Serpent 733 1/10 200mm touring
#2776
#2777
Captain,
We did not make any shock changes but we did go 1 step softer on the springs (orange). We also reduced the camber to 2 deg and toe to 2.5 deg.
I will be posting the set up for Scott's car in the next couple of days. Stil trying to catch up on work and family.
#2778
Hey Stefan, There is a set measurement for the long rods. Between the ball cup I think it's 47.7, I will double check. No adjustments needed after that. I ran without the sway bar most of the time. I did try it with the sway bar and gained more steering. It changes the car but only took half a tank to adjust to it. After that it felt normal.
my concern is what happens when you hit soemthing or get hit by somebody?
Especially with the Serpent ball cups, where the rods are easily pushed in.
I would expect the handling to be very weird then?!
#2780
would that cause any problems? the shock shaft/piston hitting the bladder?
#2781
#2782
thanks,
also anyone running the long shock bodies at the rear? and how long are the long compared to short.
what spring do you guys recommend for a track with low traction?
im thinking blue front, purple rear?
also whats the difference between
1650
http://www.amainhobbies.com/product_...w-Set-Screws-4
and 1649
http://www.amainhobbies.com/product_...el-Ball-Set-20
serpent recommends 1649 for the lower and 1650 for upper on the instruction manual.
1650
and 1649
#2783
thanks jimmy
#2784
#2786
I think he meant weird if a rod got damaged in a crash.
#2787
#2788
#2790
anyone using the long bodies/shafts?
