Old 10-04-2010, 09:50 PM   #3076
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Also,
Does any one know how much the stock chassis plate weights please??
Pretty Pretty please, I don't want to strip down my car to weight just the chassis alone, maybe someone has a spare chassis they can throw on the scales?
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 10-05-2010, 03:16 AM   #3077
Originally Posted by Novarossi View Post
Anyone know how much the Xceed screw sets saves in weight?
Reading back through this thread, one person says it saves 100grams (which is awesome) and another guy said only 30grams....
I replaced only the screws on top of the car and it saves 30gram.
This are more than half of the total screws, so i think if you replace them all it will save 50-60gram
Serpent 733, novarossi (engine), Capricorn (engine/tyres), Futaba, Runnertime
petertjes is offline   Reply With Quote
Old 10-05-2010, 05:55 AM   #3078
quietstorm76's Avatar
Default Warning
Just in case anyone is thinking of buying the CSO cvd's DON'T!!! They are very weak!! Nice price but it going to cost you a race........guaranteed.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 10-05-2010, 06:16 AM   #3079
lil-bump's Avatar
Trader Rating: 83 (100%+)
Also,
Naked bare 733 chassis weighs 127 grams. Which is pretty heavy. My mugen 4mm only weighed 107 grams. Kawahara mtx4r 3mm was around 88 grams.
Since the 733 chassis does not have a cutout for the battery this adds alot of weight
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 10-05-2010, 01:06 PM   #3080
Michael_T's Avatar
Excellent, thanks for the answers guys...
Old 10-05-2010, 02:02 PM   #3081
Hi there,
How you use the dls with or without rear bar?
I tried today without and the car was rear lose, set the camber to 2,5 toe in 3,0. 47,7mm dls downstops to 3mm and -1 front. Rear was shorter 2mm. Front -1.
Any help?
Thxs,
kavajas is offline   Reply With Quote
Old 10-05-2010, 02:30 PM   #3082
Originally Posted by kavajas View Post
Hi there,
Any help?
Thxs,
No sway bar for me
Check for binds
How was tire wear? Coning to out side or inside? May need more camber
Primary Weapon: ?
Secondary Weapon: ?
Old 10-05-2010, 04:54 PM   #3083
Ya tire right side, coning out left tire inside.
more camber than 2,5?
Old 10-05-2010, 04:58 PM   #3084
dj apolaro's Avatar
When I use it I run more camber than that. I would start with 3.5 on the left and 4 on the right. IMO this worked better for me and yes, make sure there is no binding.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 10-05-2010, 05:33 PM   #3085
What you mean on binding?
Loose parts? The levels have some loose even if you put the washers on.
4,0 camber i will try better than, the rear weel base -2 ?
thxs.
Old 10-05-2010, 09:23 PM   #3086
thxs.
Yes everything is loose, moves freely. You can leave wheel base -2, just add more camber.
Primary Weapon: ?
Secondary Weapon: ?
Old 10-05-2010, 11:59 PM   #3087
I would like to speak about the weight reduction ...is it neseccary?Definetly puting away some grams makes the car faster end easier to drive but is this right ?I think that the car as it comes from the factory has everything in it carefully designed and chosen ...So i dont see the need to put light weight parts and make the car less durable ...
the only think that we can change without problems as i saw here is the screws ...where we can find this set how much does it cost ?
JIMBO20 is offline   Reply With Quote
Old 10-06-2010, 03:58 AM   #3088
Michael_T's Avatar
Reducing rotating mass is always a good thing:
-CSO Light weight 2speed shaft
-CSO/Serpent Light weight brake disc
-Xceed composite diffs
Static weight is also a plus:
-Low profile servos (eg Futaba 9551s)
-LiPo Reciever pack
-Xceed Ti Screws
Then you have other things like:
-Lightweight bodies (eg Protoform make normal and "light weight versions, there is 15g difference between the two)
-Lightweight wheels (Capricorn save about 20g all round compared to normal rims)
If your a normal club driver, 50grams won't do much to your times. But if your searching for that 0.1 or 0.2 on the limit, then saving weight is a must.
But then again, improving the efficiency of your car will probably yield the same result (eg ceramic bearings, low friction belts, etc)
Old 10-06-2010, 04:16 AM   #3089
Pattojnr's Avatar
Trader Rating: 19 (100%+)
-LiPo Reciever pack
-Xceed Ti Screws
no compensation for a driver aid then ? how can we lighten the drivers a bit ? haha first thing first, no point lightening the car and doing this and that, if your off teh track every 4th or 5th lap . concentrate on setup, and consistancy, then when that arrives, work on making the car that bit faster, and lighter.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 10-06-2010, 05:04 AM   #3090
Send a message via AIM to Bxclip
Just bought my 733 from member on here! Now what engine is next. The flash 12 or murnan modified 353?
Bxclip is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
