Old 09-12-2011, 11:30 AM   #3841
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Of course!!!
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 09-18-2011, 07:59 PM   #3842
EEL Monster's Avatar
Got my TE kit on Friday!!!
Only got to build the FF and RR assemblies and the trans/brake bulkheads as had a 2 day race and couldn't get it ready in time
Looks good so far aside from the usual couple of missing bits you get with a new car kit
Serpent 733TE / Reds M3T
LRP S8BX Team / Go MP5 7pt
Tamiya F104 Pro
EEL Monster is offline   Reply With Quote
Old 09-19-2011, 04:28 AM   #3843
The TE is built! The only thing missing was rear swaybar bearings
One of the delrin inserts for the trans was cracked, but not bad enough so it can't be used. The guys at Walter RC are already on it
Really nice car!!! Love the hardcoat chassis
The 2speed clutch shoes are a bit tight, but nothing a tank won't fix I can't wait to have a trans that doesn't crap itself
Tamiya F104 Pro
Old 09-19-2011, 07:01 AM   #3844
lil-bump's Avatar
Trader Rating: 83 (100%+)
Kool... I should have mine in a couple of weeks.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 09-20-2011, 12:06 AM   #3845
hi eel monster,
already run mine and found that new gearbox is no better then the old one at this stage. the only benefet is that it is neater and has a 53 tooth spur gear.my lap times haven't changed at all.but after seeing the new MTX-5 go,holly crap it's fast
andy733 is offline   Reply With Quote
Old 09-20-2011, 01:20 AM   #3846
As seen in this forum, the MTX-5 weighs 1685g only and my 733evo with DLS weighs up to 1850g. Not sure if that makes a difference or maybe the MTX-5 figures are not correct.
Yoshimon is offline   Reply With Quote
Old 09-20-2011, 02:30 AM   #3847
Suspended
It depends on what weight the servos , body , and dls extras add to the car . If you switch to low profile servos , and light weight body , you will lose 60+grams !!! After that switch from nimh pack to lipo and you can lose another 35+grams, and get a lightweight screw set to loose another 20grams, all of which puts you at 1735grams close enough to the 1725gram minimum weight .......
bertrandsv87 is offline   Reply With Quote
Old 09-20-2011, 06:26 AM   #3848
lil-bump's Avatar
Thats heavy I run a lipo no DLS and mine varies from 1735-1750 depending on what engine and pipe combo I run. I run standard servos KO and futaba.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 09-20-2011, 07:24 PM   #3849
In my current setup, I used one KO2413 (low profile) for steering and one standard servo for throttle (because low profile servo cannot fit due to the servo horn position). Half of the screws are titanium screws. LI-FE battery with ballast (35gram) for weight balance. No DLS. OS-XZ speed engine. The ready to race weight (ie with lexan body, wheels and no fuel) is still 1780gram.
I can use small Li-po battery to save even more weight, but the left and right side balance will be upset quite a bit.
Old 09-20-2011, 11:07 PM   #3850
With my original 733 I got the weight down and near perfect distribution
Savox SC-1251 Low Profile x2, Ti screws for all but chassis, Ti turnbuckles, Ti wheelnuts, comp gear rear diff, ceramic bearings, EDX 1100Mah LiFe RX pack, P56N L/W body
I'll have to weigh the TE when the engine's in
PS. I put the SL6 into the old car. Will be running it this weekend at MRCCR at Lilydale so I hope alls good. The 2 speed shoes seem too tight in my opinion. Tighter then I've seen before, but I'm relatively new to all this, and have only ever worked on the old LC 2-speed
Tamiya F104 Pro
Old 09-21-2011, 09:10 AM   #3851
Originally Posted by TEMsport View Post
I used the new SL6 gear box this weekend and it was awesome, super smooth and consistent gear change, very tough, easier to service and great value when you consider it comes with full set of 6 spur gears.
Best Mod ive ever fitted to my 733!!!
I had the Evo version & wanted to upgrade the 2 speed to the SL6. Do i have to upgrade any of other parts to for the SL6
kickertrf is offline   Reply With Quote
Old 09-21-2011, 09:17 AM   #3852
Nothing else needed
Old 09-21-2011, 07:43 PM   #3853
Originally Posted by Serpent-Dan View Post
Nothing else needed
Thanks Dan.
does it come with instruction manual?
Old 09-21-2011, 08:42 PM   #3854
Can be downloaded
Old 09-25-2011, 04:35 AM   #3855
Default New Car
Hey Guys, I am thinking of getting a TE kit for one of the boys to run.
Could you please tell me what (if any) option/spare parts are a must have, or is it a goer strait out of the box.
EG: Are the kit springs OK for a bumpy/ med grip track? (Lillydale)
Warren Maker is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
