Old 10-23-2010, 11:51 PM   #3151
nitrodude's Avatar
Originally Posted by Novarossi View Post
Anyone tested standard and optional narrow rear plate? What do you think?
What rear plate?
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 10-23-2010, 11:54 PM   #3152
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Originally Posted by nitrodude View Post
What rear plate?
http://www.serpent.com/product/804133
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 10-23-2010, 11:56 PM   #3153
nitrodude's Avatar
Interesting
Steven Muller
Ronin Speed Parts
Old 10-23-2010, 11:58 PM   #3154
Michael_T's Avatar
Interesting
yes, been around since the car was released. I know some of the previous 733 drivers used them. No where on the setup sheets specifies what plate your using. I wonder what the team drivers think?
Old 10-26-2010, 05:39 AM   #3155
What battery is best for the 733 balance-wise?
I can imagine there is an optimum in battery weight to have a perfect left-right balance in the car.
Anyone has news on a 2011 version of the 733?
ma_RC_el is offline   Reply With Quote
Old 10-26-2010, 05:48 AM   #3156
Pattojnr's Avatar
Trader Rating: 19 (100%+)
i use the LiFe pack 1450mah. car is well balanced with this battery.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 10-26-2010, 10:44 AM   #3157
quietstorm76's Avatar
I've tried the narrow before. It basically gives you a long rear arm and it changes your shock angle. Your track width will be about 3mm narrow without any changes to current setup. When you widen it back out be careful as the pillow balls will have less thread in the arm. I used 8th scale pillow balls cause they are longer. More traction overall, but you will feel the difference.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 10-26-2010, 04:16 PM   #3158
Michael_T's Avatar
excellent, thanks
Old 10-28-2010, 02:18 PM   #3159
I'v read inthis thread dls has to much rear bite for us tracks not alowing car to rotate quickly I was wondering if dls would work good for parking lot club racing tryin to deside which car I want to get lab-co1 or 733 anyone driven both for a good comparison both very inviting.
mxfred is offline   Reply With Quote
Old 10-28-2010, 11:23 PM   #3160
+1
Primary Weapon: ?
Secondary Weapon: ?
Old 10-29-2010, 07:16 AM   #3161
Pattojnr's Avatar
im having a hard time to work out how to use the rear sway bar along with the DLS, and short rear end. ? swaybar binds using the outer hole like the maual, or pictures say. and the arm of the swaybar hits the 1st spur. needs to be on the inside hole as far as i can see. and also using the Narrow brackets for lower hinge pins. Cheers for any Help .
Serpent - Walter RC
Old 10-29-2010, 07:22 AM   #3162
dj apolaro's Avatar
You have to put the ball side of the linkage on the other side of the graphite piece. Away from the gear side. All of us that used the DLS and the sway bar had no issues. Although I will say we did not use the lower pins narrow. Maybe that is another issue, not sure.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 10-29-2010, 08:01 AM   #3163
Pattojnr's Avatar
DJ Apolaro
Thanks DJ, i just got it all back together now, guess ill have another go
just all the pics i have seen has the bar on the front side of the lower arm.
Thanks again, Regards, Patto.
Serpent - Walter RC
Old 10-29-2010, 08:41 AM   #3164
Pattojnr, please, could you send pics of your DLS and sway bar. I had the same issues and I quit using the sway bar. Thanks.
Torrano
Torranojr is offline   Reply With Quote
Old 10-29-2010, 09:10 AM   #3165
Pattojnr's Avatar
Torrano
ok i just found this, as i tried to fit the linkage for the roll bar on the inner side away from the Spurs, but nothing fits. what i can see here, is a set screw on the outer lower hole, to prevent the carbon plate from moving, and use a screw from the back side of the arm , and use the inner hole for the roll bar linkage, on the forward facing side of the A arm. i am about to try this now.
http://teamserpent.com/2010/09/serpe...set-up-salven/
Serpent - Walter RC
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
