Old 01-11-2011, 04:55 AM   #3316
M7H
M7H's Avatar
Originally Posted by lil-bump View Post
I thought a fully charged LIFE is about 6.6 vdc you should not need a regulator with a Life. A fully charged NIMH can reach almost 7vdc. If your running a Lipo(8.4vdc) then I would use a regulator.
To be exact:
The voltage cut-off for a 2S LiFe is 7.2V. When finished charging the voltage quickly drops to 6.6 ~ 6.8V.
A fresh NiMh pack, can even go over 7V.
Now you might think that your then better of with a NiMh pack, but I did a check with an IP 1600mAh NiMh an an IP 1450mAh LiFe, both charged and put under load of 1A.
The first 5 minutes, the NiMh had a slight advantage in voltage level, but after 10 minutes, the voltage level of the NiMh already dropped below the level of the LiFe, which for a very long time had a continuous level of about 6.4V....
Because LiFe has a higher output voltage compared to NiMh, you will also have better runtime with it, compared to a same capacity NiMh pack.
Because of the lower internal resistance of LiFe, you will also have more juice left for your steering servo, while under breaking... (that's the theorie, but if it will make you faster.... )
Serpent
M7H is offline   Reply With Quote
Old 01-11-2011, 06:10 AM   #3317
Rawz's Avatar
Originally Posted by QuiXoTic_NL View Post
You'll want to look into the drive ratio. Like all touring cars, the 733 is designed to be run with a split (front tires smaller than rear tires). When running rubber, the front tires will be the same diameter as the rear tires. You will have to play with the pulleys to get a good, close to 1:1 drive ratio.
Into that, we looked around and could not find different pulleys (size options) for the 733. And they told me the 720's ones can't be used. Is that right, or can it be adapted? (I don't hae a 733 ... yet)
Rawz is offline   Reply With Quote
Old 01-11-2011, 06:37 AM   #3318
QuiXoTic_NL's Avatar
I don't have a 733 either (yet, waiting for a 2011 kit), and I'm not racing rubber, so I haven't looked into this either. You could go to http://www.3hobby.net. This is where the UK race crowd hangs out, and they do have a rubber series on a national level. I'm sure that, if running a 733 on rubber is feasible, they will have it figured out.
Shepherd V10 Pro 2015 - Matrix tires - Novarossi Engines - Runnertime
QuiXoTic_NL is offline   Reply With Quote
Old 01-11-2011, 11:16 AM   #3319
gfilos's Avatar
pulleys from 720 can not be used on the 733. 733 uses pins instead of
grub screws for holding pulleys on shafts.
Serpent 720 09 mega zx 12 dsII+, Serpent 733 nova 353 tuned/sirio XXXV
Futaba, Graupner, Hudy, RB fuel
gfilos is offline   Reply With Quote
Old 01-12-2011, 11:41 PM   #3320
Default serpent DLS
Need advice from the serpent Gurus here, i install the DLS, yes the back stability improve alot, however i lost alot of steering as compare to wat i used to have..... pls help me to regain some steering, is it correct if i make the castor more upright to regain steering and using a softer spring infront??? and also to reduce the front shock tower lower as my shock tower position is the most uprite position now, will tat help too????? i am lost now, i need alot of steering make tight coners. tks so much....
eldwin65 is offline   Reply With Quote
Old 01-13-2011, 12:37 AM   #3321
Team Kamikaze's Avatar
Do you have the rear sway bar installed or off?
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 01-13-2011, 03:31 AM   #3322
djiewie's Avatar
Things you can try to regain steering;
- reduce rear toe-in to 1,5 degr. or even less (will get you more speed)
- harder spring at the rear
- softerspring at the front
- harder diffoil at the rear (will get you more on power turn out)
- more droop at the rear (alot more)
- less droop at the front
- harder tire at the rear
- softer tire at the front
- rear shocks harder (higher (harder) oil)
- front shockoil harder (harder for initial turn in tight corner)
- more upright caster at the front (initial turn in for tight corner)
- rear schocks more vertical
- front shocks more horizontal (will redice initial turn-in)
Or remove the DLS and get racing the proper way
Wish you the best, greetz JW
djiewie is offline   Reply With Quote
Old 01-13-2011, 06:45 AM   #3323
quietstorm76's Avatar
The 720 side pulleys won't fit with out some grinding. You will need to grind a flat spot on the shaft so the grub screw can lock down on. I know for a fact that it works for the 2 speed shaft pulley, but not certain for the front pulley.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 01-13-2011, 07:04 AM   #3324
Default serpent DLS
I running without the anti roll bar behind
Old 01-13-2011, 07:11 AM   #3325
DS Motorsport's Avatar
First put the ARB back on.
Second try raising the rear rollcentre by changing to the high or second from the top rear lower rollcentre insert. Also reset the downstops after doing this.
This is a pretty good combination, at least that was my experience.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 01-14-2011, 04:54 AM   #3326
Julius's Avatar
If you would pot the complete setup we can advise you better, but Djewie's comments are steps you can take regardless.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 01-14-2011, 07:33 AM   #3327
Default serpent DLS
thankyou to all, i have gotten the steering bac, i am happy without using the anti roll bar.... mine car can turn tight turns now. tks soo much,,, relieve
Old 01-15-2011, 08:31 AM   #3328
hahaha, interested in a 733? Do it! Then you will win the Nomac 2011!!
Serpent 733, novarossi (engine), Capricorn (engine/tyres), Futaba, Runnertime
petertjes is offline   Reply With Quote
Old 01-16-2011, 06:35 AM   #3329
X4
X4's Avatar
Is anyone interested in a BNIB Serpent 733 that i won in a lucky draw? Please pm me your offers if anyone is interested.
International shipping from Asia would be around around 2-3 weeks and will cost around $40usd.
Thanks!
X4 is offline   Reply With Quote
Old 01-16-2011, 06:36 AM   #3330
gfilos's Avatar
hello guys, one question
on 720 days, i used to apply one droop of one-way lube on my owb
on a regular basis. Never had an owb failure at last 4 years.
On the 733, it seems to me that the bearing comes alot tighter to the shaft than the one on the 720, is it a different part number? (its the same silver color and black inside not red)
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
