Old 08-23-2010, 08:50 PM   #2896
nitrodude's Avatar
http://events.redrc.net/event-galler...ds/?nggpage=15
Look on that link for pics
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 08-23-2010, 09:02 PM   #2897
G87z's Avatar
Originally Posted by nitrodude View Post
Thanks Nitrodude. I have already looked through those pics. Nothing specific to that side of the car.
Thanks,
Team Shepherd USA / Picco Engines / Sanwa / Matrix Tires / Byrons Fuel / SRC
G87z is offline   Reply With Quote
Old 08-23-2010, 09:38 PM   #2898
nitrodude's Avatar
Originally Posted by G87z View Post
Does anyone have a picture of the DLS system with the swaybar attached? Mainly the spur gear side. Just from a glance it does not look like it will fit and will rub on the spur gear.
Thanks,
You know... I dont want to be rude, but if they made it and they ran it at the worlds Im sure it fits, they're not going to make something that doesnt fit on the car properly.
Steven Muller
Ronin Speed Parts
Old 08-23-2010, 11:00 PM   #2899
SlowPushin's Avatar
k
SlowPushin is offline   Reply With Quote
Old 08-23-2010, 11:00 PM   #2900
SlowPushin's Avatar
IT's Not THe CAR,IT's THe NUT on the GRIP
S e r p e n t [7 4 7] [4 1 1]
SWEEP TIRES
ENNETI TIRES
Old 08-23-2010, 11:14 PM   #2901
SlowPushin's Avatar
Originally Posted by Novarossi View Post
Interesting.....
Were you running the rear sway bar with the DLS? Was camber set at 2.5 deg?
NO i dint think about running the sway bar. usually a sway bar takes away traction in my case i wanted more traction. i might try the sway bar next race
SWEEP TIRES
ENNETI TIRES
Old 08-24-2010, 06:36 AM   #2902
captian's Avatar
Thanks,
that link has a good pic image 11 on that page yuya sahashi car shows the spur side .
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 08-24-2010, 06:57 AM   #2903
G87z's Avatar
Well thank you for being rude. I am sure that it works. The reason I was asking is because I was having issues.
Old 08-24-2010, 06:58 AM   #2904
G87z's Avatar
thanks Captian. It seems that in order to run the swaybar you have to run the rear of the car long. I had it put together just as the pic shows but the rear of the car was short and it rubbed on the spur gear.
Thanks for your help.
Old 08-24-2010, 09:55 AM   #2905
Default image 11 on that page yuya sahashi car shows
image 11, better seen on image 14 on that page yuya sahashi car shows Some thing I have not seen , from the brake system (Bearingblock-2sp-alu r 966 (#903316) and other side has well they connect to the rear diff Bearingblock Like a stiffner ??
does any one know what this is?
thanks
jjrctech is offline   Reply With Quote
Old 08-24-2010, 10:05 AM   #2906
Trader Rating: 34 (100%+)
thanks
I asked the same question back on page 190. Some responded and mentioned it was an up coming option. No other info was given.
Monti
Monti is offline   Reply With Quote
Old 08-24-2010, 01:12 PM   #2907
quietstorm76's Avatar
The system wasn't designed to be used with the sway bar. The guys figured out how to mount the sway bar. Yes it will be close to the spur gear but it didn't touch.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 08-24-2010, 03:05 PM   #2908
captian's Avatar
thanks
they may be new parts going out . it will take the place of the lower x brace
Old 08-24-2010, 03:08 PM   #2909
captian's Avatar
Monti
it was the worlds thats what happins when you go there with all the go fast goodies that can help you when a title
Old 08-24-2010, 07:42 PM   #2910
Back on subject:
What alternatives are there with the belts.
The orange ones last forever (I am still running the originals), but make the drive train too heavy
The black optional ones really free the drive train nicely, but wear out after one club day.
I keep hearing about Team Titan, MLB, etc etc belts that fit, would appreciate if someone can provide links or part numbers of where to buy them
How efficient are these other belts, and how long do they last?
Original low friction belts are very good. I personally run them and they last a long time. In the rear i run the 5mm from Team Titan.
The Titan are excellent as well. Either one is a good choice
RCtarget, Capricorn, Novarossi, Maxima MX Fuel, Matrix, Xtreme Aero, Avid, Ko Propo, Veytrex Lab, Blast RC, PMR
Paolo M is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
