Old 11-25-2011, 06:59 AM   #3901
lil-bump's Avatar
Trader Rating: 83 (100%+)
Originally Posted by rcabj View Post
hi just like to share my findings...one of the reason my gear strips was due to no free play at the 2speed shaft. once i give it a small free play it was solve...
Glad you found it. That was true with the old gearbox too. The 2speed shaft has to have a little room to float.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 11-28-2011, 07:44 AM   #3902
Default 2seed problem
Hi guys i have the old 2speed in my 733 Evo, the 2nd gear doesnt cut in, i try to loose the 2 screws but no help. Any1 know what the problem and how to fix it? Thanks guys......
kickertrf is offline   Reply With Quote
Old 11-28-2011, 08:56 AM   #3903
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Clean the one-way. And use thin grease on it instead of one-way lube.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 11-28-2011, 11:16 AM   #3904
superspeed's Avatar
Is the one-way lube too thick or too thin?
superspeed is offline   Reply With Quote
Old 11-28-2011, 01:19 PM   #3905
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
You may have one way lub on the two speed shoe.. Just clean it. Make sure you dont use more than a drop on the one way bearing. If not, all the extra lub will go into your two speed shoe causing it not to shift at all.
Walter Diaz
wad is offline   Reply With Quote
Old 11-28-2011, 03:14 PM   #3906
M7H
M7H's Avatar
Isn't it shifting way to early?
Serpent
M7H is offline   Reply With Quote
Old 11-29-2011, 06:09 AM   #3907
quietstorm76's Avatar
If was "cutting in" and it suddenly stopped, check the 2nd gear housing. It could be broken in two pieces. Remove the gear and make sure it's not broken. The "old" 2speed is one of the most consistent I've ran so unless its broken it should shift early or late.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 11-29-2011, 06:49 AM   #3908
Thanks dan. Iwill try that
Old 11-29-2011, 06:51 AM   #3909
I used the Xceed oneway oil
Old 11-29-2011, 06:53 AM   #3910
Thanks i ll try this
Old 11-29-2011, 06:54 AM   #3911
Nah, it not shift at all
Old 11-29-2011, 06:57 AM   #3912
I checked it and everything were fine
Old 11-29-2011, 07:16 AM   #3913
Pattojnr's Avatar
Trader Rating: 19 (100%+)
if you have loosened it alot, then id listen for the engine bogging, as off the line it could very well be stuck in 2nd gear due to being too loose.
and if any of my mates reading this, yes a special 2 people ! do make sure you havent lost your 2nd pinion off your clutch bell ! yes. i know......
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 12-01-2011, 12:01 PM   #3914
rias5037's Avatar
Not sure if this is the cause of my gears striping, done 3 of 1st gears on the weekend, but the 16t pinion goes into into spur 61t almost like the tip of the triangle shape where the spur (x marking on it) looks like it should accept a pinion that has a flat end, like my 2nd speed pinion, does anyone know what i mean and could this be the cause of me striping 1st gear all the time?
Serpent 747, Max .12 xxl3, Nova 2630, Contact-rc.
rias5037 is offline   Reply With Quote
Old 12-01-2011, 12:10 PM   #3915
lil-bump's Avatar
Sounds like your 16t pinion is worn out. If the teeth on the pinion taper to a point "^^^^" then it time to replace that pinion. This situation will cause you to strip gears
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
