see it Floating upper deck, Upper arm mounts like the 966TE. Rear shock tower has less material. They really trim alot fat off of this platform
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 01-31-2012, 09:09 PM   #4034
Pattojnr's Avatar
no its not a 733. what its called ? makes me laugh pretty hard considreing its shedding weight, but it may fly still...........
Serpent - Walter RC
Old 01-31-2012, 11:48 PM   #4035
Aza088's Avatar
No its not 740 or 733 anything just keep checking redrc for updates lol
Yes patto it will still fly wink wink
www.bluerc.net
www.hootrc.com.au
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
