Old 11-28-2010, 11:12 AM   #3241
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Originally Posted by quietstorm76 View Post
Dude I was refering to NitroDude's post about tracks being different. Read my last post. If I was running at your track then maybe I would need a setup like yours. I'd like to see you try your setup at Kissimmee RC Raceway though. 37's were the prefered rear tire some even ran 35's. NT1's, Capricorns, Kyosho, it didn't matter what car soft rear tires were needed. When was the last time you ran 42s on the front and 37s on the rear, but that's what some people did to balance the traction.
I didn't run 42s in the front only in the rear.
Yes I know all tracks aren't the same and some tracks like yours are very low on traction which is why the DLS was developed to help those situations. My point again is if your setup is so extreme in the rear with the DLS on, how extreme was it when you didn't have the DLS? It seemed from your setup that the DLS didn't affect your traction situation by much. This in contrast to others who have used the DLS finding that it made so much rear traction that it affected their setups significantly.
YR4Dude is offline   Reply With Quote
Old 11-28-2010, 03:38 PM   #3242
Default 733
what would be the different
Between using 1st gear 61 vs 59 , I know that 61 would take off faster but when would a 59 be a good idea? and does it save any fuel?
jjrctech is offline   Reply With Quote
Old 11-28-2010, 03:53 PM   #3243
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
61T would give you better acceleration, suited better on shorter tracks. 59T theory is it would save on fuel because the engine does not rev as hard.
I set my ratios with the pinions, and use different spurs for perfect mesh....
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 11-28-2010, 04:01 PM   #3244
Michael_T's Avatar
The whole DLS debate...
I am not yet 100% convinced, and haven't spent $130 to get one. My rear end is just as planted as any of the other cars I have owned. I run 37 rears 95% of the time, I might go to 40s on longer finals, or 35s on low traction tracks. Generally I run 50K or higher rear diff, 2.5mm sway bar, 3deg toe etc etc. Tire wear isn't an issue for me, i cut them down to 58/60mm on 30 min finals at our home track.
As you can see, my setup doesn't indicate a lack of rear grip to justify the DLS.
At the moment, I would still rather pour the $130 on more sets of tires or a fresh engine which would give me instant guaranteed speed.
Old 11-28-2010, 04:28 PM   #3245
gearhead_22's Avatar
Send a message via AIM to gearhead_22
I went with the dls system and i was able to dirve into and out of the corners harder which drop my lap times down
serpent sdx4 srx2 977WC-novarossi-748TQ
serpent S120 LTR-S411
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter
gearhead_22 is offline   Reply With Quote
Old 11-28-2010, 05:18 PM   #3246
lil-bump's Avatar
Trader Rating: 83 (100%+)
If your engine makes a ton of torque in the lower portion of the RPM(picco's) you may want to consider running the 59. Most Novarossi make peak horsepower later in the rpm range. It all depends on what type of engine you have and what gearing it likes.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 11-28-2010, 07:11 PM   #3247
quietstorm76's Avatar
This is my final post on this because you don't seem to get it. THE TRACTION WAS WEIRD. TRACK WAS BUMPY and in the middle of the corner all the cars including 8th scales were breaking loose. IT WAS THE TRACK!!! what part of that do you not understand. This was not my home track. At my home track I can run 45s rears with DLS and the car is still good. I'll be attending the Winter Nats next yr and I've never had traction problems there with the standard rear end so I expect a push condition with the DLS and will TUNE my car according to the track conditions.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 11-28-2010, 07:13 PM   #3248
Robert R's Avatar
I am looking for Spring rate for the 966 anyone? thank you
Chef Robert
Serpent 977
Serpent 811 GT
I have Byron fuel 16, 20, 25 & 30
Robert R is offline   Reply With Quote
Old 11-28-2010, 07:18 PM   #3249
nitrodude's Avatar
Robert, I just found it!
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 11-28-2010, 09:21 PM   #3250
Pattojnr's Avatar
Trader Rating: 19 (100%+)
untill you run it you will not know. i have run it, Ric has run it. Rics response was same as mine, it really settles the car, makes it smoother, and will it relate to quicker times ? i ran it once, 2 day event, car was very settled, smooth, and did it relate to better times.... YES. car was more consistant, proof = my best ever 0.10 cons, and new lap record, and new 5 min record, first ever 19 lapper in tourer, and finally i got that 15 in as official from 2 years ago.
so unless you bite the bullet and try it, yu cant be convinced it wont help. thats the way i look at it since everyone else is saying the same thing, just different setups for diff conditions.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 11-28-2010, 11:20 PM   #3251
Trader Rating: 13 (93%+)
hey Patto, novarossi doesnt believe in hop ups..just new cars.
did you know he buys a new 733 after every 3rd club day?
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
mrgsr is offline   Reply With Quote
Old 11-29-2010, 12:04 AM   #3252
Pattojnr's Avatar
hey John, i guees the extra speed from the fresh motor will always help more. well the sudden stop is just that bit harder
Serpent - Walter RC
Old 11-30-2010, 09:01 AM   #3253
chromie's Avatar
Hey
How much grams does the xceed titanium screw set save?
chromie is offline   Reply With Quote
Old 12-02-2010, 04:39 AM   #3254
Tor Erik's Avatar
R/C Tech Charter Subscriber
Hmrf, I want to build me an new 733 this winter. Still not any hope that Serpent will soon come out with an new 2011 version of 733 ??
Or a kit including the latest upgrades ?
Rumors anyone ??
Xray XB4 and T4 Futaba 4PK
Tor Erik is offline   Reply With Quote
Old 12-02-2010, 02:29 PM   #3255
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Your safe the car isn't changing. Adding the DLS to the kit would just raise the price. It's staying in it's current form rite now. These options aren't needed just tuning options. Still a goo package for 2011 in it current form
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
