Old 07-13-2011, 07:16 AM   #3751
lil-bump's Avatar
Trader Rating: 83 (100%+)
Originally Posted by newera152 View Post
I have a Rossi R12 pixy motor which is the best plugs for this motor
I would go with a hot plug. The head clearance on the turbo model is around .7 -.8mm with no shims installed.
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 07-13-2011, 09:08 AM   #3752
newera152's Avatar
Default plug
most have said cold #7 you say hot do you have this motor and it's a non-turbo motor, i have been blowing glow plugs, i put the motor in a new car with new pipe and i keep blowing the plug, i was told to add a 0.2 shim to the head.
Custom RC Airbrushing by era1FXcustoms
Please email me at [email protected] for paint pricing, ordering and questions.
newera152 is offline   Reply With Quote
Old 07-13-2011, 09:20 AM   #3753
lil-bump's Avatar
I have the turbo model Pixy. I run a hot or medium plug.(a hot runs better using 16% Byrons). The stock carb on this engine is total junk. The head clearance is so great that any plug cooler than a MED and the engine will not idle. I only use this engine for practice. I would not trust this engine for even a club race. Again this is for the turbo head model Pixie not the standard
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 07-13-2011, 09:24 AM   #3754
nitrodude's Avatar
I had to help a friend tune that motor years ago, we're talking 2002, and yes, the carb is JUNK! If you're blowing plugs you probably need to add shims for more head clearance, or whats more likely, your conrod is about to go. Try adding shims, and if you can find a rod, replace it.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 07-13-2011, 09:33 AM   #3755
newera152's Avatar
Thanks guys, I'm just getting back into nitro, so I didn't want to spend any money on a new motor yet.
Old 07-17-2011, 01:21 AM   #3756
EEL Monster's Avatar
I'm having a really weird issue with the transmission
For the last couple of race meets my transmission's been slipping
It got so bad race be4 today that it lost all drive, so I changed the 1st gear 1way and the clutch pad.
That made it better, but in one of the heats and one of the mains today on the same corner, it slipped for a second, then went again. Barely noticeable, but definately there, but only did twice all day
It's a high load right hander into a chicane that leads onto the straight. When you get on the throttle to change direction in the chicane to power out for the straight.
Is it possible that the trans shaft is worn enough for the 1 way to slip on it under very high load?
Serpent 733TE / Reds M3T
LRP S8BX Team / Go MP5 7pt
Tamiya F104 Pro
EEL Monster is offline   Reply With Quote
Old 07-17-2011, 02:40 PM   #3757
time for a rebuild
Ghett0 is offline   Reply With Quote
Old 07-17-2011, 04:35 PM   #3758
Pattojnr's Avatar
Trader Rating: 19 (100%+)
id be looking at your one way bearing on your 1st gear holder, and the hub for your 2 speed shoes. when you hit the throttle and the engine revvs but no drive, the one way bearing is slipping. make sure all your pins are still in place , clean it, and oil it with one way lube.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 07-17-2011, 10:43 PM   #3759
I think I've figured the trans slip out
It is the 1way, even though it's new
I've heard that the 1way is an issue on 733's & realised, when I first got the car (my first RC race car) I didn't have lube for the 1way so put it together dry
The trans was great. Never skipped a beat!!!
It then occured to me that it's only been slipping since I've been lubing the 1way so I'm gonna go back to not lubing it and see how it performs
Tamiya F104 Pro
Old 07-18-2011, 02:41 AM   #3760
Team Chump's Avatar
Not sure what lube you are using but give the Hudy one way bearing lube a try..... have never had an issue after i started using it.
Walter R/C
Serpent
Reds Racing
Podified Race Fuel
Team Chump is offline   Reply With Quote
Old 07-18-2011, 04:48 AM   #3761
Les
Les's Avatar
Default Bumper
What front bumper (beside standard 733) do some use on their serpent, sick of replacing standard ones.
Cheers
Serpent S411 4.0 13.5T D4
Kyosho V-ONE S3, RB Rota-Start
Sanwa MT4S
Les is offline   Reply With Quote
Old 07-20-2011, 03:15 AM   #3762
Les
Les's Avatar
Cheers
Thanks for all the suggestions but i have fixed the problem, purchased a new Shepherd Velox.
Sanwa MT4S
Old 07-20-2011, 04:49 AM   #3763
lil-bump's Avatar
Now you'll be replacing front uprights.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 07-20-2011, 04:54 AM   #3764
M7H
M7H's Avatar
Originally Posted by lil-bump View Post
Now you'll be replacing fronts uprights.
Pass you soon...
But atleast he solved his bumper problem.
Serpent
M7H is offline   Reply With Quote
Old 07-20-2011, 06:06 PM   #3765
Pattojnr's Avatar
thats dissapointing to hear Les.
am awaiting on a reply to see if the team C conversion bumper is available seperately.
Serpent - Walter RC
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
