Old 08-24-2010, 07:45 PM   #2911
Originally Posted by SlowPushin View Post
Has any one had a chance to test out the new rear end. I Eexperience that this system gives you less traction than the original sway bar. the whole day searched for MORE rear traction . i thought this new linking system was designed to help plant the rear end. Please some one tell me there experience, I want to know if im the only one.
I tested the system in Houston. For me it gave me a lot more traction and actually i had to adjust the setup in the rear end.
I end up using 3deg of camber in the outside tire, 2.5 in the inside, i use 7mm spacer in the uprigth and the rod was 77mm (measured from the outside)
I will test more in order to learn it. I think it gives an advantage in any situation
RCtarget, Capricorn, Novarossi, Maxima MX Fuel, Matrix, Xtreme Aero, Avid, Ko Propo, Veytrex Lab, Blast RC, PMR
Paolo M is offline   Reply With Quote
Old 08-24-2010, 07:47 PM   #2912
Originally Posted by quietstorm76 View Post
The system wasn't designed to be used with the sway bar. The guys figured out how to mount the sway bar. Yes it will be close to the spur gear but it didn't touch.
U are correct. I installed myself cause i was looking for a faster transition in a super tight chicane.
By the way, i heard your 966 is on the way to you... congrats
Old 08-24-2010, 07:49 PM   #2913
nitrodude's Avatar
Paolo, when are the new bulkheads from Houston coming out?
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 08-24-2010, 07:50 PM   #2914
Originally Posted by jjrctech View Post
image 11, better seen on image 14 on that page yuya sahashi car shows Some thing I have not seen , from the brake system (Bearingblock-2sp-alu r 966 (#903316) and other side has well they connect to the rear diff Bearingblock Like a stiffner ??
does any one know what this is?
thanks
Originally Posted by Monti View Post
I asked the same question back on page 190. Some responded and mentioned it was an up coming option. No other info was given.
Monti
Those parts were brought by the factory. It's and additional tuning option, in order to change the rear stiffness of the car. You can connect the whole rear end if you like. They should be available soon.
Old 08-29-2010, 11:59 AM   #2915
Dr. Evil's Avatar
Talking Onroad Serpent 733
Hi there.
I have a Serpent 710. I haven't been running onroad in a while since there isn't anyplace to run them around here.
I was wondering, If I get into onroad again, it the 733 much better than the 710, or should I just run what I got. I actually have 2 710. 1 is a parts car.
so parts aren't an issue. (Gears maybe)
Thanks much.
Also, what are people running for engine these days. I have a Rossi .12 and a Sirio .12 as well.
Dr. Evil is offline   Reply With Quote
Old 08-29-2010, 12:21 PM   #2916
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Originally Posted by Dr. Evil View Post
Hi there.
Thanks much.
The 733 is light years ahead of the 710.
It not only is easier to work on but its also easier to tune. Everyone has marveled at how quickly it responds to tuning changes and also how quickly it is to repair after a crash. I myself included.
You really should consider getting a 733.
YR4Dude is offline   Reply With Quote
Old 08-29-2010, 05:42 PM   #2917
Default serpent 733
Hi
I am running the stock Clutch bell housing engine at .7cap , and I cant get the gears to line up perect it about 2-3mm to the outside and I cant move the engine any more to the left.??
the 2 speed Pinion gear some times rubs the 1 gear 61
Any idea?
jjrctech is offline   Reply With Quote
Old 08-29-2010, 07:59 PM   #2918
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Hi
Any idea?
Try:
1. Sand down the cone to the bare minimal clearance between the flywheel and engine.
2. The gearbox assembly should have some left/right movement. I used shims on the shafts to move the gearbox slightly over to the right (I am talking like 0.2-0.3mm)
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 08-29-2010, 09:10 PM   #2919
ShermanSim's Avatar
Hi
Any idea?
Hi,
I have the same issue a while back, the pinion gears was sticking out,
The second pinion might be reverse. try flipping it and see.
s
Serpent America, 977 KO Radio, Nova Rossi Engine, Kosmic Fuel
ShermanSim is offline   Reply With Quote
Old 08-29-2010, 09:17 PM   #2920
Originally Posted by ShermanSim View Post
Hi,
s
Yea the 2 pinion it correct I try both ways , and I have shims shafts to move the gearbox slightly over to the right , But it still about 2-3mm off .
Old 08-29-2010, 09:44 PM   #2921
lil-bump's Avatar
Trader Rating: 83 (100%+)
I had the same problem. Just keep adding shims between the spacer and bearing. My 2nd gear lines up perfect 1st gear is out by .3mm.
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 08-30-2010, 09:28 AM   #2922
lil-bump's Avatar
Hey Paolo,
When are the new spurs going to be out. I need a couple and I would like the new version. I looked at Chris's car; his spurs are totally different.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 08-30-2010, 10:13 AM   #2923
gfilos's Avatar
i had the same problem on a friend's 733. Motor was a JP 3PL. I shaved a bit the cone from the flat side and gears were perfectly lined (i ended up with a small clearance between flywheel and engine). However, 3mm is a bit too much, i am not sure if that will help to 100% cure the problem.
Serpent 720 09 mega zx 12 dsII+, Serpent 733 nova 353 tuned/sirio XXXV
Futaba, Graupner, Hudy, RB fuel
gfilos is offline   Reply With Quote
Old 08-31-2010, 04:34 AM   #2924
NiTrO BoOsTeR's Avatar
hey guys, just raced in the Qld state titles here in Australia and i am in the process on rebuilding the car and i have noticed that 3 out of the 4 pillow balls are bent. i dont know if this is a common occurrence or just because i had a rather big spill. what i wanted to know is, is there a stronger pillow ball around i can try, i have so far replaced them with 3 racing titanium pillow balls but i dunno how well they are goin to go, just bought them because i needed them in a hurry. if anyone has changed to a different brand can you tell about you experiences with them
Mitch
Serpent 733 - RB T10rc - Ko Helios EX-10
Serpent 733 - Novarossi 3SCT Tuned
============== SERPENT the only way ============
==== Pro Buggy Rc, Pitsworth - for all my RC needs =====
NiTrO BoOsTeR is offline   Reply With Quote
Old 08-31-2010, 04:36 AM   #2925
Team-RTR's Avatar
Mitch
i believe serpent make titanium pivotballs now which are supposedly quite strong.. they seem to be the go if your after something solid.
SERPENT | NOVAROSSI | XRAY | TEKIN | FUTABA
Team-RTR is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
