Old 03-20-2011, 04:01 PM   #3511
ugglasdav's Avatar
hi guys have a bit of a problem with my set up on my 733. i used the dls for the first time ever and it seemed like i loss grip. when i was going mid way through a bend the car would just spin 360 degrees. i even put the springs on the rear at the lowest position and the front at the highest and it made no differece. fast and slow corners it was lossing rear end grip heres abit of info on my set up dls without ARB, 3 cam on rear, 2 cam on front. 2.5 toe in on rear, 1 toe out on front. blue springs in rear. red in front. 650 cst oil all round. 100k in front, 50k in rear. hope that helps
>Shepherd Velox V8/Team associated TC5R
>>IDM 2011/ Speed passion/Much More
>>>Sanwa m11x
ugglasdav is offline   Reply With Quote
Old 03-20-2011, 09:06 PM   #3512
quietstorm76's Avatar
Blue front spring
Start with the orange rear spring
What pistons?
Check for binds
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 03-20-2011, 09:11 PM   #3513
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Originally Posted by quietstorm76 View Post
Blue front spring
What pistons?
Check for binds
Blue front, Orange rear? With all the rear traction DLS is supposed to generate, something odd is happening??
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 03-20-2011, 09:30 PM   #3514
Yeah I know but I'm getting him back to a base setup so we can figure it out. By the way are you helping him or still doubting the DLS?
Primary Weapon: ?
Secondary Weapon: ?
Old 03-20-2011, 09:35 PM   #3515
Michael_T's Avatar
I tried the DLS twice and have since removed it.
Old 03-20-2011, 09:41 PM   #3516
At least you finally tried it, now you can have an opinion of it based on experience.
So what do you think may be happening to ugglasdav car mid corner?
Primary Weapon: ?
Secondary Weapon: ?
Old 03-20-2011, 09:47 PM   #3517
Michael_T's Avatar
Expensive opinion!
I would go heavier shock oils, lighter rear diff, check dls rod lengths are equal, etc etc...
Old 03-20-2011, 10:22 PM   #3518
Pattojnr's Avatar
Trader Rating: 19 (100%+)
i think for starters swap springs, front to back, and take off the shocks from bottom arms. check smoothness of dls. then make sure you have enough ride hieght. DLS needs 1 or 2mm more hieght, as it will get very unsettled if it bottoms out all the time.
Nova , i have no idea why you think the dls dont work. you must be doing somthing wrong. it is a great piece of gear.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 03-20-2011, 10:39 PM   #3519
Michael_T's Avatar
Not saying it doesn't work. Just found you had to really upset the balance of the car to get it to work at our track.
To give you an idea, Ric runs 42s all arounds at our track! The others run 40s all round! It will probably work well on other tracks, but because Moorebank is fast/big/flowing and grippy, not suitable imo
Old 03-20-2011, 10:52 PM   #3520
Originally Posted by Pattojnr View Post
just found the manual.
throttle ATV is correct to adjust. you have to have it (throttle selected) and hold full throttle while pressing the - key to take out the travel, and same for brake.
thanks patto,
Also any more ideas with using the DLS system in regards to set ups and the like
andy733 is offline   Reply With Quote
Old 03-21-2011, 04:28 AM   #3521
Pattojnr's Avatar
Originally Posted by andy733 View Post
thanks patto,
Shoot me an Email Andrew, i seemed to have misplaced your address. Cheers. Patto......
Serpent - Walter RC
Old 03-21-2011, 01:03 PM   #3522
guys, i recently ordered a whole bunch of spur gears for the 733. some of these spur gears have the letter "X" etched on them.
I take it these are supposed to be the new/improved batch?
implusepro is offline   Reply With Quote
Old 03-21-2011, 01:32 PM   #3523
lil-bump's Avatar
Trader Rating: 83 (100%+)
You got any pics???
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 03-21-2011, 02:33 PM   #3524
Default 1st gear hub Breakage
Hi Guys,
Ran my 733 evo for the first time yesterday and was very impressed,
Run the car again today about 10 laps in lost drive and once i collected the car from the infield had a quick check found the aluminium oneway hub that holds 1st gear had cracked thus releasing its hold on the oneway bearing!
Is this common, will i need to carry plenty of spares or is there a fix?
TEMsport is offline   Reply With Quote
Old 03-21-2011, 02:39 PM   #3525
lil-bump's Avatar
Originally Posted by TEMsport View Post
Hi Guys,
Never had this happen. You must of hit something very hard.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
