Old 06-05-2011, 09:14 PM   #3691
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by EEL Monster View Post
Having issues with ride height & the Serpent springs
The local club track is for these 200mm pro cars like Monaco is to F1. The clubs even approved Lola bodies to make the track navigable
Running yellow springs on the rear, but have trouble getting enough ride height out of the rear otherwise damp is good spring rate is good
Can't quite get the ride height I want but the springs adjusters are on they're max. The car decks out over a couple of bumps up the straight which is degrading the trailing edge of the chassis and screws
Do Serpent make Yellow springs in 27mm length, or is this all normal and a chassis is an item that gets replaced every year and the screws every few races?
Did set my best race time though
is your problem just at the rear ? you need to run the 27 springs on the rear, and if you already are, then try the longer shock ends. just make sure your shock doesnt bottom out with the longer ends.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 06-05-2011, 09:28 PM   #3692
Pattojnr's Avatar
Wa states run over the weekend. happy to report a TQ and BIG win with the 733. 37 lapper qualifier, and a 104 lap Final saw a 22 lap win. the 733 was faultless the way it drove, its consistancy on a VERY HiGH tyre wear track. the DLS i had concerns to run for 30 mins, but last few laps with no tyres left, was still hitting my average lap times. very big thakyou to Serpent for an awesome car, and Walter RC for their support with a very nice product.
Serpent - Walter RC
Old 06-05-2011, 11:50 PM   #3693
congrats mate on the win,did you use the setup that you sent me or did you make any changes to it. try mounting the dls brackets on the lower arm to give you a similar set up to the 966 rear shock mount.also looking at trying to reverse the dls mounting position and the sway bar mount on the front of rear arm to see what affect it will have on the way the dls performs
andy733 is offline   Reply With Quote
Old 06-06-2011, 12:04 AM   #3694
Pattojnr's Avatar
same setup i sent you. but i tried 800cst in the front shocks. and left it like so. no reason to change, as it is planted so much. was like i still had a groove set in the track from last time.
Serpent - Walter RC
Old 06-06-2011, 12:18 AM   #3695
thanks for the info, will hopefully be running this weekend. have changed the set up slightly from the one you sent me( heavier front sway bar and springs) i'm also thinking of using L27 springs on the front as well at some stage
Old 06-06-2011, 12:28 AM   #3696
dawin2122's Avatar
please tell me a battery replacement for a serpent 733 nicdn,nihm or lipo thanks
dawin2122 is offline   Reply With Quote
Old 06-06-2011, 01:17 AM   #3697
Pattojnr's Avatar
i use LiFe battery packs. easy and they last all day .
Andrew, harder front springs and front bar ? 2.5 front bar and i cant get any steering out of the car. i used 37F 40R to set my TQ was just as planted. i also use Xceed Foams for both tourer and 8th. there seems to be alot of varience in shores from brand to brand, i am very happy with the Xceed tyres.
car was just as good as last years last race , i also used a RS4 Blitz this time, same feel as the Cruizer, but i rekon a bit more corner speed with the RS4 .
after the race ended, i waited for all cars to go past on inlap, and for the life of me, could not get the car to spin up, so no Donuts for me at the end of the race. thats how much rear grip i have.
Serpent - Walter RC
Old 06-06-2011, 02:36 AM   #3698
Team Chump's Avatar
Congrats on the result Patto.
Must have been a good weekend to be driving a 733, I also managed to get up for a win at R2 of the QLD interclub held at the Sunshine Coast track. First time i've run there so pretty happy.....the car was awesome all day, very stable and easy to drive.
Walter R/C
Serpent
Reds Racing
Podified Race Fuel
Team Chump is offline   Reply With Quote
Old 06-06-2011, 03:48 AM   #3699
Pattojnr's Avatar
well done, its always a good weekend to drive a serpent.
Serpent - Walter RC
Old 06-06-2011, 04:27 AM   #3700
EEL Monster's Avatar
Is there such a thing as a 27mm YELLOW Serpent shock spring for the RCC shocks?
I can't find it on the web under any of the cars part listings or manuals
Part # anyone?
Serpent 733TE / Reds M3T
LRP S8BX Team / Go MP5 7pt
Tamiya F104 Pro
EEL Monster is offline   Reply With Quote
Old 06-06-2011, 04:34 AM   #3701
Pattojnr's Avatar
Part # anyone?
new or old springs ?
Serpent - Walter RC
Old 06-06-2011, 04:38 AM   #3702
Pattojnr's Avatar
part number for new 27 yellow spring is #160321 rating is 2.8.
Serpent - Walter RC
Old 06-06-2011, 04:47 AM   #3703
using 2.5 but still using orange springs the only difference i can see is that using p37 body (seems to have more turn in on low speed but still lacking high speed turn in) will try Xceed rs4 insteed and may try p56 as well also have gone thru and rejigged rear end,so hope to see some results this weekend
Old 06-06-2011, 04:55 AM   #3704
Thanks for the part # Patto!!!! I was looking everywhere for that
I hope Walter's have got it
Tamiya F104 Pro
Old 06-06-2011, 04:57 AM   #3705
Pattojnr's Avatar
i ran the blitz RS4 . i could not get the front to turn in off the sweeper with the 2.5 bar. car rotates well with the spool when tapping the brake when needing to tightly turn, changes direction quick enough for me .
Serpent - Walter RC
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
