Old 03-01-2011, 08:36 PM   #3451
Team Kamikaze's Avatar
Originally Posted by Novarossi View Post
I think there is some confusion here. The way I am reading it, he is referring to the screws that holds his diff gears (ie, the screw that goes into the outdrive) is coming loose.
I have seen this happen several times, it happened to me causing the diff to seize.
As this is metal to metal, loctitie is the fix.
See photo of what I am talking about...
My mistake! got confused, using loctite on the outdrives (804188) is a must.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 03-01-2011, 08:51 PM   #3452
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
I never had any of the issues alot of people post about their 733's. My only problem was the faulty first tank and first run of plastics! Other than that the car was a work horse. My car was the first shipment into the US.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 03-01-2011, 09:23 PM   #3453
rias5037's Avatar
100% right, thats exactly whats happened, im sure locktite is the answer, i did locktite most of the metal to metal screws, guess i never expected that one coming loose.
Serpent 747, Max .12 xxl3, Nova 2630, Contact-rc.
rias5037 is offline   Reply With Quote
Old 03-01-2011, 09:55 PM   #3454
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Try using only 2 bevels, not all 4 bevels also
Just double your oil thickness (ie, if you use 50,000cst normally with 4 bevels, you need to use 100,000cst with 2 bevels). You get a much smoother diff action and get the advantages of weight savings off your drivetrain.
I have been using it for ages, works great....
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 03-01-2011, 10:58 PM   #3455
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
Default 733 Setup
Here is the setup I used at the KO Propo race this past weekend...
Please feel free to ask any questions..
Serpent 733 1/10 200mm touring-733-ko-race-2011.jpg
Walter Diaz
wad is offline   Reply With Quote
Old 03-02-2011, 12:16 AM   #3456
EEL Monster's Avatar
Default DLS and V2 Rear End
Just wanted to know has anyone got any advice on what improvement the DLS and V2 rear end bring to the car in real world terms?
Are they worth the price?
Just raced the car for the first time in std guise and it's pretty amazing outta the box
EEL Monster is offline   Reply With Quote
Old 03-02-2011, 12:44 AM   #3457
Aza088's Avatar
does anyone else have the screw on the rear diff holding the gears together come loose, mine has twice now, anyone have this, any solutions guys?
I had this same problem twice!!!!!!!
Just use some really good lock tight like really good.....
Shepherd | Brilliant RC | Matrix | Maxima | Xceed | KoPropo
www.bluerc.net
www.hobbyexpress.com.au
www.hootrc.com.au
Aza088 is offline   Reply With Quote
Old 03-02-2011, 04:41 AM   #3458
quietstorm76's Avatar
I'm with you on that. I got one of first batch of cars and other than those issues you mentioned I've had only minor issues that was due to my error. I run my car in parking lots, in front of my house and the track and it holds up great
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 03-02-2011, 04:55 AM   #3459
Pattojnr's Avatar
Trader Rating: 19 (100%+)
same. 1st generation chassis and plastics, i have problably broken 2 front bumpers, 3 different arms, and rebuilt the diffs a few times, then replaced with new cases after the 3rd time. i replaced my spurs due to being worn , not stripping.i may have stripped one or 2 in total, one after a crash, and one due to too much flex i put into the car (but not the parts Fault). infact the last race before i sold it, about 1.5 years on, it went the best it ever had.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 03-02-2011, 06:38 AM   #3460
Trader Rating: 8 (90%+)
Is anyone keep track of how much mah they are using in there rx packs? I'm wondering if an 800 mah lipo will do the job of 20-30 minute mains?
Thanks in advance
Houston,Texas
Serpent 733 EVO
Mikes Hobby shop-Porter Texas/ Gulf coast Raceway"Electric Is For Hairdryers"..Eric Koger
Chris [email protected]
Tha Skinny is offline   Reply With Quote
Old 03-02-2011, 07:57 AM   #3461
rias5037's Avatar
What will removing the two bevels help in terms of handling, we normally go 10000 dif oil in the rear, we have a low traction track with lots of bendy stuff only 2 small straights. We use 35 rears and 40 or 38 fronts, got the car running great with help from pattojnr's set.up. Just want to know whats the benefit is of doing it, oh and btw im also running a solid front, no diff.
Old 03-02-2011, 08:08 AM   #3462
stefan's Avatar
Send a message via AIM to stefan
Originally Posted by ugglasdav View Post
does anyone have any other ways of charging the IP 1450 life battery while its still in the car. i have figured out how i can wire it but i cant find a way in which i can charge it. i would have to take the top deck off the car every time if i wanted to charge it.
I just solder a second cable to my battery pack and together with the balancing wire run it between the radio plate and the belt tensioner.
I shaved a little bit of the radio plate to make mre room for the wire.
It's probably not looking to fancy, but it beats taking out the battery for charging..
Serpent 733 1/10 200mm touring-733_wiring.jpg
stefan is offline   Reply With Quote
Old 03-02-2011, 08:12 AM   #3463
DS Motorsport's Avatar
Thanks in advance
30 minutes shouldn't be a problem, I'm getting close to 1 hour out of my 800Mah Lipo pack. However this is with a regulated pack. Also when you run Savox/Team Orion servos the runtime will be greatly reduced because they use a ridiculous amount of power.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 03-02-2011, 01:21 PM   #3464
gearhead_22's Avatar
Send a message via AIM to gearhead_22
that is the same way I have mine, it works fine
serpent sdx4 srx2 977WC-novarossi-748TQ
serpent S120 LTR-S411
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter
gearhead_22 is offline   Reply With Quote
Old 03-02-2011, 10:22 PM   #3465
Questions??
Originally Posted by Pattojnr View Post
i dont think you would have had it on too long anyway Andrew. maybe Moorebank on a higher grip day. but not Little hampton.
i removed as many screws as possible to get Flex, not taking it out, and it made a world of difference.
Thanks patto,
Could you give me anymore tips with the 733 as I believe both les and myself could use some,also looking to try the X-ray clutch at some stage, what do you think?
andy733 is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
