Old 08-09-2010, 06:16 AM   #2791
captian's Avatar
Originally Posted by quietstorm76 View Post
Oh yeah it's gonna get weird for sure.
its all good we figured it out
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 08-09-2010, 06:18 AM   #2792
captian's Avatar
Originally Posted by LiL_JaSoN View Post
anyone using the long bodies/shafts?
dont think its a need for it
Old 08-09-2010, 06:44 AM   #2793
quietstorm76's Avatar
If you are going to do it just use the long bodies. But like someone posted already, I don't think there's a need for the change. I did that on my 720 but haven't thought about it for the 733.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 08-09-2010, 06:45 AM   #2794
Smart guys! I figured you would
Primary Weapon: ?
Secondary Weapon: ?
Old 08-09-2010, 07:54 AM   #2795
lil-bump's Avatar
Trader Rating: 83 (100%+)
Originally Posted by DS Motorsport View Post
Remove the first gear pinion, then you're able to use the Hudy tool.
Removing the 1st gear pinion worked perfect. Thanks DS!!!!
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 08-10-2010, 05:48 PM   #2796
NiTrO BoOsTeR's Avatar
hey guys, im about to have my first go at the Qld titles here in Australia and i was wondering how much fuel does the standard 733 tank hold without any inserts
thanks guys.
mitch
Serpent 733 - RB T10rc - Ko Helios EX-10
Serpent 733 - Novarossi 3SCT Tuned
============== SERPENT the only way ============
==== Pro Buggy Rc, Pitsworth - for all my RC needs =====
NiTrO BoOsTeR is offline   Reply With Quote
Old 08-10-2010, 06:14 PM   #2797
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Put the inserts in just in case I was over after a run by 3cc
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 08-10-2010, 06:36 PM   #2798
Team Kamikaze's Avatar
thanks guys.
mitch
77.5 cc without inserts.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 08-10-2010, 10:50 PM   #2799
thanks guys
Old 08-11-2010, 06:17 AM   #2800
captian's Avatar
[QUOTE=quietstorm76;7780285]Smart guys! I figured you would[/QUOTE
lol
Old 08-13-2010, 04:21 AM   #2801
Default Centax 3 Clutch issue
Hi All,
I cannot get my clutch to engage properly, I've tried everything. I got the kit with the fly weights with the hole in the wrong end. I tried drilling holes and putting weights in the other end, without luck. I tried filing the other face to 45 deg, and put the fly weights the "right way" in (so they were trailing), it still did not engage. Now I tried putting them in between the pins, still don't work
The clutch gap is approx 0.2 - 0.3 mm, end play about 0.1, and the spring retainer is backed off as far up as it can go, without protruding the threads on the center sleeve.
What can be wrong? I am still running in the engine, so I don't want to over rev it. Do I have to accelerate quickly for the clutch to engage? Or, to ask the same question a little bit different; If I don't accelerate quickly, will the clutch only slip and partially engage? Or should it still engage fully even though I accelerate slowly? (I thought that given enough rpm, the clutch would engage no matter what...)
Please help me, my car has just been sitting on my desk for 4 weeks now, I still haven't been able to drive it because of the clutch issue
Serpent fan is offline   Reply With Quote
Old 08-13-2010, 04:34 AM   #2802
gfilos's Avatar
Originally Posted by Serpent fan View Post
Hi All,
i think the flyweights cause that, cant you get new ones? with a gap of
0.2-0.3mm and spring as soft as it can, i cant see another reason for the
clutch not engaging. Unless the engine is way too rich.
Serpent 720 09 mega zx 12 dsII+, Serpent 733 nova 353 tuned/sirio XXXV
Futaba, Graupner, Hudy, RB fuel
gfilos is offline   Reply With Quote
Old 08-13-2010, 06:26 AM   #2803
dj apolaro's Avatar
Hi All,
I think you are saying it will not engage properly. If that is the case, maybe it is the entire clutch set up is off. It should be engaging immediately and this is causing it to seem bad. Make a gap of .7, go to .2 of end play and tighten the spring with .8 of thread showing. Use this as a starting point and it should work pretty good. The hole can be either way on the flyweights for this clutch and it should work fine. They just all need to be the same of course. If you are still running in the engine just use .4 of threads and then tighten it back up when the motor is ready.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 08-13-2010, 07:50 AM   #2804
NitroWD's Avatar
DJ is right, but i would like to add that if the spring nut is not tightened down far enough; it'll be hitting onto the clutch bell. you'll notice it when you put on the bell without the inner bearing (when you're setting the gap).
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 08-13-2010, 08:08 AM   #2805
Serpent Fan, you mentioned that you are still "running in" your engine correct? if that is true then yes no matter what you do it will not engage if the engine is running too "RICH" you have to lean it out a little bit until the engine produces enough RPM in order for the clutch to engage, just remember that the flyweights are centrifugal and needs a certain RPM to have the momentum to swing out and push the clutch shoe against the clutch bell. hope this helps.
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
