Old 01-04-2011, 07:58 PM   #3301
Default serpent
I am a newbie, i suppose the questions i am asking will have being repeated many times. jus want to check, how can i improve the turning when on throttle, at the moment my car turns well with a little throttle, but when i push harder it goes wide. can i ask all the gurus here, how to reduce the angle when i throttle harder???? i also have the DLS with me now, but hesitate to put it on as i am afraid that i will lose some steering.
At the moment i am still using the original front blue spring and the diff is 150k front and 80k behind. red springs for rear. pls advise. thankyou so much.
eldwin65 is offline   Reply With Quote
Old 01-04-2011, 11:58 PM   #3302
NitroWD's Avatar
try softer front springs and/or harder rear springs...
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 01-05-2011, 01:59 AM   #3303
Default serpent
tot of tat too, but wan to know how much harder should i go for the bac???
Old 01-05-2011, 02:26 AM   #3304
NitroWD's Avatar
most easy way: fit the rear shocks more upright and see if any better...try 2-3holes higher.
if you're at the top couples of holes already, try 1 grade harder spring then.
Old 01-09-2011, 10:22 AM   #3305
jvguima's Avatar
What is the best way to put the AMB Rc transponder on 733?? At the botton of the tank?on the chassis plate??
Thank's!!
Serpent 733 / Nova Rossi Flash 3t / Ko Propo EX-5 UR / Tornado 16% / Matrix - Zac
www.guimarc.blogspot.com
jvguima is offline   Reply With Quote
Old 01-09-2011, 04:12 PM   #3306
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Thank's!!
I mount mine under the fuel tank, the wiring and electronics look cleaner this way.
Some mount it on the top deck, as it makes removing the fuel tank (for cleaning) easier.
The choice is yours.
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 01-09-2011, 04:36 PM   #3307
tha Beast's Avatar
Trader Rating: 100 (99%+)
i have a low profile throttle servo and i just stick it to the bottom of the servo
REFLEXRACING
MIKES HOBBY SHOP PORTER TX
tha Beast is offline   Reply With Quote
Old 01-09-2011, 05:29 PM   #3308
lil-bump's Avatar
Trader Rating: 83 (100%+)
I mount mine under the tank also
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 01-10-2011, 08:59 AM   #3309
Rawz's Avatar
Hello guys.
Does anyone have a setup, or at least tips, for a 733 with an STS .12 and rubber tires? (I believe they are 26mm?)
It's for competition, we will have this category here now. Rubber tires and same engine for everyone. My brother in law is strungling to set the serpent right.
Here is our track
Thankx !
Rawz is offline   Reply With Quote
Old 01-10-2011, 09:30 AM   #3310
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
You'll wanna run less camber so that u have more contact patch of the rubber tires.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 01-10-2011, 11:55 AM   #3311
gfilos's Avatar
hi guys, one question
do you use a regulator with a life battery? i know most dont use
but i have mixed opinions about it. I already have the small xceed
regulator which isnt a problem to be mounted inside the radio box just
to be sure i dont face any probs with the increased voltage of life, but
i have also read here in this thread about regulator overheating problems when
inside the box so i start to reconsider using or not the regulator. Has anyone
had problems by not using a one?
i use the spektrum pro hrs receiver with futaba 9350 & 9452 digital servos and the battery is an IP 1200mah.
Serpent 720 09 mega zx 12 dsII+, Serpent 733 nova 353 tuned/sirio XXXV
Futaba, Graupner, Hudy, RB fuel
gfilos is offline   Reply With Quote
Old 01-10-2011, 12:10 PM   #3312
lil-bump's Avatar
I thought a fully charged LIFE is about 6.6 vdc you should not need a regulator with a Life. A fully charged NIMH can reach almost 7vdc. If your running a Lipo(8.4vdc) then I would use a regulator.
Elliott Hart
Serpent America
Desoto Racing Team
Old 01-10-2011, 03:32 PM   #3313
Michael_T's Avatar
You do not need a regulator with Life. I have been using Life batteries in my KO and Futaba gear, never been an issue.
LiPo batteries go to 7.4v, Life only go to 6.6v
There is also about a 60g weight saving between a NiMh vs Life
Old 01-11-2011, 02:12 AM   #3314
QuiXoTic_NL's Avatar
Originally Posted by Rawz View Post
Hello guys.
Here is our track
Thankx !
You'll want to look into the drive ratio. Like all touring cars, the 733 is designed to be run with a split (front tires smaller than rear tires). When running rubber, the front tires will be the same diameter as the rear tires. You will have to play with the pulleys to get a good, close to 1:1 drive ratio.
Shepherd V10 Pro 2015 - Matrix tires - Novarossi Engines - Runnertime
QuiXoTic_NL is offline   Reply With Quote
Old 01-11-2011, 04:37 AM   #3315
jvguima's Avatar
Thank`s for the answers guys!!!
But i have another question, i buy a Lipo battery for my 733 and i have a doubt about the best place to put the Lipo voltage regulator.
Thank`s
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
