Old 08-20-2011, 05:35 PM   #3811
Originally Posted by RC MARKET View Post
is New SL6 2 speed !
can some one please tell me when the new gear will be available????
andy733 is offline   Reply With Quote
Old 08-21-2011, 04:28 AM   #3812
Originally Posted by Pattojnr View Post
you will need to run a cone washer underneath, and i believe a ground down head of the screw. this prevents the plastic cup to bind under and over . if you see where it binds, you will know.
Cone washer is fitted and its not binding on the screw head its just purely the fact that the joint wont go to the angle required, is there another joint that would solve the problem, i have tried modding the plastic cup but it just develops lots of play???
TEMsport is offline   Reply With Quote
Old 08-21-2011, 04:32 AM   #3813
Pattojnr's Avatar
Trader Rating: 19 (100%+)
not sure. but are you using the rod ends with a marking 'TOP' on them ?
these are offset, so shouldnt be binding.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 08-21-2011, 06:35 PM   #3814
EEL Monster's Avatar
Are you refering to when the camber link is at the lowest hole on the camber plate the suspension without shocks or swaybars appears to bind?
If so, I've noticed somthing similar on my EEL, but it's beyond normal suspension travel for me
I think you'll find it's got to do with the geometry of the camber link compared to the lower A arm
Serpent 733TE / Reds M3T
LRP S8BX Team / Go MP5 7pt
Tamiya F104 Pro
EEL Monster is offline   Reply With Quote
Old 08-23-2011, 01:28 AM   #3815
Julius's Avatar
What most people including me do, is heat the outer nylon ball joint and bend it. This reduces the angle of the ball joint.
I do it by taking off the link, hold the "eye" in a pair of flat pliers, heat the nylon next to the pliers and bend the joint. Hold the force untill the joint cools and you're done.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 08-23-2011, 01:09 PM   #3816
Thanks that is the sort of fix i was looking for!!
Old 08-23-2011, 02:02 PM   #3817
lil-bump's Avatar
Trader Rating: 83 (100%+)
Anyone have a price and part number on the SL6 gearbox kit??
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 08-24-2011, 09:36 AM   #3818
804235 Gearbox set SL6 upgrade
Tamiya F104 Pro
Old 08-24-2011, 05:08 PM   #3819
djiewie's Avatar
The new geasbox looks al lot like the NT1 gearbox. Better to copy good than to design bad i think. Congratulation Serpent for a good product. What to think about a new fueltank , i have a idea..... Look at capricorn and Km , they know how you do it right.
Now don`t go killing me , just kidding.
Wonder why they took so long though.
djiewie is offline   Reply With Quote
Old 08-24-2011, 06:28 PM   #3820
nitrodude's Avatar
Dont feed the troll...
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 08-24-2011, 08:45 PM   #3821
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Smh!!! Nothing like it!
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 08-26-2011, 03:17 AM   #3822
RC MARKET's Avatar
today release !
Serpent 733 1/10 200mm touring-ser-804001.jpg   Serpent 733 1/10 200mm touring-ser-804235.jpg   Serpent 733 1/10 200mm touring-ser-804241.jpg   Serpent 733 1/10 200mm touring-ser-804248.jpg
RC MARKET is offline   Reply With Quote
Old 08-26-2011, 09:18 PM   #3823
can anyone out there remember the part no. for the wheel spacers used on the hubs from the 720. these went between the bearings to support the axles
Old 08-26-2011, 10:23 PM   #3824
Pattojnr's Avatar
just checked my 720, no inserts on them. i honestly cant remember that far back. lol
Serpent - Walter RC
Old 08-28-2011, 03:22 AM   #3825
thanks mate for trying and by the way your not that old. lol. will try to email serpent about that idea tonight as well
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
