Old 01-28-2011, 12:01 AM   #3361
gfilos's Avatar
hello guys,
after a broken suspension arm (M), i decided to go to the H suspension kit.. However the front lower arms are binding cause they have a tighter fit than before. Will they free up after some laps or should i shave them alitle bit to have a free move?
Serpent 720 09 mega zx 12 dsII+, Serpent 733 nova 353 tuned/sirio XXXV
Futaba, Graupner, Hudy, RB fuel
gfilos is offline   Reply With Quote
Old 01-28-2011, 02:27 PM   #3362
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
Originally Posted by gfilos View Post
hello guys,
I haven't run the H arms. I'm sure they will free up a little after you run them, but I will highly recommend to shave them a little bit.
Free suspension has a really high impact on handling of the car....
Walter Diaz
wad is online now   Reply With Quote
Old 01-31-2011, 12:13 PM   #3363
rias5037's Avatar
a BIG BIG thank you goes out to Pattojnr, with your help i TQ'd the A mains for the 1st time ever in two years of racing, not only that, but went on to win the A mains as well, to all the guys that doubt the need or use of the DLS, do yourself a favour and GET IT, it works!!!!!
Serpent 747, Max .12 xxl3, Nova 2630, Contact-rc.
rias5037 is offline   Reply With Quote
Old 01-31-2011, 03:23 PM   #3364
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Congratulations
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 02-02-2011, 01:40 AM   #3365
ProE's Avatar
Send a message via MSN to ProE Send a message via Skype™ to ProE
I also added the DLS to my car and tested it this weekend. The rear end is really really good. Rias 5037 are you coming up for the nationals at the end of the month?
ProE is offline   Reply With Quote
Old 02-02-2011, 04:59 AM   #3366
rias5037's Avatar
Nah boet, decided to only run my home nats this year, no away nats. Are you running all the nats, see you running a 353 now, have you given up on the jlr's. It took me a few setup tries to get DLS working 4 DMCC, but once i got it right car was on rails.
Old 02-05-2011, 05:45 AM   #3367
Thybaut's Avatar
Just ordered the EVO, same price (419 euro) as the "old" 733.
Can't wait to build it!
Serpent 733 TE | RB Touring 9, Novarossi N12T1 | Savx SC-1257TG | Ko Propo EX-10 EURUS
Thybaut is offline   Reply With Quote
Old 02-06-2011, 08:03 AM   #3368
quietstorm76's Avatar
Hey guys I just finished running 2011 Winter Nats and I managed to put the only Serpent 733 EVO in the A main. The car was just awesome I've been to this track many times and this was the fastest I've ever been. picked up a lap on my best qualifying time and shaved .3 off my fastest lap. It really is amazing how stable the car is with the DLS. I still have work to do on the driving side but the car is there.
Cruzer body/Matrix tires
Setup
Traction High, Fast and flowing.
Front: width 198/ diff 200K
camber 2, short wb, caster 3mm/roll center up
#2 piston/1000cst/purple spring/2nd hole up
stock sway bar.
Droop-1
Rear: DLS and sway bar
Width 200mm/ Diff 50K
Camber 3.5/toe 2.5/short wb/ roll center middle
#2 piston/1000cst/pink spring/2nd hole up
7mm of spacers on upright.
Droop-4
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 02-06-2011, 08:55 AM   #3369
Marcos you did a great Job this week with putting the only 733 in the Amain. Also with the pressure of running with the Big Boyz.... T-roy and I knew you could do it.... And now I have someone to help me bring home the Hardware
Setup
stock sway bar.
Droop-1
Droop-4
Travelg Amateur is offline   Reply With Quote
Old 02-06-2011, 09:04 AM   #3370
You did great, first time with the car at a big race. Wait till you try it with the DLS
Primary Weapon: ?
Secondary Weapon: ?
Old 02-07-2011, 08:17 AM   #3371
Gonzo RR's Avatar
When will the EVO be available in the us?
Xray NT1 '08 /'09 EC LRP12R / Serpent 720 '08 RB Concept V12, R3 RB mods, V12 Rody, Matrix RW / Serpent 733, 733TE RB T9 / EA RC8T OS .21 Vspec speed tuned / Kyosho Inferno GT, GT2 / EA SC10 / Serpent Cobra GT coming soon!
Gonzo RR is offline   Reply With Quote
Old 02-07-2011, 08:36 AM   #3372
lil-bump's Avatar
Trader Rating: 83 (100%+)
Setup
stock sway bar.
Droop-1
Droop-4
Great job Mr Moten,
I told you; I need to keep my good eye on you
I will need to chat with you when I install my DLS system this season.
I'm pleased to see you and Chicky done well and all of the other Serpent pilots.
as always...
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 02-07-2011, 01:16 PM   #3373
Originally Posted by lil-bump View Post
Great job Mr Moten,
as always...
Pass you soon...
Thanks man! Any questions on the setup just let me know. I've been running the DLS since the Worlds last year and I love it.
Primary Weapon: ?
Secondary Weapon: ?
Old 02-11-2011, 01:45 PM   #3374
Thybaut's Avatar
My 733 EVO arrived today!
Do you guys have a good setup with DLS for a European style track? Im guessing a setup with DLS is quite different from the standard setup, what should I change?
Or should I start without DLS and first learn the car before putting it on?
My track: http://www.machheemstede.nl/ec2011/i...&id=2&Itemid=5
Old 02-11-2011, 02:05 PM   #3375
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
That is basically the Serpent test track. I would check if Michael Salven has any posted on serpent.com if not start off with quietstorms setup just maybe stock diff oils as the traction is a lil different
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
