Old 11-19-2010, 07:02 PM   #3211
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Originally Posted by implusepro View Post
can someone post photos of how you hide all your wiring, mine is a mess
I just hide it all in the receiver box.
YR4Dude is offline   Reply With Quote
Old 11-20-2010, 02:33 AM   #3212
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Here you go...
Serpent 733 1/10 200mm touring-pb201904.jpg   Serpent 733 1/10 200mm touring-pb201905.jpg
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 11-20-2010, 10:16 AM   #3213
foch78's Avatar
I don't like the transponder under the tank because it is necessary to disassemble the radioplate for clean the tank. I put the transponder on a carbon plate attached to 2 holes located above the steering servo.
Serpent 733
Futaba 3 PM 2,4 ghz
NOVAROSSI PLUS 12-3 ST
Meccamo
foch78 is offline   Reply With Quote
Old 11-23-2010, 05:33 AM   #3214
Cirrc's Avatar
Default Question about hitec servos
Do the stock 24t 733 servo horns (the ones on the parts tee) fit hitec servos? Reason is that I've tried them on my hitec servosand they seem a little loose. Is that ok or is there something wrong?
Cirrc is offline   Reply With Quote
Old 11-23-2010, 01:12 PM   #3215
Michael_T's Avatar
Yep, 24T is Hitec.
Old 11-23-2010, 07:32 PM   #3216
quietstorm76's Avatar
Default 733/DLS setup
I just got back from the US Open Champs @ Kissimmee R/c Raceway. Finished 5th in the A. Rear tire wear is just amazing with the DLS. after a 30 minute main, I only had a .8mm difference between L/R tire dia. Usually it 2-4mm difference.
Medium/High Traction/Fast/open layout
Chevy Cruze Body
Front:
WB long
198 width
1.5 camber
1.5 toe out
caster 5mm
Roll Ctr middle
1 hole piston/1000cst/purple spring/2nd hole
RH=5.5mm
40's tires
Rear:
WB 2mm short
200mm width
4 camber
3 toe-in
7mm shims on hub
Roll ctr bottom
2 hole piston/900cst/orange spring/3rd hole up
RH=6mm
40's tires
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 11-23-2010, 07:36 PM   #3217
Michael_T's Avatar
Chevy Cruze Body
Front:
WB long
198 width
1.5 camber
1.5 toe out
caster 5mm
Roll Ctr middle
RH=5.5mm
40's tires
Rear:
WB 2mm short
200mm width
4 camber
3 toe-in
7mm shims on hub
Roll ctr bottom
RH=6mm
40's tires
Congrats dude!
What diffs front and rear did you run?
7mm shims on hubs??
Old 11-23-2010, 07:46 PM   #3218
Originally Posted by Novarossi View Post
Congrats dude!
7mm shims on hubs??
Thank man!
front 200K cst
Rear 20K cst (started with 50K then 30K and finally 20K)
No Rear Sway bar!!! No push
Meant 7mm on rear up-right for camber gain.
Very happy with the car. I think the DLS had alot to do with it. I didn't have a chance to run with the stock camber links
Primary Weapon: ?
Secondary Weapon: ?
Old 11-23-2010, 09:14 PM   #3219
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Thank man!
front 200K cst
you really should also try with te narrow lower rear hingein brackets.
the DLS just transforms the car so much, and the way it wears tyres is something to get used to. wel done Storm.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 11-23-2010, 09:36 PM   #3220
Thanx dude.
I've tried the narrow brackets but not with the DLS. What should I expect with the DLS? I tested the narrow on a parking lot track and couldn't really tell anything and I took them off. Any advice?
Primary Weapon: ?
Secondary Weapon: ?
Old 11-23-2010, 09:47 PM   #3221
That's right kit included 24t servo horns for hitec but when it comes to Hitec metal servos, it doesn't fit..much loose and spin finally. only use for plastic geared Hitec servo.
nsho0l is offline   Reply With Quote
Old 11-23-2010, 11:39 PM   #3222
Cirrc's Avatar
Thanks!
I'm planning to use metal geared servos in my 733 (HS-5996TG for steering & HS-7965MG for throttle/brake). Guess that I'll have to mod the servo horns that come with these servos.
Old 11-24-2010, 12:02 AM   #3223
Pattojnr's Avatar
Thanx dude.
even more stability. but i also used front and rear sway bar. PM me your email, and ill send you over what i found.
Serpent - Walter RC
Old 11-24-2010, 08:10 AM   #3224
ygpm
Primary Weapon: ?
Secondary Weapon: ?
Old 11-24-2010, 10:25 AM   #3225
lil-bump's Avatar
Trader Rating: 83 (100%+)
ygpm
Good Job!
I'm going to keep my good eye on you
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is online now   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
