Old 10-25-2011, 03:46 PM   #3871
GREGORY!'s Avatar
i think this car is heavier than others.
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 10-25-2011, 04:37 PM   #3872
lil-bump's Avatar
Trader Rating: 83 (100%+)
Originally Posted by bertrandsv87 View Post
You use standard or low profile servos ? Good weight for Roar races, but club guys run alot lower weight than that....
If I remove one set of diff gears front and rear and a light weight body I can get it down to 1718 grams. but the roar limit is 1725 so why bother. I teched at the GLC race and all of the fast guys were at least 20 grams over the minimum. There is a lot more I could do but I do not see a need for it.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 10-25-2011, 05:50 PM   #3873
Suspended
Your car is not overweight at all, but some clubs let others run their cars without checking their weight, and that's where it might be difficult for you to keep up....
bertrandsv87 is offline   Reply With Quote
Old 10-25-2011, 09:19 PM   #3874
tha Beast's Avatar
Trader Rating: 100 (99%+)
Pass you soon...
so is the 1725 limit, is that the heaviest or the lightest you can go??
REFLEXRACING
MIKES HOBBY SHOP PORTER TX
tha Beast is offline   Reply With Quote
Old 10-25-2011, 09:24 PM   #3875
lil-bump's Avatar
1725 is the lightest
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 10-25-2011, 09:59 PM   #3876
tha Beast's Avatar
Pass you soon...
cool thanks, also does anyone know where i can get gears for the TE version i cant find any anywhere
REFLEXRACING
Old 10-25-2011, 10:24 PM   #3877
nitrodude's Avatar
Have you tried Kamikaze?
http://www.kamikazetoysandhobbies.com/home.htm
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 10-25-2011, 10:26 PM   #3878
tha Beast's Avatar
Originally Posted by nitrodude View Post
yup, no luck though
REFLEXRACING
Old 10-26-2011, 12:22 AM   #3879
EEL Monster's Avatar
When running recently at the Oz titles, I made sure the car weighed in at least 15g overweight (1740g) dry with new race tyres and no DLS which meant throwing 25g ballast on the chassis
When I took another 5g off it, the scrutineer let me know that the car was only 3g overweight after the race and I needed to be careful not to go underweight through tyre wear
I run Xceed composite gears in the rear diff and ti turnbuckles all round
The composite diff performed admirably for all 5 days of racing
Serpent 733TE / Reds M3T
LRP S8BX Team / Go MP5 7pt
Tamiya F104 Pro
EEL Monster is offline   Reply With Quote
Old 10-27-2011, 11:41 AM   #3880
lil-bump's Avatar
Is your minimum weight 1725?
Elliott Hart
Serpent America
Desoto Racing Team
Old 10-27-2011, 06:26 PM   #3881
Our min weight is 1725g
Tamiya F104 Pro
Old 10-30-2011, 12:18 PM   #3882
rias5037's Avatar
guys, do you know what to look for when striping gears other than mesh, today i went through two 1st gears and then a 2nd gear on the final. My meshing was spot-on on both gears and im running the old gearbox with a pro oneway, cant really figure whats going on?
Serpent 747, Max .12 xxl3, Nova 2630, Contact-rc.
rias5037 is offline   Reply With Quote
Old 10-30-2011, 03:31 PM   #3883
have you checked for broken engine mount
pinklady is offline   Reply With Quote
Old 10-30-2011, 05:33 PM   #3884
lil-bump's Avatar
If you strip first gear I would look for a faulty oneway. The other time I strip 1st gear is because I wore my tires too low and in a deep turn 1st gear actually hit the ground. For second gear I would check the engine mounts and for a bent chassis near the rear of the car.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 10-30-2011, 08:53 PM   #3885
Team Chump's Avatar
I would look for worn pinions, I've had the car eating spur gears when the pinions were tired (even though they didn't look too bad at a glance)......changed to new ones and problem solved.
Walter R/C
Serpent
Reds Racing
Podified Race Fuel
Team Chump is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
