Old 03-02-2011, 10:27 PM   #3466
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
Default KO Propo Race Setup
I wrote the setup down in case you guys can't read it from my previous post.
Here it goes:
Front:
Roll center: Higher
Shock position: lower
Shocks: blue spring, 1 hole piston, 1,000 oil
Gear diff: 100,000 oil
Swaybar: 2.5
Tires: Matrix Carbon 37 shore @ 61mm
Camber left and right: -2 degrees
Toe: 0.5 out
Downstop: -1
Ride Heigh: 7mm (measured with car on setup station)
Caster: 3mm
Wheel base: 1mm spacer behind the lower arm
Width: 198mm
Rear
Roll center: middle
Upper pivot point: lowest-in
Upright mounting: 1mm shims, in position
Shock position: second from the lowest
Shocks: pink spring, 2 hole piston, 1,000 oil
Gear diff: 50,000 oil
Swaybar: 2.3
Tires: Matrix Carbon 42 shore @ 63mm
Camber left: -4 degrees
Camber right: -3 degrees
Toe: 2.5 in
Downstop: 2
Ride Heigh: 8mm (measured with car on setup station)
Wheel base: 0mm spacer in front of the lower arm
Width: 200mm
Body: Team Titan Blitz Cruze
Pinion Gears: 17-22
Spur Gears: 59-56
Let me know if you have any questions....
Walter Diaz
wad is offline   Reply With Quote
Old 03-02-2011, 10:47 PM   #3467
lil-bump's Avatar
Trader Rating: 83 (100%+)
Okay... what is part 804228???
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 03-02-2011, 11:20 PM   #3468
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by andy733 View Post
Thanks patto,
Could you give me anymore tips with the 733 as I believe both les and myself could use some,also looking to try the X-ray clutch at some stage, what do you think?
the serpent clutch is fine. i have no problems with the 10th scale clutch. the 8th is a different story.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 03-02-2011, 11:55 PM   #3469
Pattojnr's Avatar
Pass you soon...
where did you get this # from bump ?
Serpent - Walter RC
Old 03-02-2011, 11:55 PM   #3470
Team Kamikaze's Avatar
Pass you soon...
Connector-set RR 733 (2+2)
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 03-03-2011, 02:43 PM   #3471
lil-bump's Avatar
It came from post #3433. Sam has straighten it out. I been waiting for the connectors to be released. These tie the rear bulks to the 2-speed shaft mounts for the muilti-flex system on the 733.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 03-04-2011, 12:30 AM   #3472
gfilos's Avatar
has anyone faced the problem when mounting the diff gear on the outdrive
and tighten the 2mm screw, then the outdrive has some binding? I think the
cause is that the shim under the gear which is 3mm should be 2mm or 1mm
so as to provide some gap inbetween. I had to use my dremel to take some
plastic on the diff case to provide some gap so the outdrive spins freely. Although
this is only happening on one diff. the other is just fine...
Serpent 720 09 mega zx 12 dsII+, Serpent 733 nova 353 tuned/sirio XXXV
Futaba, Graupner, Hudy, RB fuel
gfilos is offline   Reply With Quote
Old 03-07-2011, 08:33 AM   #3473
lil-bump's Avatar
Here it goes:
Front:
Roll center: Higher
Swaybar: 2.5
Toe: 0.5 out
Downstop: -1
Caster: 3mm
Width: 198mm
Rear
Roll center: middle
Swaybar: 2.3
Toe: 2.5 in
Downstop: 2
Width: 200mm
Pinion Gears: 17-22
Spur Gears: 59-56
What was your ackermann???
Elliott Hart
Serpent America
Desoto Racing Team
Old 03-07-2011, 12:07 PM   #3474
also with or without dls?
implusepro is offline   Reply With Quote
Old 03-07-2011, 11:48 PM   #3475
wad
wad's Avatar
I used the long-narrow...
Walter Diaz
Old 03-07-2011, 11:49 PM   #3476
wad
wad's Avatar
No DLS, it was my first time with the car, so didn't have much time to play with it....
Walter Diaz
Old 03-08-2011, 07:32 PM   #3477
iam going to try the dls this sunday for the frist time this is my setup
rear
tou in 3
camber 4.5 left 4 right
diff 30,000
high rollcenter
30 shock oil
red shock spring
any advise thanks
georgie0125 is offline   Reply With Quote
Old 03-09-2011, 08:00 AM   #3478
enjin nak roboh's Avatar
my 733 coming soon..
enjin nak roboh is offline   Reply With Quote
Old 03-09-2011, 03:50 PM   #3479
D-man's Avatar
rear
tou in 3
diff 30,000
high rollcenter
30 shock oil
red shock spring
any advise thanks
30wt shock oil ??? What brand shock oil?
What hole piston
high roll center???
If that does not work for you try..
40 to 50,00 rear diff.
900wt oil xceed 2 hole piston.
Everything that you have seems to be to light.
D-man is offline   Reply With Quote
Old 03-09-2011, 09:24 PM   #3480
thanks d-man for the inf. i cant whait to sunday. big day for me i have this 733 since the come out but my last 3 event a use another bran of car but i am a serpent fan .
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
