Old 05-05-2011, 06:14 PM   #3601
EEL Monster's Avatar
Has anyone tried lightening light transmission parts like CSO lightened main shaft, Xceed light diff kit etc
Even the light brake disc and pulley which rotate on the main shaft.
It would make sense that weight removed from the drivetrain would make a bigger difference to performance then from the chassis, but is this really the case?
Also, little bit concerned that by fitting too many lightened parts I'll come up underweight
Help anyone?
Serpent 733TE / Reds M3T
LRP S8BX Team / Go MP5 7pt
Tamiya F104 Pro
EEL Monster is offline   Reply With Quote
Old 05-05-2011, 06:23 PM   #3602
nitrodude's Avatar
Help anyone?
If its too light, just add weight.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 05-05-2011, 06:28 PM   #3603
Send a message via Yahoo to motojon
Its better to remove weight from the drive train and add to the chassis
My Gpa(RIP)
motojon is offline   Reply With Quote
Old 05-06-2011, 01:59 AM   #3604
Les
Les's Avatar
Help anyone?
Think its pretty hard to be under weight with a 733 you should be safe
Les is offline   Reply With Quote
Old 05-06-2011, 02:33 AM   #3605
Thanks for the input guys!!
Gonna start putting a list together of all the light parts I can get for the tranny and see how that goes
Be interesting to see how much weight can be saved from the drivetrain and how much difference it makes
Also might make the rear a bit lighter, as with solid front axle, it's a bit rear heavy
Tamiya F104 Pro
Old 05-06-2011, 08:29 AM   #3606
lil-bump's Avatar
Trader Rating: 83 (100%+)
Not sure if it was done by design ,but the 733 main chassis plate is about 25-30 grams heavier than other brands. Not sure if this is a bad thing because this puts the weight extremely low. I've got an aftermarket chassis on mine and ready to race weight can be as low as 1730 grams depending on which engine and pipe I use. Currently with my Nova 3sct and 2630 pipe I'm @ 1745 grams. Body is a P37 "lightweight"
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is online now   Reply With Quote
Old 05-06-2011, 09:17 AM   #3607
quietstorm76's Avatar
I got my car down to 1742g race ready with DLS.
Xceed Chevy body
IDM EVO 4 engine/IDM 2617 pipe (IDM is 8g lighter than my Nova Flash/ pipe is about 7 grams lighter than my nova 2652)
Contact Tires standard wheels (57fr 59r)
LiFe battery
Low profile Futaba servos
TI screws across the top
Xceed brake disk
Capricorn diff gear set.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 05-06-2011, 09:51 AM   #3608
lil-bump's Avatar
I forgot to mention I have a 800 mah lipo that only weighs 42 grams. My aftermarket chassis weighs about 10 grams lighter than stock. I have not had a chance to see how it runs.It won't stop raining on the weekends.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 05-06-2011, 11:51 AM   #3609
rccobra705's Avatar
Xceed Chevy body
LiFe battery
Xceed brake disk
Hi What LiFe battery are you using?
rccobra705 is offline   Reply With Quote
Old 05-06-2011, 03:13 PM   #3610
This one
http://www.nexusracing.com/product_i...oducts_id=3142
Primary Weapon: ?
Secondary Weapon: ?
Old 05-07-2011, 05:08 PM   #3611
Team Chump's Avatar
Default 733 Evo DLS
Hoping someone can help me with this one..... regarding the carbon rear camber plate supplied with the 733 Evo, for the DLS it says to just use the lowest holes on the original camber plate. This seems strange as I have been running an older 733 and when I added the DLS it came with a proper rear camber plate designed for the DLS. When I compare both plates it is a totally different pivot point.......Is this correct or should I just get the proper plate for the DLS??
Walter R/C
Serpent
Reds Racing
Podified Race Fuel
Team Chump is offline   Reply With Quote
Old 05-07-2011, 06:38 PM   #3612
rc carnage's Avatar
I think you need to learn how to set up the car first
rc carnage is offline   Reply With Quote
Old 05-07-2011, 11:18 PM   #3613
Pattojnr's Avatar
Trader Rating: 19 (100%+)
the pivot point is quite important, and will change how the whole system works. so to say learn to setup the car, is an understatement.
Team Chump, send me a PM with your Email, and i can forward you a starting setup and see how that goes. Cheers, Patto.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 05-08-2011, 12:03 AM   #3614
Les
Les's Avatar
Howdy, R U going to run the Evo at Brendale.
Cheers
Old 05-08-2011, 01:29 AM   #3615
Team Chump's Avatar
Patto, thanks mate but i think you may have gotten the wrong impression! RC Carnage and i race against each other at our club and he's just putting s**t on me...... I have a setup i'm happy with.
I was just making the point that the Evo doesn't come with the correct camber plate for the DLS, (even though the DLS comes in the kit) only the standard one and it says to use the bottom set of holes when using the DLS. And yeah the pivot point is very different when comparing to my older 733 with DLS.......wondering why Serpent have done this??
Walter R/C
Serpent
Reds Racing
Podified Race Fuel
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
