Old 05-30-2011, 06:15 PM   #3676
quietstorm76's Avatar
Originally Posted by andy733 View Post
thanks for yhe reply.have already used the v1 mounts and the 966 pivot balls to great success (thanks patto). by using the dls brackets on the lower arms it gives you that 2-3mm on the lower shock position.also trying V10 axles in the front to give a little bit more tuning options due to the xtra shimming on the axle similiar to the 966
V10 axles, interesting!!! I'll have to look into that. I'm going to try the DLS brackets, what I'm using now were custom made by another racer and the angle is different.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 05-30-2011, 06:19 PM   #3677
Originally Posted by georgie0125 View Post
dls bracket use in the front or rear?
Rear lower arm
Primary Weapon: ?
Secondary Weapon: ?
Old 05-30-2011, 07:13 PM   #3678
liteweight's Avatar
guys anyone could tell me or link for starting setup for 733
thanks
John's Mobile R/C Raceway outdoor racing
"The New Coliseum Carpet Track"
"MRH" Carpet racing
"Xray T3 2012"
liteweight is offline   Reply With Quote
Old 05-31-2011, 04:42 AM   #3679
thanks
Box setup is good with 37f/40r tires. Tune from there.
http://www.serpent.com/product/804000/setups/
Primary Weapon: ?
Secondary Weapon: ?
Old 06-01-2011, 04:51 AM   #3680
hi mate, when using the dls brackets mount them so that you can add another fixing point into the plastic of the lower arm where the shock mounts to.To use the v10 axles you have to buy the front and rear hubs (uprights) and mount them on the car to make it work
andy733 is offline   Reply With Quote
Old 06-01-2011, 06:36 AM   #3681
Les
Les's Avatar
Default Rain
Hey Andy, R U getting much racing in it seems to be raining a lot over there
Cheers
Serpent S411 4.0 13.5T D4
Kyosho V-ONE S3, RB Rota-Start
Sanwa MT4S
Les is offline   Reply With Quote
Old 06-01-2011, 11:05 PM   #3682
SMcpot's Avatar
Trader Rating: 22 (100%+)
Exclamation
Hey fellas,
I figure that at least a few of you in this thread have had a 710 at some point (probably a helluva long time ago!) If any of you still have unused belts, pulleys, spurs, pinions, and especially gear diff cases, kicking around, I'd like to take them off your hands. Please PM me with anything you might have.
SMcpot is offline   Reply With Quote
Old 06-01-2011, 11:58 PM   #3683
Cheers
les the only racing i have done of late is leaves in the local creek as it has rained every race day.hopefully next weekend if we have enough numbers in 1/10th.what about yourself?
Old 06-02-2011, 03:05 AM   #3684
Les
Les's Avatar
Arrived Qld 18/05 raced Brendale (Awsome Track) 22/05 and racing this Sunday 24Deg/ Sunny, does rain a little bit but it seems to dry out in 5 minutes over here
Hope you have better luck next meeting
PS.. R U coming over for the QLD State Titles.
Cheers
Sanwa MT4S
Old 06-02-2011, 07:50 AM   #3685
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Cheers
lets hope the rain holds of this weekend in Bunbury ! be my first Nitro run since October last year cars are just about ready to go.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 06-03-2011, 01:15 AM   #3686
Cheers
sorry mate not luck there,can't even go to the nats this year.to patto hope it doesn't rain, best of luck at your state event.
Old 06-03-2011, 03:20 AM   #3687
Les
Les's Avatar
Should be all good maybe a light shower, good luck with your racing Patto in 1/10th & 1/8th
See you at the Qld States
Cheers
Sanwa MT4S
Old 06-04-2011, 05:21 PM   #3688
hi guys,anybody had the luck of running the new gearbox yet? also anybody know when these parts will become available and how much?
Old 06-05-2011, 08:54 PM   #3689
EEL Monster's Avatar
Having issues with ride height & the Serpent springs
The local club track is for these 200mm pro cars like Monaco is to F1. The clubs even approved Lola bodies to make the track navigable
Running yellow springs on the rear, but have trouble getting enough ride height out of the rear otherwise damp is good spring rate is good
Can't quite get the ride height I want but the springs adjusters are on they're max. The car decks out over a couple of bumps up the straight which is degrading the trailing edge of the chassis and screws
Do Serpent make Yellow springs in 27mm length, or is this all normal and a chassis is an item that gets replaced every year and the screws every few races?
Did set my best race time though
Serpent 733TE / Reds M3T
LRP S8BX Team / Go MP5 7pt
Tamiya F104 Pro
EEL Monster is offline   Reply With Quote
Old 06-05-2011, 09:11 PM   #3690
lil-bump's Avatar
Trader Rating: 83 (100%+)
Run the long springs in the rear . Check your droop setting.
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
