Old 09-12-2010, 09:12 PM   #3001
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Originally Posted by Bxclip View Post
$600 might be out of my range. What's it mean when a engine is flashed?
First of all, you said you wanted a monster and that it had to be durable. You didn't say that you were on a budget.
$600 is full retail and like everything in this hobby, no body sells for full retail. If you really want one here you go.
http://www.kamikazetoysandhobbies.co...VFLASH123TUNED
YR4Dude is offline   Reply With Quote
Old 09-12-2010, 09:16 PM   #3002
YR4Dude's Avatar
If it's as fast as te flash why not buy this it's cheaper right?
You always get what you pay for.
Old 09-12-2010, 09:21 PM   #3003
Send a message via AIM to Bxclip
As much as I try to be on a budget. I always tend to break it in this hobby
Bxclip is offline   Reply With Quote
Old 09-12-2010, 09:32 PM   #3004
YR4Dude's Avatar
To bad my girl made me promise that se gets me 733 for Xmas. Any hop ups I should buy from get go. Or is the kit good Enough
Hop ups and options will always be available for any car. For the 733 there's plenty. However, just to get started, the kit is a good base.
The latest is the new DLS rear link system which was recently used by the team drivers at the World Champs race in TX. Read back a few pages on this thread you find more info on that option.
Old 09-12-2010, 09:46 PM   #3005
Thanks for the help. Next spring I'll be ready for Season with this 733 with that nova engine!
Old 09-13-2010, 02:12 PM   #3006
Default DLS System
Hi fellow Serpents,
As we all know,the DLS has been introduced during the Worlds,and I am interested in giving it a try.Currently,my 733 has been dialed in for my local track so im worried if i try the DLS,it would mess up the car's handling and performance.
So just want to know from those who has given the DLS a try,is there major changes to the setup for it to work properly or it works just fine out of the package??Please do share your experiences with the 733 before and after with the DLS since its been out for some time now hence there should be guys out there who have tested it thoroughly.
Thanks guys!
tq23 is offline   Reply With Quote
Old 09-13-2010, 04:45 PM   #3007
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Originally Posted by tq23 View Post
Hi fellow Serpents,
Thanks guys!
+1
Also, would like to see some team driver World's setup. DJ??? Paolo???, was there a common setup amongst you, please post
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 09-13-2010, 08:03 PM   #3008
YR4Dude's Avatar
Hi fellow Serpents,
Thanks guys!
One of our guys just used the DLS this weekend. The rear end is really planted. However the drawback is that you need to adjust your setup by trying to find more steering to compensate. That was done by lowering the front's roll center and adding more droop while reducing some droop in the rear.
Once you're able to dial in more steering, the car will be enter and exit the turns easily while on throttle. Hence, more corner speed.
Old 09-14-2010, 03:40 AM   #3009
wee
Default dls
helo to all serpent fans,
i'm having some problems herewith my dls...
after installing the dls (without rear anti roll bar), i found that my rear end do
not stick to the groung. so i remove the dls and install back rear anti roll bar
and guess what it much better without the dls
did i do any thing wrong
i read that some of you try and got the car glue to the ground and
same goes to guys in hong kong.
our track here is consider ok not parking lot but tarmac is dusty after rain.
thanks
SERPENT S733 , S966 , S811 , S400 , S411 TE & S747 SOON.......
POWERED BY NOVAROSSI ( GP )
POWERED BY HOBBY WING V3, SPEED PASSION AND LRP (EP)
wee is offline   Reply With Quote
Old 09-14-2010, 03:48 AM   #3010
Doug M's Avatar
Default Novarossi Challenge @ Homestead Super raceway
Doug M is offline   Reply With Quote
Old 09-14-2010, 05:36 AM   #3011
quietstorm76's Avatar
thanks
Double check the the install for any binds. What is your measurement on your linkage on the inside. Set it to 47.7mm. Start with 3 camber and 3 toe and adjust from there. Make sure there are no binds. The system works great so you may have missed something.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 09-14-2010, 06:50 AM   #3012
wee
quietstorm 76,
well i have check confirm no binding.
but the book says both linkages are to be 45.5 mm
do i need to set only for the inside linkage to 47.7
pls advise
tks in advance
Old 09-14-2010, 07:00 AM   #3013
wee
Default dls
quietstorm 76
one more thing to ask...
1) have you try to use togather with the rear anti roll bar. how is it? i try
to install it ( with out asorbers attached) and it looks like when you push the outter tyre, the inside tyre do not work what it seems to be cos the anti
roll bar lift the lower arm. you know what i mean...
tks
Old 09-14-2010, 12:42 PM   #3014
quietstorm 76,
pls advise
tks in advance
quietstorm 76
tks
47.7 is what we were told to set at the worlds so thats where mine is. 45.5 is pretty close but not sure if it will make a difference. Paolo may know that answer.
I have run the DLS with and with out the sway bar. With the anti installed it allows the rear to rotate more. Watch the ball cups on the lower arm for binds
Primary Weapon: ?
Secondary Weapon: ?
Old 09-15-2010, 12:31 AM   #3015
wee
Default dls
hey quietstorm 76
got it, understood will try to run my car this afternoon...
thanks again
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
